Toymods » Tech & Conversions » 18R-GU in TA22
silverfox
Cabooture QLD
18R-GU in TA22 Thu, 17 April 2003 09:09 Go to next message
Hey
i was thinking of putting a 18R-GU in a TA22 celica
will it go straight in , and is there anything i have to change or should change when i put this engine in?
Pumpkin
Toymods Board Member
Re: 18R-GU in TA22 Fri, 18 April 2003 00:56 Go to previous messageGo to next message
Silverfox,
Why a 18RG? Why not a 2TG. The 18RG will not bolt straight in.. Unless you can get a crossmember from a RA21 from the states, then your going to have to change your mounts. It will fit, but not as easy as a 2TG which will bolt straight in, no problems.
You will have to use a W50 or so, as a T50 won't bolt up to the motor.
silverfox
Cabooture QLD
Re: 18R-GU in TA22 Fri, 18 April 2003 05:13 Go to previous messageGo to next message
well i was thinking the 18R-GU cause i got one laying around thats in good nick
i have a bellhousing for my T50 thats will bolt onto the 18R-G
i was just thinking it woud be pretty good if i put it in
if i was to put the 18R-GU in should i go and possibly turbo or of supercharge it?
juzzo84
Hornsby, N.S.W
Re: 18R-GU in TA22 Sun, 20 April 2003 21:52 Go to previous messageGo to next message
i was going to put the import 18rgeu efi motor in my ta22, but the amount of work really wasnt worth it, so now im putting a 2tgeu efi 1600 into the car and stroking it out to 1800 and running it with 3sge injectors off a 3sge.
justin
toycelica77
bris
Re: 18R-GU in TA22 Mon, 21 April 2003 02:26 Go to previous messageGo to next message
silverfox... how much do you want for the 18R-GU?
silverfox
Cabooture QLD
Re: 18R-GU in TA22 Mon, 21 April 2003 07:01 Go to previous messageGo to next message
its not for sale
Classique71
Colac, Victoria
Re: 18R-GU in TA22 Mon, 21 April 2003 12:57 Go to previous messageGo to next message
to put one in - youd obviously need ot swap over to now engine mounts - and hope it all fits
Downside of this conversion so ive heard is the extra weight of the 18rg upsets the balance of the front end of the ta22 - makes it more nose heavy
As others have said - 2tg is your best bet if you want twin cams and an easy conversion - as it is just " bolt in "
power wise the 18rg - in high compression carb form puts out about 145 fwhp , a 2tg - 125fwhp - so your not loosing out much on power on stock motor outputs ..
Decent cams - and tuning will see a 2tg up there with the RG's PLUS you can stroke them out to 1.8 litres with a 3t crank swap !
and out to 2 litres i believe with a overbore ( 86mm ?) and suitable pistons ..
silverfox
Cabooture QLD
Re: 18R-GU in TA22 Tue, 22 April 2003 11:44 Go to previous messageGo to next message
thanks for the help
i think i mite go play with the 18R-GU in a 2nd TA22 body i got just to see ,
what are good quick ideas to give some more power out of a 18R-GU anyway?
Re: 18R-GU in TA22 Wed, 23 April 2003 01:21 Go to previous message
i have seen an 18R-GU put into a TA22.. there is a SERIOUSLY a lot of work involved if you want it to sit properly and not dodgy. THe crossmember needs some serious modifications and some custom engine mounts fabricated. For all that hassle you could buy a good 2T-G, install it and sell the 18R-GU and be out of pocket by only a small amount! And don't forget how easy it is to stroke the 2T out to a 1800cc using the 3T crankshaft!!
As well as that - why ruin the precise handling of the TA22?
Previous Topic:HELP 4agte egine mounts
Next Topic:Installing factory efi pump - help?
Current Time: Thu Nov 19 21:08:30 UTC 2026
Total time taken to generate the page: 0.005465030670166 seconds
