Toymods » Tech & Conversions » Faulty sensor - GZE
AE82TwinCam
Canberra, ACT
Faulty sensor - GZE Fri, 18 April 2003 03:47 Go to next message
what are the negative imlications of having a faulty starter sensor?? besides the fact it switches my engine check light on when I increase revs constantly for 10seconds between 2 and 5000rpm...
Andrew
JDM hachi
was adelaide now newcastle
Re: Faulty sensor - GZE Fri, 18 April 2003 07:52 Go to previous messageGo to next message
if you could clarify what you mean by "starter sensor" i may be able to help?, i assume that you are reffering to the start signal which is sent to the ecu? if the check engine light is coming on what code is it flashing upon earthing the t terminal of the diagnonsis plug? my gze is map sensed thus may be different to the airflow meter version, but on mine the start signal also runs the cold start facility as well as going to the ecu.
AE82TwinCam
Canberra, ACT
Re: Faulty sensor - GZE Fri, 18 April 2003 08:01 Go to previous messageGo to next message
I get code 42 and code 43...
I think code 42 is no vehicle speed sensor is connected to the ecu...
-andrew
[Updated on: Fri, 18 April 2003 08:01]
xpimp
melbourne
Re: Faulty sensor - GZE Fri, 18 April 2003 08:16 Go to previous messageGo to next message
Yer thats cause u didnt connect the purple wire on the ecu Wink
done this the otherday myself and mine does that
if its indeed the speed sensor then thats nothing Smile
JDM hachi
i got this from club4ag
42) Vehicle Speed Sensor No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. for 8 seconds or more.
problems with VSS(speed sensor)
ECU
43) Starter No starter signal to ECU when cranking in TEST mode.(ie t1 earthed)
problems with Terminal STA on ECU
starter signal circuit
starter relay
ignition switch
i wouldnt worry about the speed sensor, and for the most part no damage will occur thru the STA signal not being recieved by the ecu, this is just my opinion, when i put a 4age in my last car the speed sensor issue was there so i installed a switch for the check engine light and the t terminal,and checked for other codes regularly.
AE82TwinCam
Canberra, ACT
Re: Faulty sensor - GZE Fri, 18 April 2003 08:35 Go to previous message
yeah cool, no worries then Smile
thanks fellas!
-Andrew
Previous Topic:WA engineering
Next Topic:considering a button clutch
Current Time: Wed Nov 18 21:03:28 UTC 2026
Total time taken to generate the page: 0.0061259269714355 seconds
