Toymods » Tech & Conversions » boxer engine
HYPA-NOVA
Brisbane QLD
boxer engine Sat, 19 April 2003 10:36 Go to next message
Just wondering what boxer engine would fit in a TA23 the easyest (sp?) I know it would mean modifications, but to what and how hard/expensive?
CTZen
[Updated on: Sun, 20 April 2003 01:46]
jza70-mel
Perth WA
Re: boxter engine Sat, 19 April 2003 14:27 Go to previous messageGo to next message
Do you mean BOXER engine (horizontally opposed cylinders) or BOXTER (Porsche flat six - in an expensive German convertible).
I guess the only modern boxers that are anywhere near affordable are from Subaru (Impreza, Liberty, SVX etc.) The other manufacturers would be Porsche and Alfa Romeo I think.
HYPA-NOVA
Brisbane QLD
Re: boxer engine Sun, 20 April 2003 01:47 Go to previous messageGo to next message
Soz I ment boxer, original message modified...
juzzo84
Hornsby, N.S.W
Re: boxer engine Sun, 20 April 2003 21:49 Go to previous messageGo to next message
are you talking about the wrx boxer or the alfa romeo boxer???
im assuming you mean the wrx, if so i think you could fit one of the 2litre motors in their, go with something around 1996, they had the bigger turbo and will be alot cheaper to buy than say an my99-01
justin
toycelica77
bris
Re: boxer engine Mon, 21 April 2003 01:25 Go to previous messageGo to next message
you mean, water cooled VW engine? Laughing Laughing Laughing
HYPA-NOVA
Brisbane QLD
Re: boxer engine Mon, 21 April 2003 02:14 Go to previous messageGo to next message
definatly be going with a wrx boxer, do you know a model number or something so I could look up specs for it?
RA28
Re: boxer engine Mon, 21 April 2003 09:02 Go to previous messageGo to next message
em ej20t??
something like that anyway.
one more thing...why??? hell expensive I think.
Tim.
juzzo84
Hornsby, N.S.W
Re: boxer engine Mon, 21 April 2003 09:05 Go to previous messageGo to next message
they are not all that expenisve for a full front cut!!!
you can get some inmports that have some awesome aftermarket goodies that come with them.
justin
toyrota
Re: boxer engine Mon, 21 April 2003 09:55 Go to previous messageGo to next message
WRX motor only are or were under $1000 I think $750 from memory,I had the same thoughts a few months ago but you will strike g/box problems to start with.I decided to stick with the rota and add a turbo even if I have to go back to a 12A it will still be cheaper hp Very Happy
Alainve
Newcastle NSW
icon13.gif  Re: boxer engine Mon, 21 April 2003 14:07 Go to previous messageGo to next message
Have you actually seen how wide an EJ20t is? theres enough width in a WRX engine bay to fit a wide V8. theres simply not enough room in a xA23 to fit one as they mount very low in the subie engine bay and their chassis rails sit high unlike the xA23 which has low narrow chassis rails.
then theres also the gearbox problem which isnt really that bad u just gotta remove the front diff from the casing.
i thought about this conversion for the same cost effective reason but it ended up that it would cost twice as much of many of the options out there .BTW ive got a TA22
haggis
Re: boxer engine Tue, 22 April 2003 03:13 Go to previous messageGo to next message
Ditto to Alainve, the EJ20 (came in both the Liberty and Impreza) are a very wide engine. Even in the Liberty which is a wide car compared to a TA series, its still a nightmare to get the spark plugs out past the chassis rails! It would require MAJOR work to get it to fit.
You might have batter luck with the turbo 1800 boxer motor out of a L series Subie, but dont quote me on that!
Also, Subie gear boxes are weak if you want to drive hard. Even with STI close ratio internals we managed to destroy 2 boxes last year rallying a Liberty. 2nd and 3rd gears totaly destroyed! somthing to keep in mind.
Good luck!
Craig.
HYPA-NOVA
Brisbane QLD
Re: boxer engine Tue, 22 April 2003 08:44 Go to previous messageGo to next message
I've been told you can fit a 2lt V8 in a TA23 (imported from usa). Is this true? If so wouldn't it be just as wide as a boxer engine?
RA28
Re: boxer engine Tue, 22 April 2003 09:50 Go to previous messageGo to next message
ooh, that would be nice!! 1000 for suby's best!! what's the deal with bellhousings and w5X boxes??
oops, hi-jacked thread...
..clears throat...
when you think about it, a boxer is way wider than a v8 (that's why they use a V better use of space) I've never seen one but I don't like your chances, look at the tight fit for a 1G, there aint much space in there...
I guess only the tape will tell!!
Tim.
HYPA-NOVA
Brisbane QLD
Re: boxer engine Tue, 22 April 2003 10:12 Go to previous messageGo to next message
what sort of v6 would fit or the largest rotory
blackRA28
adelaide
Re: boxer engine Wed, 23 April 2003 06:59 Go to previous messageGo to next message
either 20B turbo or 13B turbo will easy fit.. and be lots of fun, or if you want V6 go quadcam camry or VG30turbo from 300ZX maybe (ive seen one of these in a datto 1600 so i guess it would fit).
HYPA-NOVA
Brisbane QLD
Re: boxer engine Wed, 23 April 2003 10:03 Go to previous messageGo to next message
how much modifications would I have to do to get either a 12a or a 13b rotory in it?
Alainve
Newcastle NSW
Re: boxer engine Wed, 23 April 2003 13:27 Go to previous messageGo to next message
for starters dont bother with a 12A theyre getting too old to find parts for. however a 13B is relativeley easy to get and with lots of knowledge around are the better choice.
new engine mounts need to be made and your fuel system upgraded to EFI (if not already) possible modification to the gear shifter location in the floor (this varies depending on where you locate the engine. custom tailshaft
theres not much to changing the engine its making it work reliably that takes skill
BTW.why choose a rotary? its like eating a meat pie with fish sauce. Toyota and Mazda it just tastes funny Very Happy
toyrota
Re: boxer engine Thu, 24 April 2003 08:59 Go to previous messageGo to next message
My RA23 has a 13B and I love it,very nice combo I feel and it's been very reliable
One of the best cars I've owned.
I did the conversion myself and it went together pretty easy.
It's really is a good way to go.BTW 13bt is not legal in NSW.
HYPA-NOVA
Brisbane QLD
Re: boxer engine Thu, 24 April 2003 09:40 Go to previous messageGo to next message
Alainve: I have heard alot of good comments about rotaries (like the one above) and have heard how easly they are turbo'ed and/or supercharged. (rx2+rotary+turbo+supercharger=hardcore sideways action Very Happy )
Next question is where do I find out what is legal in qld to put in the celica?
Re: boxer engine Thu, 24 April 2003 10:05 Go to previous messageGo to next message
go to the rta website for qld.
you'll be fairly lucky if they let you put that in your car.
in NSW, there are different rules for <1100kg and >1100kg.
the ta23 is under 1100kg, and because rotors put out so much power, they double their capacity for purposes of determining what you can and cant put in.
so you'd be trying to put a 2.6L turbo in, which is well over what you're allowed.
just go for a 13b bridge port. still has loads of power.
juzzo84
Hornsby, N.S.W
Re: boxer engine Thu, 24 April 2003 11:34 Go to previous messageGo to next message
SKREW ALL THAT,
just buy a 22B quad rotor and whack that in there.
justin Laughing
Bugman
Re: boxer engine Thu, 24 April 2003 11:44 Go to previous messageGo to next message
in NSW you can legally put a 13bturbo into a ra28 Smiley =
gotta love the little extra weight on the rear end
HYPA-NOVA
Brisbane QLD
Re: boxer engine Fri, 25 April 2003 00:48 Go to previous messageGo to next message
draven wrote on Thu, 24 April 2003 20:05
where did a 2.6l come from?
you can turbo and/or supercharge a 13b can't you?
Re: boxer engine Fri, 25 April 2003 15:43 Go to previous message
you're not *actually* putting a 2.6 turbo in there.
but the RTA considers rotaries as double the capacity, hence a 13B (1.3L) is considered a 2.6L by them, for purposes of whether it's legal or not
Previous Topic:Boost Guage and Turbo Timer?
Next Topic:Garrett TA51 on 1JZ-GTE?
Current Time: Fri Oct 30 12:20:14 UTC 2026
Total time taken to generate the page: 0.0091249942779541 seconds
