Toymods » Tech & Conversions » 2s-c fuel pump (broken or not)
bozwon
nowra
2s-c fuel pump (broken or not) Sun, 20 April 2003 08:49 Go to next message
im having problems with the fuel system in my car.
when the fuel tank gets low (about 1/8 of a tank) the engine cuts out if i rev the car past 1200 rpm.
the fuel filter is usually full (about 2-3mm from top) but recently only has about 5mm of fuel in it (down from about 50mm)
when the tank is full the car only cuts out high in the rev range and the filter remains almost empty.
can anyone tell me what the problem is (is the pump stuffed)
ZZT231
melbourne.vic.au
Re: 2s-c fuel pump (broken or not) Sun, 20 April 2003 09:17 Go to previous messageGo to next message
If you have doubts about your petrol pump, replace it...
Cheers.
bozwon
nowra
Re: 2s-c fuel pump (broken or not) Sun, 20 April 2003 09:25 Go to previous messageGo to next message
the biggest problem is im broke untill tuesday and i dont know where to get a pump from or how much it will cost
will try autopro then the wreckers
ZZT231
melbourne.vic.au
Re: 2s-c fuel pump (broken or not) Sun, 20 April 2003 09:31 Go to previous messageGo to next message
Hey,
I have a 2S-C as well. They are fitted on the Croana ST14x as well. Parts are sort of avaliable. I had mine changed after it kept on stalling and did 250,000Kms. Now the car is 450,000Kms on the second pump and going strong.
Having a pump changed makes the mind reassuring that you would not breakdown on the side of the road from fuel starvation.
Cheers.
bozwon
nowra
Re: 2s-c fuel pump (broken or not) Sun, 20 April 2003 09:38 Go to previous messageGo to next message
this engine is only 100k kms old
the car already broke down from lack of fuel on friday. filled the tank up past halfway and it runs ok but stalls high up in the range.
ZZT231
melbourne.vic.au
Re: 2s-c fuel pump (broken or not) Sun, 20 April 2003 09:41 Go to previous message
Just replace the pump. Look around the pump and make sure that the petrol isn't leaking out the pump.
Just replace it.
Previous Topic:is there a difference between between different coloured 20v's?
Next Topic:1995 Corolla AE101 Death Rattle?
Current Time: Wed Nov 18 16:44:37 UTC 2026
Total time taken to generate the page: 0.0051019191741943 seconds
