Toymods » Tech & Conversions » 22R-E EFI gear on 18R-G? Is it all good?
22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 03:07 Go to next message
Ok, as some know after my little stint at Dubbo last weekend, im ready and rearing to get me some EFI goodness on my 18R-GU. I've managed to find myself an Intake manifold with throttle body and TPS i hope, so now im looking at how to control the whole thing.
18-RGEU ECU's, AFM's and looms i would've thought arent exactly going to be the easiest things to find. So im wondering whether the ECU + AFM from a 22R-E would work on such a motor. I'm sure it wouldn't be optimal, but this is just temporary while i save up my poor uni dollars and get some aftermarket computer, some rammed in air and other such goodies. In the end ill have a nice motor, but for now i just want efi to work decently enough.
And before you say do a search, i did... and didnt find much info. I just wonder if anyone has any experience or knowledge of it working.
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 07:41 Go to previous messageGo to next message
Its not going to work. Fuel control for the 18r is going to be different to a 22r. If it did run it would fun very poorly and possibly cause damage if it ran lean.
Blaze
Re: 22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 10:01 Go to previous messageGo to next message
I'm using an AFM and ECU from an early model Camry, with the 2S-EC engine in it. the AFM is exactly the same as that for the 18RGEU. Give me 2-3 weeks and I'll tell you how it all works out.
Lambolica
Northwestern Sydney
Re: 22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 10:19 Go to previous messageGo to next message
When I was chasing up wiring diagrams for my 18r-geu I spoke to the blokes at SSS automotive and they provided my with the wiring diagram for an MX60 (62) cressida (5M???) which they told me they give to everyone who buys an 18r-geu from them.
After that I did a little research on the net and found pin diagrams for their repective ECU's and found the MX60's ECU pluged straight into my 18r-geu loom. personally I can't see why you couldn't use an MX60's ECU and loom and cut off 2 fuel injector plugs. If I'm Wrong let me know for future reference.
However you may have the same fuel control probs as using a 22r
I think the AFM is the same on the cressida as well? Confused
On another note I may be upgrading to a delco or autronic computer in the future and will probably think about selling the standard ecu and loom. I'll let you know if I do.
Stefan
Hobart, Tas
Re: 22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 14:31 Go to previous messageGo to next message
I'm guessing running a 6 cyl ECU on a 4 cyl isn't going to work out
Lambolica
Northwestern Sydney
Re: 22R-E EFI gear on 18R-G? Is it all good? Tue, 22 April 2003 14:39 Go to previous messageGo to next message
As far as I know both the 18rgeu and the 5m-blah injectors batch fire according to the wiring diagrams ie 18r-geu fires to injectors at a time and the 5m fires three at a time the wiring diagram shows the two sets of injectors in series with only two wires triggering from the ECU. So in threory the ecu could run 4,6,8,10,12 cylinders... ohhhh 12 cylinders...can a jag V12 fit in a RA28 engine bay?? Yeh it's late! Razz
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 00:49 Go to previous messageGo to next message
22R-E ECU on an 18R-G can and has been done with great success. Sure it's not ideal, but the early EFI systems are very simple and flexible - it's quite easy to adjust the mixtures by tweaking the spring pressure in the airflow meter.
A 6-cylinder ECU on a 4-cylinder engine is going to be "issues" IMO, however with a bit of experimentation you could probably make it work. I have to wonder if it's worth the effort though when 22R-E ECU's are so easy to come by?
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 01:08 Go to previous messageGo to next message
exactly my thinking norbie!! i also like the idea of the 2s-e, since its also pretty easy and cheap to come by. Depending on the prices i might just buy BOTH!! heehee....
22R-E's are easy to find and buy, just go down to pick and payless, and BANG.. you've got oooodles to choose from!
I would also like to get a matching pair AFM + ECU, just so it runs as smoothly as possible.
I had thought about the 5M-E, but i would rather not break something in the "trying it out" phase....
wilbo666
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 01:15 Go to previous messageGo to next message
Can confirm that the 5ME have batch fire injectors (have the manual in front of me) so that would ease the 4cyl <- 6cly issues, just getting the rest of it to work!
(sorry I did think that it fired all the injectors at once, but looking at the wiring and it does do it in two sets of threes...oops!)
[Updated on: Wed, 23 April 2003 01:51]
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 01:23 Go to previous messageGo to next message
well does the 18R-GEU batch fire all the injectors at once also?
Lambolica
Northwestern Sydney
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 03:18 Go to previous messageGo to next message
The 18R-geu batch fires in two pairs of two the same as the 5M-E batch fires in two pairs of Three
Blaze
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 06:50 Go to previous messageGo to next message
I got the 2SE ECu and most of the loom at a wrecker for $65. the AFM and a filter box what $35. here's the pin outs for the 2SE
http://users.tpg.com.au/desblaze/ToyEFI_Pins_2S-E.gif
The only thing that is missing/different is the Oxygen sensor is not on a 2SE, Which I found strange as the 2S-C carbbie model of the Camry had one and the EFI didn't. Apart from that is all seems the same.
One more thing, i am not sure what the Vacumm Switching valves are???
Like I said give me 2 weeks and I'll tell you how it went
[Updated on: Wed, 23 April 2003 07:00]
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 08:03 Go to previous messageGo to next message
interesting... i might have a search around and ask a few more questions. I'm interested to know if the 18r-geu uses an EGO sensor, and also if the 22r-e uses one. Also want to be CERTAIN of the batch firing arrangement of the different motors.
For now though, i think the 22R-E sounds like the goods Smile
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 09:09 Go to previous messageGo to next message
witzl - what do you mean by EGO?
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 09:25 Go to previous messageGo to next message
EGO = exhaust gas output, ie: oxygen sensor
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 09:27 Go to previous messageGo to next message
i can tell you that the 22r-e uses an o2 sensor. Anything else you want to know about the 22r-e? i am fairly familiar with them.
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 09:31 Go to previous messageGo to next message
do they batch fire in the same way that an 18R-GEU does? ie: in two batches of 2 injectors?
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 09:36 Go to previous messageGo to next message
Each injector injects, at the same time, one half of the fuel required of ideal combustion with each engine revolution.
Thats direct from the genuine toyota repair manual
SkiDMaN
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 10:02 Go to previous messageGo to next message
i have a stuffed 22re with loom and computer and afm if u need it or parts Smile
only thing wrong with the motor is the rings.. other than that it ran like a dream
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 10:15 Go to previous messageGo to next message
what do you want for these parts? Can you pls list price for each separatly.
celicaboy
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 12:00 Go to previous messageGo to next message
a 22r intake manifold will not bolt onto an 18rg head Very Happy
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 12:13 Go to previous messageGo to next message
well derr!!
i was asking about the AFM and ECU if you read my first post silly Razz
celicaboy
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 12:34 Go to previous messageGo to next message
he he i know i was just saying.... you probably couldnt use the ecu and wireing cause they will have different mapping ... the afm .. im nto sure bout that.... is it electronic ignition.. if not you can buy a good fuel only computer for under a grand.. if it is you can get a microtech ecu fitted for 2 grand or for sumfin cheaper you could go wolf 3d for a lil bnit cheaper.. im not sure how much they are but yeah... have a shop around for an aftermarket ecu.. you will be suprised how cheap some are
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 12:45 Go to previous messageGo to next message
well not really... these old computers aren't really "mapped" as such from what im aware... they are more like electronic carbies. They simply measure intake air volume and apply the appropriate fuel mixture to match that air volume and the mixture ratio. This can of course be tuned as norbie said by adjusting the spring tension in the AFM.
And aftermarket computers are a "damn the track" mod, for when i have money. For now the idea of a $150 ECU + AFM is good Smile
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 14:13 Go to previous messageGo to next message
Go for it dude; tweaking a 22R-E ECU can't be any harder than tuning frigging sidedraughts. Very Happy
FWIW the 18R-GEU ECU fires all injectors at once. It has two separate injector circuits so it appears to be batch-fire, but when you open up the ECU both circuits are joined on the circuit board. Weird!
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Wed, 23 April 2003 20:28 Go to previous messageGo to next message
The reason they have two injector pin outs is to reduce the current flow throungh each pin. If there was only 1 pin for injectors, the pin would probably foul up over time, due to excessive current flow.
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 00:18 Go to previous messageGo to next message
makes sense...
and norbie - i gave up on even trying to tune sidedraughts. I figure i understand EFI better, so why not go there. And thanks for the info on the "bracket-type shim" for the oil pump... i'll be investigating Very Happy
Stefan
Hobart, Tas
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 03:05 Go to previous messageGo to next message
BansheeBuzz wrote on Wed, 23 April 2003 19:27
I am faily familiar with them too, and I can assure you this is NOT nessesarilly true.
The 22RE in an '85 RA65 is the shortdeck head the rest of the world got in 85 but uses the older analog EFI with NO o2 sensor -we were running leaded at the time.
later 22RES.. i believe out of Coronas... are TCCS and have an o2 sensor, BUT the TCCS EFI is a lot less tweakable and mod-friendly.
Stefan
Hobart, Tas
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 03:09 Go to previous messageGo to next message
BTW If you're really keen for analog EFI and an o2 sensor, just get an ECU shipped from someone in the US. FWIW, no o2 sensor may give a little less ecconomy but should be easier to tune.
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 12:08 Go to previous messageGo to next message
ill just go to the wreckers, have a look at all the 22R-E's i can find and see what i see hey!
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 18:08 Go to previous messageGo to next message
I just bought some 22re stuff and found out the difference in the lead to unleaded models. So i have a computer and afm that does not run an o2 sensor which is really not much use to me. Let me know if your interested.
gmsta27
Fl
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 18:44 Go to previous messageGo to next message
Here in the states a fella by the name of tim, Timstoys@earthlink.net has a 2tg that is currently running a efi with a 5MGE throttle body, AFM, with a 22re ECU..While I have not seen the car I have been told that the car runs very strong. It has 2.0Liter pistons, and 290 cams. I am currently collecting the parts to do the same thing to my 2tg I will let you know how it works.
Greg
Stefan
Hobart, Tas
Re: 22R-E EFI gear on 18R-G? Is it all good? Thu, 24 April 2003 22:57 Go to previous messageGo to next message
BansheeBuzz wrote on Fri, 25 April 2003 04:08
No one seems to listen to me. What's the big deal with having an o2 sensor? Having a non-o2 sensor model with the ecu in open loop all the time (or is it closed, i always get them mixed up) should make it a lot easier to tune, and the analog EFI is a LOT easier to fool by playing with spring tension and bigger injectors.
The TCCS EFI is a lot less mod friendly, from what I hear it really doesn't like being played with much.
gmsta27
Fl
Re: 22R-E EFI gear on 18R-G? Is it all good? Fri, 25 April 2003 01:15 Go to previous messageGo to next message
My understanding of the early analog EFI is that the O2 sensor is used for idle to maintain mixture once the throttle is opened the afm and ecu mainain mixture.
Greg
BansheeBuzz
Gold Coast
Re: 22R-E EFI gear on 18R-G? Is it all good? Fri, 25 April 2003 03:16 Go to previous messageGo to next message
Stefan wrote on Fri, 25 April 2003 08:57
No one seems to listen to me. What's the big deal with having an o2 sensor? Having a non-o2 sensor model with the ecu in open loop all the time (or is it closed, i always get them mixed up) should make it a lot easier to tune, and the analog EFI is a [b
LOT[/b] easier to fool by playing with spring tension and bigger injectors.
The reason the non-o2 sensor stuff is no good(to me) is cause i have a vehicle that is unleaded has the o2 sensor so the ecu is different. If the ecu was the same as my 22r-e i would keep it but mine has 3 plugs and this has 2 so i was not ignoring you.
[Updated on: Fri, 25 April 2003 03:17]
Re: 22R-E EFI gear on 18R-G? Is it all good? Fri, 25 April 2003 14:06 Go to previous messageGo to next message
even though i am running unleaded... i think i will have no real need for an O2 sensor unless i particularly want to run closed loop ECU. The need for the EGO sensor isn't major... so i wont be using one!
i would be interested in your gear banshee... but you are in gold coast, and unless your price is particularly good, there isnt much point sorry.
celicaboy
Re: 22R-E EFI gear on 18R-G? Is it all good? Sat, 26 April 2003 09:19 Go to previous messageGo to next message
i just read this 18rg/2tgu site and it says that the 2TGEU and 18RGEU can be run with the early Toyota 4AG computers and will be excellent low maintenance fuel injection systems and thats from a preddy reliable site so i think that should be of consideration Very Happy
i ahve never ehard of it until now.. has anybody else heard of it?
Re: 22R-E EFI gear on 18R-G? Is it all good? Sat, 26 April 2003 10:06 Go to previous messageGo to next message
that woud be the the toysport site... i have since learned to take their information with a pinch of salt....
all the same, 22R-E will still be cheaper!
celicaboy
Re: 22R-E EFI gear on 18R-G? Is it all good? Sun, 27 April 2003 00:05 Go to previous messageGo to next message
it would be a cheaper option but if the 4ag computer works it would be more efficient i reckon
Stefan
Hobart, Tas
Re: 22R-E EFI gear on 18R-G? Is it all good? Sun, 27 April 2003 01:31 Go to previous message
Witzl, if you're really keen you could try this DIY EFI. A few guys on the OCC list are going this way.
http://www.bgsoflex.com/megasquirt.html
Previous Topic:where to hook a MAP sensor to?
Next Topic:XT130/RT132 Strut with Hilux/Peugeot Brakes
Current Time: Sat Oct 24 22:08:08 UTC 2026
Total time taken to generate the page: 0.0073649883270264 seconds
