Toymods » Tech & Conversions » diff oil change ??
ae86trueno
diff oil change ?? Tue, 22 April 2003 05:33 Go to next message
Ok, on the weekend im going to attempt to change the oil in the diff, is there any tricks or should it be straight forward ??
Ben.
AE86 Trueno 4AGE
IRA11Y
Club Member
Re: diff oil change ?? Tue, 22 April 2003 06:08 Go to previous messageGo to next message
1, Dump old oil
2, Fill new oil to check plug level
pretty easy Smile
some people take it for a run to warm the oil up so it drains a bit better, Id leave it for a couple of hours to drain, If you really want to get all the filings out then you can go a full rambo and remove the centre and wipe inside with clean rags.
theres no real tricks to it
Evan_26
Re: diff oil change ?? Tue, 22 April 2003 07:01 Go to previous messageGo to next message
Tip: Most diffs (atleast from my performance car experience) have a magnetic drain plug, this collects all the little bit of metal sludge crap on it, wipe that clean as well.
Next time you do the diff oil you can see how much stuff is on the plug, gives you a feel for whats going on inside the diff, ie how fact is it wearing.
I change my diff oil ever second oil change so there should be just about non of that crap on it.
engine oil + filter : every 5000kms or less
rear (and front if applicable, eg gt-r): every 10,000kms
gearbox : every 10,000kms (When driven hard, 6 speed getrag every 5000kms)
In the evo6 the right angle drive unit: every 5000kms witout fail !
And yet to destory a gearbox/diff etc in gtr/evo/gts-t, bit i did destroy syncros on 1st, second and 3rd, and 3rd gear on a sw20 mr2 (40,000kms only !) but toyota told me that it was a bad 3rd gear to start with.
Wowow what a ramble.... oh well you get that.
E
shinybluesteel
melbourne
Re: diff oil change ?? Tue, 22 April 2003 08:21 Go to previous messageGo to next message
if it is coming out a bit slow, light a fire under the diff.
oh and a little trick i think i have discovered, if you want to change the gearbox oil in a sprinter (i will do this soon) take the centre console out, unbolt the gearstick and just pour it in where the gear selector lives, as far as i can tell this should drain into the gearbox (looks nice and gbox oily at least)
(until it runs out of the inspection plug that is, that you have taken the bolt off)
might be easier just to squirt it in the level hole, i think that is the better option actually.
[Updated on: Tue, 22 April 2003 08:23]
wilbo666
Re: diff oil change ?? Tue, 22 April 2003 09:45 Go to previous messageGo to next message
Hmm well I've been meaning to change mine for a while now, really should get off my ass and do it!
One question I have tho is will it help make my diff less noisy? At the moment my diff makes a little noise (is more like a rumbling) under slight load (at about 80kph), I'm guess in its the pinion gear but can I expect changing the oil to do anything to reduce the noise it does make?
shinybluesteel
melbourne
Re: diff oil change ?? Tue, 22 April 2003 13:46 Go to previous messageGo to next message
put some really fine sawdust in it, and some ATF Very Happy
wilbo666
Re: diff oil change ?? Wed, 23 April 2003 01:10 Go to previous messageGo to next message
Is that almost the same as "throw in a banana peel into it.." sort of thing!
Does / will it really work? lol (sounds pretty stupid).
jza70-mel
Perth WA
Re: diff oil change ?? Wed, 23 April 2003 15:50 Go to previous messageGo to next message
It'll work just as well as turning up the volume knob on your stereo - that'll fix the noise from the diff Laughing . Higher viscosity "oil" will lead to more friction (and heat - maybe a fire?), and not to mention more wear from the particles of sawdust.
Diffs only have a small reservoir of oil - so any metal bits floating about will not be diluted by the volume, and will circulate around again causing more wear.
Rolla Boy
Club Member
Sydney, NSW
Re: diff oil change ?? Thu, 24 April 2003 12:38 Go to previous messageGo to next message
Make sure to undo the siller plug first though... Cause If you can't undo it and the oil has already drained, then how do you expect to fill it up???
Helpful Hint Number 23 from Benny boy...
Re: diff oil change ?? Fri, 25 April 2003 14:11 Go to previous message
Remember used diff oil smells just DIVINE!
Previous Topic:Garrett TA51 on 1JZ-GTE?
Next Topic:King vs Whiteline vs Pedders springs
Current Time: Fri Oct 30 12:20:26 UTC 2026
Total time taken to generate the page: 0.016330003738403 seconds
