Toymods » Tech & Conversions » Removing Soarer Headlights
ytri
Preston
icon5.gif  Removing Soarer Headlights Thu, 20 June 2002 07:48 Go to next message
Basically as the title says. Does anyone know how to remove the headlights from a JZZ30 Soarer? Is it possible to remove them without removing the front bar?
[Updated on: Thu, 20 June 2002 07:50]
Manny
Re: Removing Soarer Headlights Sun, 23 June 2002 11:56 Go to previous message
Headlights don't need the bar out but high beams do.
Removal is fairly straight forward: -
Jack front of car up, remove wheeel/guard liner, remove two 10mm nuts holding light assembly on inner guard side, remove electrical plugs from the back of the beam assembly and remove visible 10mm bolt on the radiator side of the light assembly. Raise the front lower section and slide out - careful not to scratch the bar on the way out.
Previous Topic:Tech Info on the 5M-E (MA61)
Next Topic:chassis dyno, not accurate
Current Time: Sat Nov 21 16:05:01 UTC 2026
Total time taken to generate the page: 0.0041408538818359 seconds
