Classifieds » Miscellaneous » FS: 18R-GU motor, minus carbs $400 neg
icon14.gif  FS: 18R-GU motor, minus carbs $400 neg Wed, 23 April 2003 01:49 Go to next message
Ok guys, its time for me to clear out some stuff i have lying around!
18R-GU Motor, 11111-88253 head (same as EFI head, big port big valve). Runs well, complete except for carbies. Comes with 4-1 extractors, carby intake manifold, and maybe a spare 11111-88250 head if you twist my arm well enough. I havent done a compression test because i dont have the tools to do so.
I also have a W50 gearbox spare.... needs a little clean but otherwise works well. $50
Im located in sydney, and the motor isn't in a working vehicle im sorry. But i can vouch that it works, because i used to drive it everyday.
[Updated on: Wed, 23 April 2003 09:15]
Re: FS: 18R-GU motor, minus carbs, big valve head $400ono Wed, 23 April 2003 08:15 Go to previous messageGo to next message
comon people... its got really BIG ports, lol!!
im negotiable too Very Happy
alwaysRA23
Re: FS: 18R-GU motor, minus carbs, big valve head $400ono Wed, 23 April 2003 09:26 Go to previous messageGo to next message
ok heres the question...
wats the differance between the 18rg the rgu head and block power wise and potential power wise?
and how much would it cost to ship to canberra...
Re: FS: 18R-GU motor, minus carbs $400 neg Wed, 23 April 2003 10:21 Go to previous messageGo to next message
ok... the 18R-G in stock used 9.7:1 compression pistons, whereas the 18R-GU used 8.7:1 and the 18R-GEU used 8.3:1.
The 18R-G head used smaller valves and small ports, and they both got bigger for the 18R-GU, and again for the 18R-GEU.
here is some info on the heads:
Quote:
> 88250:
> - 49657 single spring early rgu single dump ex ok head small studs on ex
> - 52978 same as above
> 88253:
> - 73086 double spring late rgu good head to start with large studs on ex
duel dump man
> - 62744 single late rgu still good head may be small stud ex should be
single dump
> - 81784 double spring late also
> - 87278 double spring late also
> 88270: these are ale efi heads all double springs alll good heads these
are the ones you use
> - 35140 biggest ports biggest valves no smog ports best casting
> - 08037
> - 49383 very late head newest ive seen
> - 81225 same as above double late rgu if the head is a 11111-88253 not a
11111-88270
> 88253 88270s would be the heads of choice since these need very little work from the factory these willl make lots of power with little porting
they will make a lot more power with a lot of porting
the castings are a lot thicker around the ports so there is a lot of room
the 88250s can be made good but the ex studs should be changed up to 10mm ones for best sealing
just be glad you dont have any of those 11111-88230 or 88210 heads they are
good paper weights
I have the 11111-88253 head on this motor. And im pretty sure that it has the 8.7:1 compression pistons. Bit nevertheless it has the big ports and double valve springs which is what you want. Basically its the best head from the 18R-G motors.
All the blocks are identical, and are wiiide open for what you want to achieve. A little boring and honing and some oversized pistons reap some good rewards, but the best thing you can do i whack in the 9.7:1 pistons, use the 88253 or 88270 head and port the sucker out. Damn fine! As you can see these two heads have the greatest power potential of them all.
shipping the motor to canberra... would be less than $100
Re: FS: 18R-GU motor, minus carbs $400 neg Thu, 24 April 2003 11:01 Go to previous messageGo to next message
still for sale Smile
marki
Re: FS: 18R-GU motor, minus carbs $400 neg Fri, 25 April 2003 23:56 Go to previous messageGo to next message
wanna sell me the extractors??? Very Happy
marki
Re: FS: 18R-GU motor, minus carbs $400 neg Sat, 26 April 2003 09:58 Go to previous messageGo to next message
would cost nearly 50% of their sale price to ship them..... and i;d rather they went with the motor.
reduction... $350 negotiable.... make offers!
blackRA28
adelaide
Re: FS: 18R-GU motor, minus carbs $400 neg Sun, 27 April 2003 13:11 Go to previous messageGo to next message
Far out man!! i wish i had the money to buy this motor off you, it would be sick for another project engine..!! spewin..
this is a pretty good deal. would be killer for a little datsun 1200 coupe or ta22 hehe..
ra23celicachick
Mornington Peninsula
Re: FS: 18R-GU motor, minus carbs $400 neg Mon, 28 April 2003 02:45 Go to previous messageGo to next message
I actually just bought one about 2 weeks ago.
But if I hadn't I would buy yours.
I wouldn't mind the extractors though.
RA28midge
Adelaide and Queenstown T...
Re: FS: 18R-GU motor, minus carbs $400 neg Tue, 29 April 2003 03:16 Go to previous messageGo to next message
a tentative enquiry,
any idea how much this would cost to ship to adelaide?
blackRA28, you got your engine shipped from justin, how much did that cost?
RA28midge
Re: FS: 18R-GU motor, minus carbs $400 neg Tue, 29 April 2003 10:47 Go to previous messageGo to next message
you have a pm fella.
OmEg_A
Re: FS: 18R-GU motor, minus carbs $400 neg Wed, 30 April 2003 10:53 Go to previous messageGo to next message
Still have the engine and bits?
Thanks Joel
Henrik
Sweden
Re: FS: 18R-GU motor, minus carbs $400 neg Wed, 07 May 2003 17:00 Go to previous messageGo to next message
Ok, this is the kind of engine I would really like to have in my car and I have been searching a long time for an engine like this. I live in Sweden and it is very hard to find an 18R-G here in Europe. What I am wondering is if it's possible to ship an engine from Australia to Sweden and does anybody know what it would cost? I work on merchant ships and I will maybe come to Australia in Oct-Now and if I could find and buy an engine it might be possible for me to bring it onboard the ship and that would save me the money for the transport to Sweden. Does anybody have any tips, ideas, comments or suggestions? Thanks.
Intensevil
Re: FS: 18R-GU motor, minus carbs $400 neg Sat, 10 May 2003 14:11 Go to previous message
I'm also very interested in this engine.
Roughly how much to send to melbourne? I would gladly pay the additional costs.
Also need to know if this is a reco'd engine or how many K's its done.
Previous Topic:Custom Front Splitter - AE82 Hatch
Next Topic:Sprinter Parts Manual (KE-17)
Current Time: Wed Nov 18 23:09:16 UTC 2026
Total time taken to generate the page: 0.010483980178833 seconds
