Toymods » Tech & Conversions » 1UZ conversion update + questions
thefastj
1UZ conversion update + questions Wed, 23 April 2003 13:14 Go to next message
okay, my 1uz is out of the half-cut!! Smile
you beauty!! we went about it by disconnecting every single plug that went to the engine and gearbox (boy it was a b*tch of a job!) and we finally got it out tonight!
some questions...
1. do all 1uz's have the exact same engine mounts from each different model car they came in?? mine is out of a Crown and the engine mounts sit at about 45 degree angles...do any of them (maybe Soarer) just face straight up/down??
2. the whole intake manifold is off, as well as the fuel rail and injectors and that stuff.
while these are off is there anything i should do to it apart from just clean it up a little?
3. if i was to attempt the wiring myself...where the hell do i start now?!? Shocked
4. i need pics of a Soarer sump from a 1uz. i need to know exactly where the bump is...
cheers,
Aaron.
thefastj
Re: 1UZ conversion update + questions Thu, 24 April 2003 07:21 Go to previous messageGo to next message
oh yeah also,
since i've taken the two (top one and one under that) intake manifolds off do i need to get new seals(gaskets??) for them?
Steve_Reynolds
Gold Coast
Re: 1UZ conversion update + questions Thu, 24 April 2003 07:25 Go to previous messageGo to next message
Mate nearly every engine mount you will see is mounted at around 45 degrees as the engine moves whilst operating, it 'rocks' in the mounts in a circular fashion on the same plane as the crankshaft. If the mounts were flat, they would tear apart in no time, if you see what I mean.
DannyGT4
Toymods Board Member
Re: 1UZ conversion update + questions Thu, 24 April 2003 07:58 Go to previous messageGo to next message
thefastj wrote on Wed, 23 April 2003 23:14
have the injectors professionally cleaned/flowed
replace all gaskets and o-rings
Re: 1UZ conversion update + questions Thu, 24 April 2003 10:10 Go to previous messageGo to next message
since you'll be making up custom mount anyhow, is it really a problem what the factory ones look like?
thefastj
Re: 1UZ conversion update + questions Fri, 25 April 2003 03:05 Go to previous messageGo to next message
coz i've bought modified engine mounts and was just working them out!! Very Happy
nzsimon
auckland
Re: 1UZ conversion update + questions Thu, 08 May 2003 04:48 Go to previous messageGo to next message
pull the starter and get it recoed cause it would be a bitch if it failed after you put it all in the car
SupraPete
Re: 1UZ conversion update + questions Thu, 08 May 2003 05:10 Go to previous messageGo to next message
Never heard of any starter problems. I had a similar problem, but it was because the wire to the starter wasn't thick enough.
I put in a knock sensor the other day and I really don't feel like taking the bloody intake manifold off again any time soon ('cept if it was for NOS).
knackers
berala sydney
Re: 1UZ conversion update + questions Thu, 08 May 2003 06:18 Go to previous messageGo to next message
hia thefastj
one qestion did you start the motor up in the front cut before removing it.
cya knackers
thefastj
Re: 1UZ conversion update + questions Thu, 08 May 2003 07:49 Go to previous messageGo to next message
yeah, i don't think i'll worry bout the starter, me too have never heard of these going. Rolling Eyes
hey knackers, nah we didn't start it coz we didn't have a fuel pump lying around so thought stuff it, it's a 1UZ, it should be alright! Smile
guess we'll have to wait and see now hey! Shocked
and yeah, i woulda wanted to get some half decent oil in there anyway if i was going to start and that woulda meaned that we'd have to drain whatever was left, flush it a couple a times with cheap sh*t just to make sure all the "gunk" gets out and all that stuff....so we thought nah we just won't worry bout it.
SupraPete
Re: 1UZ conversion update + questions Thu, 08 May 2003 07:58 Go to previous message
Another thing I did to flush my oil, was to take off the rocker cover and clean the lobes on the cams. If the engine has been sitting for a while (mine had) then the oil can get caked on. I just used a rasor blade.
Also I changed the oil and oil filter (remote setup) 3 times in the first 500kms. I didn't use any cheap oil though as how do you flush THAT out? The ALSC did a study on which was the best oil for the 1UZ and they came out with the Caltex Halvoline synth. I bought 15L and got prepared for some oil changes.
The oil thats in there now will stay in for its alloted 5,000kms.
Previous Topic:More power from Celica = Powerchip ??
Next Topic:Why is a twinky better than a single cam
Current Time: Sat Oct 31 08:02:41 UTC 2026
Total time taken to generate the page: 0.069203853607178 seconds
