Toymods » Tech & Conversions » turbo 18RG
TurboRG
Nor Calif USA
turbo 18RG Thu, 24 April 2003 06:20 Go to next message
Hi All,
on your turbo 18RG
How much Boost can you run until you have
to cut O-ring in your block?
My turbo project is getting close to the end. I know
I need to O-ring the block to run big numbers of boost
And I'm wondering How much boost could you run before you
had to O-ring your block.
I'm hoping to run big numbers of boost of 14 to 16 psi before I O-
ring my block.
This is a long term project for me.
I have 1 block built all ready and I have another
in the planning stages.
That is why I'm asking this question.
If you can help that would be great.
If not have a great day and keep the rubber on the
on the road.
http://photos.yahoo.com/toyceli72
here is some of the pics I have.
Some need to be updated.
I know some you have seen this all ready.
so please bear with me.
Karey
clancey
Re: turbo 18RG Thu, 24 April 2003 06:40 Go to previous messageGo to next message
I assume you want to get the block o-ringed later so you can run a metal gasket.
I'm running 16psi on my 18rg, but i've got a 2mm copper gasket and i've had the block o-ringed.
I think i would only run around 8-10psi max if i was using the standard gasket though. It all depends on what has been done to the engine and how much compression your running but i think 14-16psi would be pushing it.
TurboRG
Nor Calif USA
Re: turbo 18RG Thu, 24 April 2003 06:57 Go to previous messageGo to next message
Hi
My compression is going to be near 9.0
with the 20R piston.
I will be using ARP studs.
celicaboy
Re: turbo 18RG Thu, 24 April 2003 11:49 Go to previous messageGo to next message
you can run up to 10 psi safely if you got your twin webbers still on but if you bring the compression to high 7's you could run 15-18 safely 9 to 1 you wouldnt run anymore then 9 psi without forged pistons
clancey
Re: turbo 18RG Thu, 24 April 2003 23:31 Go to previous messageGo to next message
I'd have to agree with that, considering your setup.
TurboRG
Nor Calif USA
Re: turbo 18RG Fri, 25 April 2003 00:16 Go to previous messageGo to next message
This engine has forged 20R pistons and it will
have APR head studs.
so I hoping to get 14 to 16psi
now and my next engine it will be 20 to 25
with a O-ring block.
blackRA28
adelaide
Re: turbo 18RG Sun, 27 April 2003 09:10 Go to previous messageGo to next message
How about a standard rebuild 18rgeu? can these handle any amount of boost safely without risks? if you replaced the injectors with 3tgte items or something.. ?
celicaboy
Re: turbo 18RG Sun, 27 April 2003 11:55 Go to previous messageGo to next message
as long as the bores are round and the pistons still fit int he bores flush you shouldnt have any problems blackra28 but you would only be able to run veyr low boost.. like no more then 8 psi being a 9:2:1 compression engine with alloy pistons you can run more boost if you bring the compression down.
TA22-3SGTE
MACKAY
Re: turbo 18RG Sun, 27 April 2003 12:21 Go to previous messageGo to next message
I built a standard 18RG a few years ago for a mate and then decided to fuel inject it and run Haltech E6S and stick on a turbo ,Was running on 15 psi for quite a while and there was no signs of any trouble until we decided to turn up the boost to 24psi and then it broke the ring lands , when I pulled it down there was no sign of any leakage in the head gasket.
Trevor
Re: turbo 18RG Sun, 27 April 2003 12:35 Go to previous messageGo to next message
TurboRG, Just wondering what your custom Inlet manifold is made from?
celicaboy
Re: turbo 18RG Mon, 28 April 2003 12:20 Go to previous messageGo to next message
thats because it has had a rebuild and the heltech was running the engine properly.. any engine lasts longer is it has been tuned right Smile
TurboRG
Nor Calif USA
Re: turbo 18RG Tue, 29 April 2003 00:03 Go to previous messageGo to next message
Aluminum pipes.
This manifold I haven't finished and
I don't think I ever will. Now that I have
2 stock EFI manifolds.
pilot
Argentina
Re: turbo 18RG Fri, 07 October 2005 04:39 Go to previous messageGo to next message
TurboRG wrote on Thu, 24 April 2003 03:20
Can anybody elaborate on this "o-ring" thing? what kind of o-rings are used for this? metal? what kind? Are there pics of this?
Also, are there news on this project?
Re: turbo 18RG Fri, 07 October 2005 05:15 Go to previous messageGo to next message
Um, are you aware this thread is over two and a half years old?
Mookie
Tassie
Re: turbo 18RG Fri, 07 October 2005 07:25 Go to previous messageGo to next message
at least he searched
Mr DOHC
Re: turbo 18RG Fri, 07 October 2005 09:38 Go to previous messageGo to next message
true
o-ringing is where they machine a tiny groove about 1.5mm on top of the bore in the block, they fit a little metal o-ring, it just makes for a better seal
pilot
Argentina
Re: turbo 18RG Fri, 07 October 2005 12:16 Go to previous messageGo to next message
I realized that and dont consider the date a problem. I am a moderator myself on another forum and there we encourage to do this (use old topics).
Thanks for the info on the o-rings. I was in the doubt, mainly, on the o-ring material. I know that on drag racing in the USA it is a common practice to use o-ring for cylinder head sealing (only o-ring, not gasket at all). Generally these o-ring are little metal tubes filled with Sodium, for example. They leak pressure at low temperatures, but in normal codition they seal just fine.
willwal98
Toowoomba
Re: turbo 18RG Sat, 08 October 2005 04:23 Go to previous message
hey MR DOHC who is that chick and where do we get more photos from? Very Happy
Previous Topic:gearbox conversion needed in a hurry HELP
Next Topic:question of the wheel??
Current Time: Thu Nov 19 15:54:20 UTC 2026
Total time taken to generate the page: 0.0066039562225342 seconds
