Classifieds » Parts Wanted » 3tgte pressure switches
lvn-ra65c
Wichita, Ks, USA
3tgte pressure switches Thu, 20 June 2002 21:40 Go to next message
anyone have these? ..i need to get these to wire up my knock ecu.
thanks Very Happy
Re: 3tgte pressure switches Fri, 21 June 2002 05:31 Go to previous messageGo to next message
I had heaps of trouble finding the pressure switches for stock 3t-gte engine management.
In the end I got just a generic pressure switch from autospeed. Places like jarcar sell them also I think.
It is only there so the knock sensor works only on boost and not off. You can set this up however you want.
Get a 2 or 3psi switch so it only works above that pressure maybe.
Hope this helps.
Joel
lvn-ra65c
Wichita, Ks, USA
Re: 3tgte pressure switches Sat, 22 June 2002 03:01 Go to previous message
so i would need a normally open 2-3 psi pressure switch? did you end up using the .09psi pressure switch (vacuum switch on their page)? how about the lead for the vacuum switch on the knock ecu? ...normally open also? ..or just run that straight to ground?
and is that jarcar or jaycar? Smiley =
[Updated on: Sat, 22 June 2002 03:16]
Previous Topic:C4 Auto Suit 6 Cylinder
Next Topic:NEED WHEEL URGENT !!
Current Time: Fri Nov 20 21:51:56 UTC 2026
Total time taken to generate the page: 0.010880947113037 seconds
