Toymods » Tech & Conversions » where to hook a MAP sensor to?
where to hook a MAP sensor to? Sat, 26 April 2003 11:32 Go to next message
I hooked up my MAP sensor to the vacuum line that controls the power steering power increaser (for lack of a proper term.. red wine is getting to me)
I'm wondering if this is a fixed or variable vacuum line, and whether it might be part of my car's rather large problem.
I mainly ask because the p/s power upper isn't working... if at idle I turn the wheel hard, my car stalls
help?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: where to hook a MAP sensor to? Sat, 26 April 2003 11:57 Go to previous messageGo to next message
Try tapping it off the fuel pressure regulator vac line, or find it a dedicated port. I have a fitting on my plenum that comes with either 2 or 3 vac fittings available. ATM I'm using 1 for fuel pressure, 1 for MAP, & one spare.
Re: where to hook a MAP sensor to? Sat, 26 April 2003 11:58 Go to previous messageGo to next message
mine are all used, so I've got to tee it into another line
Re: where to hook a MAP sensor to? Sun, 27 April 2003 02:21 Go to previous messageGo to next message
Yeah, keep it away from any line that opens up like that - when you turn the wheel and the vacuum valve opens, suddenly the MAP sensor will see stuff all vacuum, and add HEAPS of fuel, and make the car stall. You need to tee it into a line with a dead end, e.g. fuel pressure reg, or better still give it it's own hose. The power steering vacuum hose is probably the worst one you could choose! Evil or Very Mad
Re: where to hook a MAP sensor to? Sun, 27 April 2003 02:23 Go to previous message
I figured as much *sigh*
ah well, at least I have tons of vacuum hose left over Smile
Previous Topic:ST184 PCD
Next Topic:22R-E EFI gear on 18R-G? Is it all good?
Current Time: Mon Oct 26 07:31:55 UTC 2026
Total time taken to generate the page: 0.0056538581848145 seconds
