Toymods » Tech & Conversions » 4agze pistons in a 4age?
pulcino
Mackay QLD
icon3.gif  4agze pistons in a 4age? Sun, 27 April 2003 03:08 Go to next message
Will 4agze piston fit onto 86kw 4age conrods?
I need to know urgently.....
IRA11Y
Club Member
Re: 4agze pistons in a 4age? Sun, 27 April 2003 03:55 Go to previous messageGo to next message
no , the gudgeon pins are different sizes, they will however fit to a 100Kw rod
feral4mr2
Bundaberg, Qld.
Re: 4agze pistons in a 4age? Sun, 27 April 2003 07:09 Go to previous messageGo to next message
IRA11Y,
i have a spare set of 20mm gudeon pin conrods, will pulcino's crank be the right size though?
all the 4ag engines seem to have the same conrod bearing part #.....
Smile
IRA11Y
Club Member
Re: 4agze pistons in a 4age? Sun, 27 April 2003 11:09 Go to previous messageGo to next message
unfortunately it is unlikely.. most ( I say most because there were some weird crossovers from 86kw to 100kw around but they are very few and far between)100kw conrods have the 20mm gudgeon and 42mm crank to rod bearing where the 86kw were 18mm gudgeon and 40mm crank to rod bearing
if you were really desperate you could swap over the cranks to make it match...personally its easier just to use the whole 100Kw bottom end
feral4mr2
Bundaberg, Qld.
Re: 4agze pistons in a 4age? Sun, 27 April 2003 11:36 Go to previous message
Freakyeah my original 4age (1987 model aw11) has red and black writting on the cam cover. it has the same size conrods/gudeon pins as my 4agze (20mm), same crank etc.. 7 rib block.
so would one of my cranks (42mm crank to rod) fit into pulcino's 3 rib block? (i'm sure he has a blue and black writting ge)..
doh!!! i just read your post again.. so it can be done. Smile
[Updated on: Sun, 27 April 2003 11:37]
Previous Topic:help with alarm info PLEASE!
Next Topic:Easiest, cheapest, best coils to use?
Current Time: Sun Jun 28 11:05:52 UTC 2026
Total time taken to generate the page: 0.02118706703186 seconds
