Toymods » Tech & Conversions » hilux lsd
driftin
hilux lsd Sun, 27 April 2003 08:37 Go to next message
Hi all.
I got a slight problem with my diff swap in my sprinter, I've got a hilux diff about to be put in I'm not sure exactly what model (its got a 5 stud bolt pattern)I bought it of this guy as well as an MA70 lsd and as far as i know they are both G? series centres?(the hilux one is an open ender)What i was wondering was,do u rip the guts out of the hilux diff and put in the MA70s lsd centre into it? is that possible?
I think i should have checked before i got it! Razz
Sam
Sydney, Australia
Re: hilux lsd Sun, 27 April 2003 09:13 Go to previous messageGo to next message
Hi drifta,
I could be wrong but I always thought the MA70 had a 'F' series diff...
sam.
rob_RA40
c'town, NSW
Re: hilux lsd Sun, 27 April 2003 09:25 Go to previous messageGo to next message
MA61 has F
MA70 has G
Re: hilux lsd Sun, 27 April 2003 11:19 Go to previous messageGo to next message
MA70 definitely has a G series diff.
Yes, you can hybrid the Supra diff into the Hilux carrier but you will need some slightly different bearings, depending on which Hilux carrier you have.
Sam
Sydney, Australia
Re: hilux lsd Sun, 27 April 2003 11:27 Go to previous messageGo to next message
Well there you go! I said I could be wrong Smile
Chris Davey
sunny coast, qld
Re: hilux lsd Sun, 27 April 2003 11:33 Go to previous messageGo to next message
umm what is the difference between an F and a G?
Re: hilux lsd Sun, 27 April 2003 11:56 Go to previous messageGo to next message
A little off topic and not directly related to the orignal question, but is there any difference in strength between the diffs in the models of Hilux available? Housing strength? All the axels are the same size I gather?
Re: hilux lsd Sun, 27 April 2003 12:23 Go to previous messageGo to next message
F series = 7.5" crown wheel.
G series = 8" crown wheel.
Cosmo
Re: hilux lsd Thu, 01 May 2003 07:19 Go to previous messageGo to next message
U'd prob get a torsen style diff for the hilux rear end, try looking at the MA61 diff thread.
gold28
Madrid - Spain
Re: hilux lsd Fri, 02 May 2003 03:37 Go to previous messageGo to next message
can ya change over the entire centre including the gear set or is it only the LSD centre???
Maybe the Hilux conversion is looking a little more afordable
Bugman
Re: hilux lsd Fri, 02 May 2003 07:25 Go to previous messageGo to next message
anthony.. diff conversion aint cheap really.. I thought I was getting away cheap with my one but it has all totaled up much higher than I first thought it would.
so do it once and do it right!
driftin
Re: hilux lsd Sun, 04 May 2003 04:59 Go to previous messageGo to next message
Hey r gianttomato i think my hilux carrier is a 4cyl 2 pinion centre? if thats right does it mean i need different bearings? I'm not sure what ratio it is though.
Re: hilux lsd Sun, 04 May 2003 08:38 Go to previous message
That's what I am using too. I believe there is a difference in carriers with ratios higher than 4.3:1 (so the diff places tell me anyway).
The side bearings (where the adjusters go) are different. I am using 32010 bearings. I actually haven't built one up yet....all I have done is the measuring and it looks like it will fit. It's all in a box packed away in a corner of the garage. I don't have a bearing press or a way to measure preload so it'll be a little while before it is done.
Previous Topic:Agze Supercharger?
Next Topic:Clutch problems.
Current Time: Sun Nov 1 21:05:41 UTC 2026
Total time taken to generate the page: 0.0063450336456299 seconds
