Toymods » Tech & Conversions » Testing coils
Testing coils Sun, 27 April 2003 13:34 Go to next message
I have a set of ZE coils here wich I would like tested to make sure they are ok before I try and use them! Is there anyway I can test them?
BansheeBuzz
Gold Coast
Re: Testing coils Sun, 27 April 2003 20:31 Go to previous messageGo to next message
it is possible but much eaiser on a car. you would need.
1 a battery
2 some wires to connect parts together
3 a spare dizzy(this is to trigger the coil, you cannot trigger it on and off by hand ause you cant do it as fast as a dizzy can) You can get away with a points dizzy but an electronic would be better for testing the coils.
4. HT lead
5. Spart tester, a sealed tester is best as the gap the spark jumps is under pressure like it is inside an engine.
6 The coils of cause.
Join them all up and spin the dizzy to see if it fire the spark tester.
Or you could just put your ohm meter on them, inspect for any phisical damage and they should be right.
SUPRAGTE
North Sydney
Re: Testing coils Mon, 28 April 2003 06:46 Go to previous messageGo to next message
Just use a meter, it will usually tell you if they are fine.
Accross the primary you should have 0.6 > couple of ohms.
Across the seconday you should have many k ohms.
If either are open circuit the coil is stuffed, junk it.
Re: Testing coils Mon, 28 April 2003 07:08 Go to previous messageGo to next message
Well I just did a quick check using the Fluke and the primary's came up with .6 Ohms and the secondaries were 90 meg-Ohms Shocked
By these checks they look ok but I guess I cant be sure until they actually get used!
[Updated on: Mon, 28 April 2003 07:12]
SUPRAGTE
North Sydney
Re: Testing coils Tue, 29 April 2003 07:10 Go to previous messageGo to next message
90 Meg seems a bit high, they might be dodgy!
Anyone got a resistance reading on some 7mgte or 4AGZE coils on the secondary side?
Re: Testing coils Tue, 29 April 2003 07:59 Go to previous message
They might not of been 90meg ohms but I think it was more than 20meg! But I cant be sure!
Previous Topic:4A-GTE Questions
Next Topic:Headlight Power
Current Time: Sat Nov 21 07:20:12 UTC 2026
Total time taken to generate the page: 0.0053529739379883 seconds
