Toymods » Tech & Conversions » forced induction....... to blow or to turbo?
marki
forced induction....... to blow or to turbo? Mon, 28 April 2003 06:05 Go to next message
hey all..
have an 18r-g
just wondering what it's like fitting a 18r-guet exhaust and turbo on.. what are the oil lines like to get... If i were to turbo the thing where would i get the oil feed and return lines from.
if this can't be found easily i'll just slap an SC14 to the side of the thing.
also...
carbs.... will the solex's be ok under boost applications??
should i blow through or draw through the carbs?? any thoughts.. ideas..
and then . .. ..
cams... does anyone know where i can get these cams re-ground (if possable)
i'm sure some of you guys may have built somthing similar?
any ideas would be great.
cheers.
shinybluesteel
melbourne
Re: forced induction....... to blow or to turbo? Mon, 28 April 2003 09:21 Go to previous message
i think "slapping an sc14 on" would be harder than sl;apping the equivalent turbo on (assuming you can get the exhaust manifold made fairly easily)
as otherwise you will have to mod the main pulley, or something to drive the 'charger.
you will have to mod the carbies for blowthrough, and use a fuel pressure regulator of some kind. (for supercharger or turbosupercharger)
if you go suck through, it will be easier (just use one carb, but this will be a stuff around and would be more ideal to go EFI) but you can't use an intercooler. (for supercharger or turbosupercharger)
turbo oil return: drill right sized hole in sump (above oil line id say)
turbo oil feed: use a T piece off the oil pressure sender and have one pipe going to the sender and the other to the turbo. (read this in a damn good book on turbo/supercharhging, by allan allard, never tried it myself but id say it is one of the easiest ways to go)
dunno about cams, but i wuldn't bother getting them reground if you are going forced induction.
good luck!
Previous Topic:SX corolla shocks
Next Topic:97 camry, turbo engine and bodykits
Current Time: Sat Oct 10 10:23:12 UTC 2026
Total time taken to generate the page: 0.010225057601929 seconds
