Toymods » Tech & Conversions » HiAce Diff
Malkomv2.0
HiAce Diff Fri, 21 June 2002 04:38 Go to next message
Early 80's Hiace/Liteace diffs. Look large, and a bit like an F series.
What I want to know is where to they hide the ID tags on these things? I cannot find them anywhere. Yes they are still on the car, but they are not on the pillars or in the engine bay.
Any ideas?
Malkom
Re: HiAce Diff Fri, 21 June 2002 05:04 Go to previous messageGo to next message
Malkom, they're hidden under the passenger seat. I believe they are a G series, and a lot of really crazy ratios too, like around 5:1!
Re: HiAce Diff Fri, 21 June 2002 09:14 Go to previous messageGo to next message
Every HiAce I've seen had a G series diff centre. As far as I can tell the whole rear end is the same as the Hilux.
LiteAce has F series from what I've seen, and the 4WD ones (rare) have an LSD F diff in the rear axle.
Malkomv2.0
Re: HiAce Diff Sat, 22 June 2002 03:59 Go to previous messageGo to next message
So that means I can use a Torsen for it doesn't it? What about Liteaces? They have a much narrower track than a Hiace. Less shortening to be done.
Any other vehicles that have G diffs, so I can get 3.9? Do you guys have the links for the Toyota diff codes?
Re: HiAce Diff Sat, 22 June 2002 04:32 Go to previous messageGo to next message
The diff you want is a Hilux RN41 (or that era) diff - it is around 1410 mm wide. It is a G series diff, and you could potentially use the Torsen centre in that. All the Hiace ones I have seen are around the 1500 mm mark or perhaps wider Nope . Beware, apparently there are 2 different carriers depending on the ratios:?:. I haven't confirmed this by checking myself....
Liteace diffs are E centres (7.1") - I have never seen one but I understand the Liteace 4WD have an F series LSD in them.
Here's that link for the diff codes, but it's not entirely up to date.
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/AxleCodes.html
[Updated on: Sat, 22 June 2002 04:44]
chrisss
melb
Re: HiAce Diff Sat, 22 June 2002 05:52 Go to previous messageGo to next message
- giantomatoe that link only tells you how to decipher the diff code, it doesnt tell you what diffs were in what vehicles.
You seem to have an amazing knowledge for these things. Ive looked at your website but couldnt find any info. How did you find out so much?
I dont want to have to walk around the wreckers for weeks looking at ID plates - im sure plenty others have done that already.
Can you please share what you know?
Malkomv2.0
Re: HiAce Diff Mon, 24 June 2002 08:26 Go to previous messageGo to next message
Thanks GT, very useful. But I am looking for the list that tells you what comes in what. I have seen it before, but it was on the old forums..... Somewhere.
Did you end up buying the MkII coupe?
Re: HiAce Diff Mon, 24 June 2002 08:41 Go to previous messageGo to next message
Mk2 Coupe in driveway - awaiting my club president to send me a little handwritten note and a signature on a piece of paper so I can club reg it.
There is this one but it's very USA.
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/diffSize.html
Some of these aren't quite right - 1 ton Hiluxes are definitely G series diffs.
Re: HiAce Diff Mon, 24 June 2002 08:47 Go to previous messageGo to next message
I'm not sure what your really after but try this link. And let me know if it was useful.
http://home.iprimus.com.au/ipirate/Diff.ID.codes.h tml
chrisss
melb
Re: HiAce Diff Mon, 24 June 2002 12:04 Go to previous messageGo to next message
excellent...giantomatoe
not so good cool1
thanx anyway
Re: HiAce Diff Mon, 24 June 2002 12:50 Go to previous message
oh well, it was worth a try. I dont even know where i got that from!
Previous Topic:Ignition Problems 18r-g
Next Topic:Conversion of foot pounds of torque into Newton metres?
Current Time: Thu Nov 19 15:17:50 UTC 2026
Total time taken to generate the page: 0.041712045669556 seconds
