Classifieds » Parts Wanted » AE86 Headlight switch/Gearbox.
4AGE
AE86 Headlight switch/Gearbox. Thu, 01 May 2003 05:20 Go to next message
The listed parts are needed. Pref in melboune if not its still ok. Pm me if u got any goods.
Patr1c
icon11.gif  Re: AE86 Headlight switch/Gearbox. Fri, 02 May 2003 03:27 Go to previous messageGo to next message
The head light switch can be repaired. put a posting on club4ag technical section for instructions on how to do this.
DanielJ
Re: AE86 Headlight switch/Gearbox. Fri, 02 May 2003 08:01 Go to previous messageGo to next message
Sorry, just remembered that I said I would post some pictures on how to fix the problem some time ago Very Happy I've got myself a digital camera now, so I'll take some pictures later on and post them up for you.
DanielJ
Re: AE86 Headlight switch/Gearbox. Fri, 02 May 2003 13:37 Go to previous messageGo to next message
OK, here's how to fix the switch:
When you remove the switch from the dash, you will end up with the below. Simply pop the back off the switch assembly with a small flat head screw driver. Just lever it off in the positions shown by the arrows - there are two places that clip in on each side (a total of four).
http://members.optusnet.com.au/dcjohn/Switch_1.JPG
When you have popped the back off, you will see the below. Just pull the circuit board away carefully.
http://members.optusnet.com.au/dcjohn/Switch_2.JPG
This will reveal another circuit board. Check for broken solder joints and re-solder.
http://members.optusnet.com.au/dcjohn/Switch_3.JPG
This was the broken connection in mine.
http://members.optusnet.com.au/dcjohn/Switch_4.JPG
It should only be around a 10 minute job once you have it out of the dash.
Hope this helps!!
4AGE
Re: AE86 Headlight switch/Gearbox. Sun, 04 May 2003 11:18 Go to previous message
thanks dude. much appreciated. i'll get soldering tomorrow.
Previous Topic:7M-GTE 550cc injectors
Next Topic:AE92 air con conensor
Current Time: Thu Nov 19 19:12:59 UTC 2026
Total time taken to generate the page: 0.007436990737915 seconds
