Classifieds » Miscellaneous » 1 wire and 4 wire oxygen sensors for sale...**SOLD** for now...
1 wire and 4 wire oxygen sensors for sale...**SOLD** for now... Thu, 01 May 2003 12:43 Go to next message
hey all,
**update, only 2 of the four wire sensors left**
i have a couple NEW oxygen sensors for sale. 2 types, 1 wire with toyota connector, and 4 wire heated sensor with crimp connectors. they are Borg-Warner brand for the 1 wires and NAPA-ECHLIN for the 4 wires.
and yes the price is firm Smile it's the best i can do....
first is a 1 wire sensor which is listed as a replacement for many toytas including 4KE, 4AGE, 4AFE, 5SFE, 3SFE, 7MGE etc. it has a connector but you'll have to check if it the correct one. it comes with flange and gasket as shown in pic.
price is $40 plus postage of $3.
pictures are below:
http://www.materials.unsw.edu.au/~sford/OS509-1.jpg
http://www.materials.unsw.edu.au/~sford/OS509-2.jpg
http://www.materials.unsw.edu.au/~sford/OS509-4.jpg
second type is a 4 wire universal heated sensor. it has crimp connectors. has same thread as toyota sensors, M18x1.5. also comes with antisieze compound for the thread.
priec for these is $57 + $3 postage
pics are below:
http://www.materials.unsw.edu.au/~sford/OS874-1.jpg
http://www.materials.unsw.edu.au/~sford/OS874-2.jpg
if you are interested, email me at stewie@unsw.edu.au
[Updated on: Mon, 26 May 2003 07:29]
pepsicola
Re: 1 wire and 4 oxygen sensors for sale... Thu, 01 May 2003 13:48 Go to previous messageGo to next message
interested, is the price firm?
ed_ma61
Lost in the K hole
Re: 1 wire and 4 oxygen sensors for sale... Thu, 01 May 2003 14:17 Go to previous messageGo to next message
ill take a 1 wire if it suits the 86-88 7m-ge
let me know where/when/how etc...
i can pick up too Smile
ed
Grega
melbourne.victoria.austra...
Re: 1 wire and 4 oxygen sensors for sale... Thu, 01 May 2003 21:43 Go to previous messageGo to next message
stewart i'd like one of the 1 wire ones please. i've sent u a PM
[Updated on: Thu, 01 May 2003 21:45]
Soarer
Wollongong
Re: 1 wire and 4 oxygen sensors for sale... Fri, 02 May 2003 04:03 Go to previous messageGo to next message
I'm interested in one of each (I think). My Soarer has 2 sensors, and I think it's one of each. I'm having fuel issues, so I want to replace the sensors anyway.
I'll be in touch very soon if I need em.
Re: 1 wire and 4 wire oxygen sensors for sale... Sat, 03 May 2003 23:51 Go to previous messageGo to next message
bump....
Manny
Re: 1 wire and 4 wire oxygen sensors for sale... Sun, 04 May 2003 01:17 Go to previous messageGo to next message
Are these narrow or wide band O2 sensors? Excuse the ignorant question, but I'm not certain of the differences.
Soarer
Wollongong
Re: 1 wire and 4 wire oxygen sensors for sale... Sun, 04 May 2003 01:58 Go to previous messageGo to next message
I doubt that they are wideband sensors, as the prices are usually in the 4 digit range. They would just be factory replacements I imagine.
Re: 1 wire and 4 wire oxygen sensors for sale... Sun, 04 May 2003 04:27 Go to previous messageGo to next message
sorry guys, these are narrow band factory replacement sensors. the last price i saw for wideband (the NTK L1H1's?) was US$170 but they are hard to get hold of now that Honda and NTK have a deal going for exclusive supply...
so yeah, just normal narrow band sensors, new in box.
Manny
Re: 1 wire and 4 wire oxygen sensors for sale... Sun, 04 May 2003 05:44 Go to previous messageGo to next message
Thanks for the clarification.
I did read somewhere of OEM wide band O2 sensors being used - European car(s) from memory. I'll have a bit of a search when I need one.
Re: 1 wire and 4 wire oxygen sensors for sale... Sun, 04 May 2003 08:11 Go to previous messageGo to next message
yeah, there is a Bosch one being used.. is similar price but is not as yet supported by the DIY_WB.... i think the next version will tho...
basically to run the WB you need a WB controller (to control the oxygen pump) and then a display to see what is going on.... expect to get one going for about AUD$500+
they are good tho!!
joyride
fairfield NSW
Re: 1 wire and 4 wire oxygen sensors for sale... Mon, 05 May 2003 21:54 Go to previous messageGo to next message
Hi there,
you wouldnt happen to be able to grab a MAP sensor for a toyota paseo EL44 would you? the engine is a fuel injected 1.5L 5SFE (?)
Thanks.
Re: 1 wire and 4 wire oxygen sensors for sale... Thu, 08 May 2003 04:08 Go to previous messageGo to next message
bumpity bump Smile
lotsa interest but only a couple of bites? first in first served!
IRA11Y
Club Member
Re: 1 wire and 4 wire oxygen sensors for sale... Thu, 08 May 2003 06:39 Go to previous messageGo to next message
Hey Stewart,
the 4 wire.. is the output compatible to the GE 86Kw ECU inputs??? just wondering if I should take my own advice from a few years back and upgrade Smile seeing as i cant figure which wires on mine are the signal set
Re: 1 wire and 4 wire oxygen sensors for sale... Thu, 08 May 2003 06:51 Go to previous messageGo to next message
IRA11Y wrote on Thu, 08 May 2003 16:39
Hey Stewart,
it should be. afaik all narrow band (re normal ppls ones Wink ) sensors have a 0-1V output. it should be compatible.
the 4 wires are:
2 for heater, power and ground.
2 for the sensor, 1 is signal, 1 is ground.
to check which are the signal wires on yours, put a multimeter between ground and the pins/wires, while the motor is running and warm.
if it is 1 wire, you should get a +0-1V reading (signal) and at idle it should be around 0.5 for stoich.
if 2 wire, one will be 0 the other 0-1V
3 wires, one is +12V, one is 0V (heater ground), the last is the signal 0-1V.
4 wires, the two same colour wires should be the heater, one is +12V, one is ground, the different colour wires will be signal ground (0V) and signal (0-1V).
apart from the heater, the 4 wire has a remote ground, which you can ground to the computers ground, to eliminate any resistance between the exhaust (where a 1 wire is grounded), and the computers ground....
hope this helps a bit Smile
how many wires are there atm? is it flanged? does the flange screw off?
ae86er
Re: 1 wire and 4 wire oxygen sensors for sale... Thu, 08 May 2003 09:40 Go to previous messageGo to next message
I'll take a single wire sensor.
IRA11Y
Club Member
Re: 1 wire and 4 wire oxygen sensors for sale... Fri, 09 May 2003 10:34 Go to previous message
well currently (sorta Smile ) its the factory single wire setup which has its own baseplate so its a one piece as opposed to your 2 piece screw in setup not that theres an advantagfe either way really.
as for meassuring it I guess ill have to heat it up with a blowtorch or something...its going to be hard to measure voltage when its not plugged in Smile thats why I have been having problems figuring it all out Smile I dont know what it came off although it is definately Toyota.
Previous Topic:Corolla sx front seats for sale
Next Topic:TA22, RA23, RA28 and RA40 parts...
Current Time: Wed Nov 18 16:44:41 UTC 2026
Total time taken to generate the page: 0.0068700313568115 seconds
