Toymods » Tech & Conversions » 4AGZE into a 74 TA22
moo4AGZETA22
Tasmania
icon7.gif  4AGZE into a 74 TA22 Fri, 02 May 2003 02:30 Go to next message
Hello,
Who would I speak to about putting it in the tech section?
Should I even bother? I will get around to making a web page eventually, but god knows when. The conversion starts tommorow!!!!!!!!!!!!!!!!!!!!!!!!!! Any general hints, tips, ideas, feedback would be cool.
Justin
thunderbird1
Sydney Australia
Re: 4AGZE into a 74 TA22 Fri, 02 May 2003 02:45 Go to previous messageGo to next message
def put it in the tech section.. it would be helpful for others , the reason for these forums.
SHould be a nice ride once the conversion is done, take your time and enjoy the benefits Smile Smoke a gze for me man Smile
DannyGT4
Toymods Board Member
Re: 4AGZE into a 74 TA22 Fri, 02 May 2003 02:58 Go to previous messageGo to next message
you can email your article to board@toymods.org.au
some tips...
* drink lots of caffeine
* make no plans for the next few weeks
* have 1-3 friends to help... any more and nothing gets done
* be good to your mother
* make sure you have all the gaskets, hoses and parts you need before you start
* make sure the gze is in good condition
* dont forget to add oil and get the oil pressure up before starting Razz
* make sure the sump plug is in when adding the oil
good luck Smile
[Updated on: Fri, 02 May 2003 03:06]
Grega
melbourne.victoria.austra...
Re: 4AGZE into a 74 TA22 Fri, 02 May 2003 06:15 Go to previous message
let me know what you do with the mounts - the drivers side cast ae86 mount is too long - if you use the stock ta22 mounts on the K frame - the passenger side one is also too long - again, shorten it by about 2" and you might be ok.
if you're using a T50 - 4 holes in the floor where the gearbox X member bolts to - the stock T50 in the TA22 uses the front two - the T50 for the 4A will use the back two. you'll have to cut the shifter hole back further by about 2-3".
other than that take pix. would love to see!
Previous Topic:Clips for chrome window surrounds
Next Topic:crassida brakes
Current Time: Sun Oct 25 23:25:16 UTC 2026
Total time taken to generate the page: 0.0034749507904053 seconds
