Toymods » Tech & Conversions » Which turbo for 4AGTE
23Kev
Which turbo for 4AGTE Sat, 03 May 2003 08:13 Go to next message
First post here but surely not the last....
I've got a AE82 Twin Cam Hatch that I am planning a 4AGTE for using the std MAP 4AGZE. I will be using aftermarket computer, steam pipe manifold, i/cooler etc. It needs to be faster than my previous Turbo Swift.... Smile. I think if I have somewhere between 200-250HP at the front wheels I will be happy.
The thing that I am most worried about is the turbo. The car will be driven most days to work and all up will be driven more than your typical fast street car. I really want a turbo that will be making substantial boost by about 3000rpm.
I originally thought of using a T28 off a S14 or S15, but upon thinking of the power that I want, it may not be big enough. Then I looked at the CT26 (I know there are lots of variations, I'm really unsure which is best suited), but after reading one of the posts on here I don't really like the sound of the boost curve. I have really started to think about spending more cash on the turbo and am thinking of the GT series Garrett (or if a large wad of cash falls my way, the new HKS series). I know these are expensive, but I am willing to pay the money if it gets the turbo I want. I assume the GT Garretts will boost up early and have the top end I need for the power I want.
So....Now that you know what I want, what do you pro's suggest??
I especially want any feedback from people that have used these turbos...like
- Where does it start producing boost (like over 1psi)
- Where does it start make substantial boost (like over 6psi)
- Where does it run out of puff
- What kind of power are you making
Thanks a lot....
Kev
TE72_Turbo
Re: Which turbo for 4AGTE Sat, 03 May 2003 12:59 Go to previous messageGo to next message
I JUST fininshed changing over my turbo from a high flowed CT26 to an S14 T28 today. With the CT26, my 4AGTE would struggle to make boost before 4500rpm, but had a screaming top end, now with the T28 its making 5psi at 2500rpm! I've only been for a quick blast tonight, but it doesnt seem to have lost anything up top either. I'll be interested to see the results on the dyno.
If your gonna spend the cash though, you couldnt go past a brand new GT25 with a compressor/turbine combination matched to your setup.
Phil
Re: Which turbo for 4AGTE Sat, 03 May 2003 13:17 Go to previous messageGo to next message
Absolutely, buy brand new IF you can afford it. Otherwise, time to look around Very Happy
The S15 turbo is a reasonable option, I'd suggest you choose between that or R32 RB20 - I used one of these on my car for a while, before I overdid it too many times and eventually the turbine came off. Presently I'm using an RB25 turbo, but this does seem quite a bit laggier. I can recommend the RB20 one though, especially in a FWD car you wouldn't probably want to go TOO much more powerful. The AE101 Levin GTZ is probably the car I'd be game to go the furtherest in, having different suspension etc., but even then I'd tend to be careful.
R32 turbo, properly tuned management (I'd probably suggest haltech/autronic, motec if you feel really cashed up), moderate sized intercooler, 1 bar boost, and you should have something that'll last reasonably well, be good to drive and not cause you too much strife.
nos4ag
Re: Which turbo for 4AGTE Sun, 04 May 2003 10:20 Go to previous messageGo to next message
In my 1988 AE82 Twin Cam, I put a Garret T25 of off a 300zx (one off the twin set-up) onto the 4AGE and it goes excellent!
It makes full boost of 7psi by about 3200rpm and drops off 1psi just b4 redline at 6800rpm. Its great for street driving and is still economical. Bear in mind Im still using the original 4AGE that came in the car, NOT a 4AGZE engine. So yeah, either a
(G)T25 or equivalent. Anything bigger than a T28 is (to me) too big for daily street driving, it just depends on whether you are gonna use the car for anything else in the future e.g : drags or circuit racing e.t.c
Regards, NOS4AG!
P.S: With a small amount of retarded ignition timing( for safety sake), Im making 100kw at the wheels on 7psi.
[Updated on: Sun, 04 May 2003 10:28]
Re: Which turbo for 4AGTE Sun, 04 May 2003 10:51 Go to previous messageGo to next message
Hey Kev, there's a name I recognise! So you got permission to modify the better half's car huh? Nice work. Smile
23Kev
Re: Which turbo for 4AGTE Mon, 05 May 2003 00:26 Go to previous messageGo to next message
G'day again,
Thanks for the replies.
Norbie: Nah not like that, I've got the Twin Cam for me, and Bec and I have bought a Barina for a car for her. I'm trying to sell the 200sx but having worse luck than the Swift!!! Sad Hopefully thou I'll have some fun with the corolla and it will hold together better than the swift....especially in the gearbox department!! Very Happy
I've been thinking some more about the suggestions on here, and I really don't think the t28 (which I guess most people are suggesting) will be big enough for the power I want. Has anybody put a VF22 (usually used as a power up on a WRX) on a 4AG?? What kind of performance did they get out of that? On a WRX they are good for about 200hp at 4 wheels, we all know how much power they loose on a dyno, they are BB too so that is an advantage. I'd think that might be pretty well suited to what I'm after.
In all reality I guess I am asking if anybody has done a 4AGTE with the kind of components and power delivery I am after. Either somebody I can talk to in Australia, or anywhere else in this wide world....surely somebody can help out.
Thanks a lot for your views and ideas...muchly appreciated.
Kev
Re: Which turbo for 4AGTE Mon, 05 May 2003 00:53 Go to previous messageGo to next message
From what I've gathered, the ball-bearing turbos from the S14A 200SX (revised model) and S15 200SX (I'm pretty sure they were the same turbo) are good for over 170-180rwkW. Hell, one company, I think it was APS had one of their demo cars putting out 200rwkW.
If you convert these into hp as you are using, 170kW ~ 230hp. I don't think you'd need to go to the expense of something else if these BB T28's could support the power level and still give good boost response. Shit, cheaper than a GT25!
Edit: And from what I've read, the VF22 Turbo from the Sti makes the car a bit laggy on a WRX. I'd imagine it would be similar to a CT26 and would only be worse if you removed 400cc.
[Updated on: Mon, 05 May 2003 00:55]
Twincammer
West Sydney, NSW
Re: Which turbo for 4AGTE Thu, 19 June 2003 16:36 Go to previous messageGo to next message
Hey Nos4ag,
I have an 88 twincam with the big port 4age and I read in your post that you had turbo charged this engine. I have been hoping to do this on mine and run a similar turbo at low boost (around 5 psi) but have been worried wether this engine's internals can handle it.
I was wondering then, will this engine handle the turbo well? Or can I expect it not to last very long even if I run it a low boost? Also cost wise, how much roughly did it cost you?
Sorry bout havin so many questions, just really interested in plannin for this.
Chris Davey
sunny coast, qld
Re: Which turbo for 4AGTE Thu, 19 June 2003 23:33 Go to previous messageGo to next message
twincammer: you may have to try PMing him as the thread has been revived a little.
Twincammer
West Sydney, NSW
Re: Which turbo for 4AGTE Fri, 20 June 2003 04:00 Go to previous messageGo to next message
Ok will do.. thanks!
drifter4ag
Auckland
Re: Which turbo for 4AGTE Tue, 24 June 2003 04:42 Go to previous messageGo to next message
ok
turbo bluetop is sweet even at 15psi if you have fuel
i have built 3 turbo setups on bluetops and ive almost got it as i want it
first was a t3/4 and at 5psi with 0deg spark advance was making 97kw@wheels with stock fuel system and GTZ intercooler.
Number 2 was custom T25 Turbo similar to the M10 Series you find on pulsars and S11/12 Silvias ..with GT4 intercooler and 2inch downpipe with screamer and 5deg spark advance stock fuel this made 106kw@wheels on 4.5psi ..
finally i have changed to a Ca18det turbo (t25) same intercooler but with about 12psi boost and 5deg advance and downpipe is now 2&3/4inch and may or may not be running sidepipe on the dyno .. NOTE:THIS SETUP HAS MORE FUEL but still on a bluetop engine. This will be dyno'd on Saturday 26th June and then i will post up all the Dyno sheets on our website www.garagedori.com
ALL THESE ARE ON STOCK BLUETOP ENGINES ..no INTERNAL MODS..NO REBUILDS ..all 200k+motors
ANY QUESTIONS feel free to email me at drifter4ag @ garagedori dot com
Matt
Sprinta
Re: Which turbo for 4AGTE Wed, 25 June 2003 07:40 Go to previous messageGo to next message
Interesting results..
I got the haltech e6k in finally and got it back yesterday.. It pulled 166hp@wheels on 14psi.. r33 turbo and vr4 intercooler.. ae92 gze motor
thats 123rwkw.. i expected more Sad
Ribbo
Northern Beaches
Re: Which turbo for 4AGTE Wed, 25 June 2003 08:17 Go to previous messageGo to next message
how long has each of these motors lasted?
are you just doing the stock ge's cos you got them lying around? hehe
or is it the same motor?
drifter4ag
Auckland
Re: Which turbo for 4AGTE Wed, 25 June 2003 23:15 Go to previous messageGo to next message
first one the 97kw ended up losting the t3/4 and trading to an RB20DET turbocharger .. and ran at around 10psi for 1.5years
2nd one had a few problems with fuel surge and sparking plug faliure so i went throught two motors with that setup.
The most recent motor has been in the car 2months and has been to two drift days ..one competition and one practice day. And i dont see it expiring anytime soon .. most bluetops will last a very long time with turbo ..safely 7-8psi .. no trouble ever 4-5psi ..and shortened lifespan = 10-14 psi which is what im currently running .. it all comes down to spark and advance.
And why bluetops ? .. compression isnt 2 low and isnt 2 high .. and they also cost about $60 from a wrecker
ive done a turbo redtop but it was running 11:1 +8psi and that was when the spark plugs shat themselves resulting in a slight meltdown.
But note .. Stock fuel system and ecu and injectors .. With a programmable ecu you can make them last plenty with good spark retard systems and stuff like that.
ke382TG
Re: Which turbo for 4AGTE Thu, 26 June 2003 01:21 Go to previous messageGo to next message
G'day there, just another 4AGTE setup. Mine made 216hp at the wheels on the dyno at Summernats this year (On a variety of Dynos its always been within 2 or 3 hp of that so its a reliable figure). The setup is as follows:
* T28 off a Skyline (It has been highflowed and runs steel wheels)
* This power was made with the standard AFM GZE computer and 14.5 psi.
* Has full 14.5 psi boost by 2750 rpm, never really looked at when boost starts etc.
I am currently fitting a programmable computer, MAP sensed so I can remove the restriction of the airflow meter, and fitting bigger injectors so I can run a high boost setting of approx 19psi (low boost setting will be somewhere below 14psi). If you have any Q's PM me. If all goes to plan I will give it a run this Dyno day (6th July).
Shane.
[Updated on: Thu, 26 June 2003 01:24]
Ribbo
Northern Beaches
Re: Which turbo for 4AGTE Thu, 26 June 2003 02:50 Go to previous messageGo to next message
whats a gtz intercooler? do you mean gze?
Sprinta
Re: Which turbo for 4AGTE Thu, 26 June 2003 03:01 Go to previous messageGo to next message
Toyota Corolla Levin/Trueno GTZ is the car which has the 4agze motor.
drifter4ag
Auckland
Re: Which turbo for 4AGTE Sun, 29 June 2003 03:02 Go to previous messageGo to next message
OK
all done
back on the dyno again for more power runs
we ran it up 4 times yesterday
run 1-2 119kw@wheels with 10.8psi and 650nm on a roller dyno. with 2inch exhaust 2 resonators , over diff and super turbo muff.
run 3-4 130kw@wheels with 11.1psi and 600nm same dyno with my cust side exit exhaust and no mufflers which was a very good figure
but
i have reached the fuel limits of the bluetop injectors and ecu so no more can be achieved without full engine balence/head porting etc or aftermarket ecu/plugin systems
Still stock bluetop engines S13 turbo and Nite Parts and Performance manifolds and downpipes which are made in NZ and i can ship to austrailia if anyone is interested. VERY GOOD MANIFOLDS.
also K Skewes AA60 carina with M10 pulsar turbo and 9.2psi ran up 117kw@wheels with no intercooler !! Dyno for that will also be available
Dyno printouts with be available later this week on www.garagedori.com
Ribbo
Northern Beaches
Re: Which turbo for 4AGTE Sun, 29 June 2003 08:49 Go to previous messageGo to next message
congrats, very good figures
what fuel pump are you running? and have you got bigger lines, or just stock?
and how much are the manifolds?
[Updated on: Sun, 29 June 2003 08:52]
drifter4ag
Auckland
Re: Which turbo for 4AGTE Sun, 29 June 2003 23:09 Go to previous messageGo to next message
Im running stock intank AE86 fuel pump and 2.9bar fuel pressure reg.
Turbo Manifolds retail at $690 but i can get cheaper than that i think
also we have a cast bellhousing to fit W series gearboxes straight to your 4age and they also fit the GZE 220mm flywheel and clutches ..
email me at drifter4ag@garagedori.com for more info and prices .. i can work out a custom deal for everyone ..or i can fly over to aus and set your cars up for you Smile
boris
On probation
Brisbane, Queensland
Re: Which turbo for 4AGTE Mon, 11 August 2003 09:02 Go to previous messageGo to next message
600nm of torque Shocked Shocked Shocked
sprinterboy4agze
Re: Which turbo for 4AGTE Tue, 12 August 2003 22:04 Go to previous message
where do u guys get you rear wheel drive inlet manifold?????
Previous Topic:3t/2tg hybrid?
Next Topic:gze oil question?
Current Time: Thu Oct 29 15:56:50 UTC 2026
Total time taken to generate the page: 0.031677007675171 seconds
