Toymods » Tech & Conversions » TA22 with 4AGZE Engineer Certificate
rollaboy
Coffs
TA22 with 4AGZE Engineer Certificate Sun, 04 May 2003 13:13 Go to next message
Has anyone here had any troubles getting a engineer certificate for a TA22 with a 4AGZE??
$450 ta22
vic Castlemaine
Re: TA22 with 4AGZE Engineer Certificate Tue, 20 May 2003 14:34 Go to previous messageGo to next message
i dont no an answere 2 your question but i whould be interested in how u get on as i dream about 4agzes in my car frequently
rollaboy
Coffs
Re: TA22 with 4AGZE Engineer Certificate Wed, 21 May 2003 01:22 Go to previous messageGo to next message
I havn't actually got a TA22 or one with a 4agze i was just researching before i went out and spent a heap of money on one and then find out i can't get it engineered.
trent_kershaw
Re: TA22 with 4AGZE Engineer Certificate Wed, 21 May 2003 01:52 Go to previous messageGo to next message
might have to upgrade your brakes, but other than that, if everything is done properly, engineering shouldn't be an issue.
GZE-STYLE
Camden
Re: TA22 with 4AGZE Engineer Certificate Wed, 21 May 2003 02:07 Go to previous messageGo to next message
Yeah my friend used to have a TA22 with a gze in it. Its the one in the New South Wales forum thing. He had to do a brake upgrade to disks all round which was a bit of a cunt. He used the Corona diff with the disks on the back, then used RA60 struts in the front. Passed no worry's regarding the brake upgrade. He need to fit a baffel in his exhaust as it was around the 105+ Db. Baffel brought it down to 94db i think. That was with a 2.5 inch mandrel bent exhaust.
EDIT: He had to put a unleaded fuel restrictor in aswell
[Updated on: Wed, 21 May 2003 04:11]
moo4AGZETA22
Tasmania
Re: TA22 with 4AGZE Engineer Certificate Wed, 21 May 2003 03:17 Go to previous message
I'm doing that conversion at the moment.
Transport in Tasmania have said that I didn't need an engineers certificate. I have to take it to a Transport approved mechanic to check it out and give it the all clear. This is because the engine hasn't been an increase in capacity, and doesn't increase horsepower by more than 25%. I'm going from a 124 hp 2TG to a 145hp 4AGZE AW 11 engine. So I could put an engine in that has 155hp without an engineer's certificate.
If I wanted to put in say a Lexus V8, then I would have to get it engineered. Rotary conversions are also difficult to get approved.
I did speak to the guys who are going to inspect my car. We then ran through the things they wanted me to do to my car, and they were quite reasonable about it. They prepare cars for Targa Tasmania, so they must know something about fast cars...
I'm putting bigger brakes up front, and am using a Hilux diff with the standard drums. They were fine with the drums as a Hilux weighs more than a Celica and is designed to stop a vehicle with a lot of weight (2000 kg +).
I'm also using the standard computer and am fitting a 2.5 inch exhaust with a catalytic converter. There are no emission tests for conversions (as far as I know), and technically I don't have to run a cat as my car is pre 76, but I want to do my little bit for the environment. Plus a car running on unleaded with no cat is worse for the environment than a leaded vehicle (please correct me if I am wrong). Transport also like cars to be quiet.
The main thing is to reasonable and not bring the car in with split lines, leaks etc. Trust me, they are extremely thorough with these inspections, and will yellow sticker cars for the most trivial things.
Hope that helps in some way???!!!
Justin
Previous Topic:1G-GTE crank pulley
Next Topic:clutch problem?
Current Time: Thu Nov 19 23:20:37 UTC 2026
Total time taken to generate the page: 0.0051460266113281 seconds
