Toymods » Tech & Conversions » removing front wheelbearings
RobertoX
removing front wheelbearings Mon, 05 May 2003 00:26 Go to next message
simple question: How do most people remove the bearing seats (is this what they are called? The bit that gets stuck in the hub anyway...) Use a gear puller?
I 'practiced' on a damaged hub that I had, by knocking the seat out from behind with a hammer(large) and screwdriver Confused but now the hub is a little more damaged Razz
any tips would be muchly appreciated
RobertoX
Re: removing front wheelbearings Mon, 05 May 2003 04:32 Go to previous messageGo to next message
anyone?
Re: removing front wheelbearings Mon, 05 May 2003 04:37 Go to previous messageGo to next message
That is exactly what I do. Just use a little more caution and all will be good.
ed_ma61
Lost in the K hole
Re: removing front wheelbearings Mon, 05 May 2003 04:42 Go to previous messageGo to next message
perhaps instead of a screwdriver, a length of steel rod with the edges of the end just rounded off. might cause a little less damage Smile and rememer to work you way around the ring of the outer bearing race, dont just smash it out from one side - you can ovalise the seat.
ed
RobertoX
Re: removing front wheelbearings Mon, 05 May 2003 06:16 Go to previous messageGo to next message
thanks guys Smile
Rolla Boy
Club Member
Sydney, NSW
Re: removing front wheelbearings Mon, 05 May 2003 11:53 Go to previous messageGo to next message
Try a hydraulic press dude... It's the only way to get it out properly...
I'm doing mine at the moment and a press is the way to go... easy as...
ed_ma61
Lost in the K hole
Re: removing front wheelbearings Mon, 05 May 2003 12:05 Go to previous messageGo to next message
a hydraulic press is a bit of overkill isnt it!!
we are just talking about punching out the outer bearing race from the hub arent we??
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: removing front wheelbearings Mon, 05 May 2003 12:16 Go to previous message
If you can, get a brass or aluminium rod, or drift as it's also known. That way you won't damage anything, as the drift is softer than the axle, or whatever it may be.
Previous Topic:How Loooooooow Can you Go !!!!!!
Next Topic:1JZ question?
Current Time: Mon Oct 26 15:10:27 UTC 2026
Total time taken to generate the page: 0.010851144790649 seconds
