Toymods » Tech & Conversions » help back firing on boost
knackers
berala sydney
help back firing on boost Mon, 05 May 2003 06:00 Go to next message
hi all
got the iggte going like a rocket its in a hilux ute.Till i let a so called machanic have a look at the cold start idle.Now when the second turbo come on to boost it back fires and break down real bad. any one out there got any ideas what may be wrong.
thanks in advance knackers
Embarassed Sad Sad
Re: help back firing on boost Mon, 05 May 2003 07:44 Go to previous messageGo to next message
Sounds like you might be hitting boost cut. How much boost are you running?
knackers
berala sydney
Re: help back firing on boost Mon, 05 May 2003 07:57 Go to previous messageGo to next message
running about 10 psi but it would rev hard be for no probs till this f////en nutter got hold of it
Re: help back firing on boost Mon, 05 May 2003 11:33 Go to previous messageGo to next message
Well if a mechanic screwed up your engine I suggest you take it back and demand he fix it for you.
sideshow
Re: help back firing on boost Mon, 05 May 2003 11:46 Go to previous messageGo to next message
wehat u mean by 2nd turbo
they both boost up together at same time
check for air leaks
or maybe even bad spark plugs
check that he hasnt swapped em for shitty ones its been doen b4
if its electrical i can possibly look at it for u
TE72_Turbo
Re: help back firing on boost Mon, 05 May 2003 12:46 Go to previous messageGo to next message
check your spark plug condition, & gaps. you may need to close them down to 0.8-0.9mm, but I wouldnt really expect that you'd need to with only 10psi
TA22-3SGTE
MACKAY
Re: help back firing on boost Mon, 05 May 2003 13:03 Go to previous messageGo to next message
Backfiring when boost comes on can be caused by leaning out , check your fuel filter and pressure .
Trevor
Bugman
Re: help back firing on boost Mon, 05 May 2003 14:07 Go to previous messageGo to next message
yeah if he was playing with the cold start(stepper motor) he may have knocked the vacum line to the fuel reg. also check that once the car is warm the stepper motor is closing off.
knackers
berala sydney
Re: help back firing on boost Mon, 05 May 2003 22:28 Go to previous messageGo to next message
hi all
Thanks for all the replys.Dont no what the prob is at the moment but will tell you all when i find it.I think the bugman is onto the prob will check it out.
Thanks again cya knackers
ps is the stepper motor on top front of the plenum chamber
Bugman
Re: help back firing on boost Tue, 06 May 2003 04:32 Go to previous messageGo to next message
also check all the leads are secured to the spark plugs.
knackers
berala sydney
Re: help back firing on boost Tue, 06 May 2003 09:28 Go to previous message
hia all
Well iam a bit :blush:embaressed for baging my machanic(sorry)
The problem turn out to be a lose wirer (the main wiring loom from the coil)one wire caused all the trouble Rolling Eyes . well its going great now.Well thanks again boys for your advice & suggestions.
cya knackers Very Happy
Previous Topic:Price for a R154 GEARBOX.
Next Topic:7M auto box service
Current Time: Fri Oct 23 16:34:14 UTC 2026
Total time taken to generate the page: 0.0063340663909912 seconds
