Toymods » Tech & Conversions » 1G-GTE Twin Turbo
dispatcher
Malaysia,Kuala Lumpur
1G-GTE Twin Turbo Mon, 05 May 2003 11:16 Go to next message
Hi ya all, i know the've been many post with regards to the 1G-Twin Turbo. I just want to know the following,
1) The good and bad points
2) IS this a Sequential Turbo ?
3) IN the Forum on the Top sometimes there's a RA40 i thing
with a 1G all polished and chromed. Where can i get to see more of that particular engine.
Thanks/Dispatcher
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:19 Go to previous messageGo to next message
For points 1) and 2), this: SEARCH and a few well chosen keywords are your friend.
As for the 1G-GTE with the shiny pipes, Nark nabbed that from somewhere, last time I checked he couldn't remember where...
ROBBO_ma61
a whole 210hp in stock form. non sequential turbos. Nice responsive engine tho..and can be worked with extra boost etc...what car is it goin into? if something bigger than a celica...go a 7mgte/ or 1/2jzgte.
dispatcher
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:28 Go to previous messageGo to next message
Thanks Guys, will do my homework, If anyone knows where i can find a full blown up pic of the 1G with the shiney pipes..please pass it on.
ROBBO_ma61
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:31 Go to previous messageGo to next message
if its any consolatation the shiny pipes dont make it go faster...
[Updated on: Mon, 05 May 2003 11:32]
dispatcher
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:36 Go to previous messageGo to next message
sure they don't, but they sure make a 'statement' tho Cool
ROBBO_ma61
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:38 Go to previous messageGo to next message
why not make it go fast first? Just get stainless steel and mr sheen it Smile
dispatcher
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 11:44 Go to previous messageGo to next message
Yup ,thought of that. Steel Wool and some really good metal polish. Will update you guys on progress.
cheers/dispatcher
Re: 1G-GTE Twin Turbo Mon, 05 May 2003 23:52 Go to previous messageGo to next message
If the "shiny pipes" are HPC coated, that actually will make the car (slightly) faster.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon2.gif  Re: 1G-GTE Twin Turbo Tue, 06 May 2003 01:13 Go to previous messageGo to next message
Yeah, that was a pic that I found somewhere. I think it was in a mag...
What car is it going into? The 1G is a good engine, but some others may be better for you depending on what you have.
dispatcher
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 02:35 Go to previous messageGo to next message
Norbie/Nark , thanks a million, The 1G will be going into my Cressida GX60. Now Norbie you said HPC coating; WHAT IS IT ?
Nark
Cabramatta, NSW
icon1.gif  Re: 1G-GTE Twin Turbo Tue, 06 May 2003 02:48 Go to previous messageGo to next message
Should be a pretty easy swap since it's still a 1G.
But you might find that a 1JZ might be better value since you have the room in the engine bay and the long wheel base. You get more torque from the extra capacity. How heavy is a GX60?
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 03:45 Go to previous messageGo to next message
HPC is a form of ceramic coating; it's pretty expensive but it's good stuff. One of its properties is heat resistance, which is especially beneficial on headers and turbo dump pipes (ie it keeps the heat inside the pipe). It's also used on intercooler pipes to reduce heat soak. I had my dump pipe and intercooler pipes HPC coated, but I had the latter painted matt black because they were too damn shiny! Smile
Forgot to add: check this link for more info:
http://www.hpcoatings.com/exhaust_coatings.htm
dispatcher
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 12:34 Go to previous messageGo to next message
Nobbie / Nark , Thanks again for the info,
Seriously i've no clue to the exact weight..but i think about 1.2 Tons. Will check out the HPC coatings website. Will also need some info on Boost controllers Fcon.S-AFC etc..to get some extra horses..
cheers/Dispatcher
7M-Brisbane
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 12:52 Go to previous messageGo to next message
I assume the G means that it comes with a 1G from factory, in which case the 1G is the best choice.. but 1.2 tonnes is a lot of weight for a 1G to haul around.
dispatcher
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:00 Go to previous messageGo to next message
Well i wont know for sure as for the weight to power ratio, i'm compiling some info to send to Toyota Cust.Support in japan.
hopefully they can shed some light on the topic.
Stefan
Hobart, Tas
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:15 Go to previous messageGo to next message
Err.... 1.2 tonnes is the same as an A6 Celi like Narks or mine (1220kgs w/ driver & half a tank rings a bell Nark)
If it's a heavy car... perhaps try the 1G-GZE? Boost from idle should help move a heavy car around.
Just random thoughts, i don't pretend to know much.
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:39 Go to previous messageGo to next message
Since when is 1200kg a heavy car for a 1G to be pulling around? Shit, in that case my ~1275kg Celica XX is going to be positively porcine!
Stefan
Hobart, Tas
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:46 Go to previous messageGo to next message
that was kinda my point.
BTW that sounds pretty light for a Supra... I guess the 1G-EU must be lighter than an M series or soemthing, but all the Supra accessories add up. Even the padded dash is supposed to be substantially heavier in the Supra than the Celica.
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:51 Go to previous messageGo to next message
Well, the rims I've got are lighter than the Supra ones, I've got a space saver spare coming instead of a full size spare, I don't have climate control. My seats are also lighter than the Mk2 ones, it all adds up. 1275kg is the goal weight once the 1GGTE is installed.
Ed's MA61 weighed 1340kg with half a tank of fuel, a toolbox and a sub, so I figure with the extra weight removed from the bits I've done, the less weight of the 1G, I reckon I can get in between 1275-1300kg which would be perfectly acceptable for a 2l turbo engine.
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 13:53 Go to previous messageGo to next message
As for the Supra parts weighing more, they do *but*, having pulled apart quite a few Supra and Celica interiors, it wouldn't be by much.
Re: 1G-GTE Twin Turbo Tue, 06 May 2003 23:41 Go to previous messageGo to next message
7M-Brisbane wrote on Tue, 06 May 2003 22:52
I hate to tell you this dude, but your Corona is going to weigh about that much when you're finished shoehorning that 1G in! Razz
Nark
Cabramatta, NSW
icon14.gif  Re: 1G-GTE Twin Turbo Wed, 07 May 2003 00:26 Go to previous messageGo to next message
Stefan wrote on Tue, 06 May 2003 23:15
Yup. No driver though. That was in full street trim (ie: half my wardrobe in the back along with other paraphernalia.
1200 is a good weight for a 1G. 1400 would be pushing it.
CrAiGzEE
south of the big smoke
Re: 1G-GTE Twin Turbo Wed, 07 May 2003 04:17 Go to previous messageGo to next message
a bit off topic, but can you guys drive your car off boost 100% if ya like i know i can but my car only weighs 1007kg with a full tank of juice Razz
Bugman
Re: 1G-GTE Twin Turbo Wed, 07 May 2003 06:40 Go to previous messageGo to next message
yeah I sometimes.. hahaa.. get to work in the morning without coming on boost, often the mornings I wake up at work and try to work out how I got here.
Nark
Cabramatta, NSW
icon10.gif  Re: 1G-GTE Twin Turbo Wed, 07 May 2003 06:55 Go to previous messageGo to next message
Every day for me!
I live about 2-3km from work... Very Happy
wilbo666
Re: 1G-GTE Twin Turbo Wed, 07 May 2003 08:46 Go to previous messageGo to next message
The GX60 looks pretty well like a MX62 Cressida Very Happy
Hmm, an MX62 crossmember makes a 7M-GTE an easy proposition....
BTW te manual states the "kerb weight" as 1250kgs, so in that case would a 7M-GTE Cressida beat the pants off a 7M-GTE MA61? Or do they need to add fuel, a diff and a motor into the kerb weight (is a MX62 / GA60 porkier than that? Sounds a bit too light to me).
[Updated on: Wed, 07 May 2003 08:51]
Bugman
Re: 1G-GTE Twin Turbo Wed, 07 May 2003 12:11 Go to previous messageGo to next message
well I go from sutherland shire to the city everyday..
man it's gunna be fun tomorrow now that I have another diff in it and I took the muffler off, turbos come on boost even sooner
Nark
Cabramatta, NSW
icon14.gif  Re: 1G-GTE Twin Turbo Wed, 07 May 2003 23:50 Go to previous messageGo to next message
Sweet!! I love the sound of a 1G with no exhaust! Very Happy
I regret not putting a flange in before my muffler. Disgusted
It'd be handy for some late night fun.... Wink
CrAiGzEE
Re: 1G-GTE Twin Turbo Thu, 08 May 2003 02:02 Go to previous messageGo to next message
no exhaust at all straight off turbos
www.users.bigpond.com/digger_aus/1ggte.wmv
dispatcher
Re: 1G-GTE Twin Turbo Thu, 08 May 2003 04:17 Go to previous messageGo to next message
Getleman , here's another question..
currently running a 1G-GEU..Malaysian Weather is sometimes similiar to the Sahara desert..Engine use to Temp High or mid High..got pissed with the Thermostat and removed it. Now Temp is cool-low hot..power has improved and fuel consumption sowewhat improved, When i put in my 1G-GTE, can i get rid of the Thermostat ???...is it safe ?
Re: 1G-GTE Twin Turbo Thu, 08 May 2003 04:21 Go to previous messageGo to next message
Sounds like your thermostat was buggered. The whole point of the thermostat is so the engine quickly heats up before it flows to the radiator.
A properly working thermostat should work as well as not having one and would get up to temperature sooner.
Bugman
Re: 1G-GTE Twin Turbo Thu, 08 May 2003 08:50 Go to previous messageGo to next message
Nark wrote on Thu, 08 May 2003 09:50
yeah I forgot to ask for a pipe and flanges for my cat.. may have to go back and get that made up.
dispatcher
Re: 1G-GTE Twin Turbo Mon, 12 May 2003 10:39 Go to previous messageGo to next message
Does anyone know why the 1G T-Turbo has a mini fan in the top left hand corner for the radiator ??If it doesn't work..is that ok ??
punkdefender
Dandenong/VIC
Re: 1G-GTE Twin Turbo Tue, 13 May 2003 21:52 Go to previous messageGo to next message
I believe that turns on when you have the air con on... So make sure it turns on when the air con is on...
1G-GTEFreAk
Re: 1G-GTE Twin Turbo Wed, 06 August 2003 13:32 Go to previous messageGo to next message
Hey I believe that the 1G-GTE will owrk well in the Cressida,I own a Chaser GX81 and I feel that engine pulling like a train.You just need to get the right amount of boost and fuel and a good set of ad ons
Nark
Cabramatta, NSW
icon2.gif  Re: 1G-GTE Twin Turbo Wed, 06 August 2003 23:36 Go to previous messageGo to next message
How heavy is the GX81?
Cranking up the boost doesn't change its off-boost behaviour (which is why we don't recommend 1G's in heavy cars). You're only on boost a small percentage of the time.
Re: 1G-GTE Twin Turbo Wed, 06 August 2003 23:38 Go to previous messageGo to next message
They weigh 1380kg. When you compare that, its less than current day EVO's and STi's, and properly tuned I'd say its a non-issue.
dispatcher
Re: 1G-GTE Twin Turbo Thu, 07 August 2003 04:30 Go to previous messageGo to next message
Well the Cress GX60 is completed. The 1G is quite a motor, and compared to the body weight (still guessing) it's quite fast. So will upgrade for more power slowly but surely.
Single turbs 1G lags like a cow.
Twins are cool.
CrAiGzEE
Re: 1G-GTE Twin Turbo Thu, 07 August 2003 04:49 Go to previous messageGo to next message
what single turbo were u using?
dispatcher
Re: 1G-GTE Twin Turbo Fri, 08 August 2003 02:50 Go to previous messageGo to next message
Not me my buddies car, hmmmm i can't remember but he and i were not impressed with the single option. But when it did kick in..wooow...
1G-GTEFreAk
Re: 1G-GTE Twin Turbo Fri, 08 August 2003 12:19 Go to previous message
To me the car performs very well when it not doing boost. Just need to get more power out \of the 1G-GTE and I 'm there.
Previous Topic:My ST162 nearly stalls when cold
Next Topic:Need Outer Diameter of Brake Rotor skimmed.!
Current Time: Thu Oct 29 15:01:43 UTC 2026
Total time taken to generate the page: 0.17685914039612 seconds
