Toymods » Tech & Conversions » DIY repairs...for a non-DIYer?
biased99
DIY repairs...for a non-DIYer? Tue, 06 May 2003 05:40 Go to next message
Hmmm...I'm told I need a new (reco'd) steering rack in the KE70 and thought that, while there, it would be a good idea to change out the struts for some better ones I happen to have lying around. (Obviously followed by a wheel alignment!)
So, how hard is this to do, and what tools etc am I likely to need? (Given that I have few! Razz )
If I can get an idea of what's needed first up, then I can decide whether to:
A) attempt it myself "as is"
B) procure the appropriate tools and then attempt it or,
C) (last resort) take it to a $$mechanic$$)
Re: DIY repairs...for a non-DIYer? Tue, 06 May 2003 06:18 Go to previous messageGo to next message
Easy job. The only special tools you might need are a spring compressor and a ball-joint remover if you're changing the ball-joints while you're in there. It helps if you have a workshop manual too.
biased99
Re: DIY repairs...for a non-DIYer? Tue, 06 May 2003 06:39 Go to previous messageGo to next message
Thanks, Norbie!
Helmann
Ipswich
Re: DIY repairs...for a non-DIYer? Tue, 06 May 2003 07:34 Go to previous messageGo to next message
How much do ball joint removers generally go for?
Can u do the ball joints without????
Re: DIY repairs...for a non-DIYer? Tue, 06 May 2003 11:43 Go to previous messageGo to next message
I find 2 pieces of pipe, hammer and a vice works just fine on ball joints Surprised
Re: DIY repairs...for a non-DIYer? Tue, 06 May 2003 23:44 Go to previous messageGo to next message
A ball-joint remover is cheap (ie less than $20) but it can save you a lot of frustration if you have a hard-to-remove ball-joint!
Remedy
Southern Sydney
Re: DIY repairs...for a non-DIYer? Wed, 07 May 2003 00:05 Go to previous message
Is there actually a tool to disassemble ball joints????
I've been using a big arse hammer all these years!
Previous Topic:4a-gze into old cosworth
Next Topic:Toyota Liteace Info??
Current Time: Wed Oct 21 18:59:45 UTC 2026
Total time taken to generate the page: 0.0042030811309814 seconds
