Toymods » Tech & Conversions » Supra 14x7 rims on AE86
4a-c
Sutherland Shire
Supra 14x7 rims on AE86 Tue, 06 May 2003 11:55 Go to next message
Have supra 14x7's on my sprinter. have 195/60 tires. Currently they scrub on the front bumper under load eg. heavy braking and cornering. Car has stock suspension... Is there a cure for this problem? any help appreciated thanks
4a-c
Sutherland Shire
Re: Supra 14x7 rims on AE86 Wed, 07 May 2003 06:12 Go to previous messageGo to next message
bump help please
ae86slaver
Re: Supra 14x7 rims on AE86 Wed, 07 May 2003 07:02 Go to previous messageGo to next message
They are probably too wide, and the profile is fat. A 55 profile would also scrub from experience, and this is with hardened suspension.
Your solution would result in how much is in your pocket, either:
Change the wheels to less wide items such as 6.5, with 50 profile -won't scrub.
Change/harden your suspension (but this still would scrub).
Get your guards rolled (probably not worth it without suspension mods).
Hope it helps!
STR8 2.8
Re: Supra 14x7 rims on AE86 Wed, 07 May 2003 09:31 Go to previous messageGo to next message
just put your old rims back on
they were hot, better grip too
4a-c
Sutherland Shire
Re: Supra 14x7 rims on AE86 Thu, 08 May 2003 05:14 Go to previous messageGo to next message
Audioslaver, it's not the guards it rubs on... just the plastic front bumper. Ive heard changing camber angles helps? can anyone confirm this? Thanks anyway audioslaver
bozwon
nowra
Re: Supra 14x7 rims on AE86 Thu, 08 May 2003 08:53 Go to previous messageGo to next message
if you decide to get rid of the wheels give me a buzz
Classique71
Colac, Victoria
Re: Supra 14x7 rims on AE86 Thu, 08 May 2003 08:57 Go to previous messageGo to next message
Bozwon - i have a set of 14x7 supra mags for sale right now - all restored and polished like new - PM me if your interested
ae86er
Re: Supra 14x7 rims on AE86 Thu, 08 May 2003 09:57 Go to previous messageGo to next message
Try adjusting your caster rods, you can move the wheel back (away from bumper), but be careful it doesnt hit the back of the wheel arch when you move it. You will have to get a wheel alignment after, so probably better to get it done at a supension place. Prob cost you 50 bucks.
I had the opposite problem, the wheels were hitting the back of the wheel arch, and i had to move it towards the bumper.
purpleminiep
Mentone
Re: Supra 14x7 rims on AE86 Fri, 09 May 2003 00:18 Go to previous messageGo to next message
Find a different way Dont adjust the castor rod. By moving the wheel back you will reduce castor which will mean lighter steering and less camber when you are cornering. Sprinters need as much castor as possible.
Brad
4a-c
Sutherland Shire
Re: Supra 14x7 rims on AE86 Fri, 09 May 2003 06:23 Go to previous messageGo to next message
thanks everyone
ae86er
Re: Supra 14x7 rims on AE86 Sat, 10 May 2003 00:58 Go to previous message
True... it worked out ok for me though as I was able to increase my caster.
Couldnt you just shave a bit off the bumper?
Previous Topic:weight difference betweent
Next Topic:22RE engine manuals
Current Time: Fri Nov 20 14:37:15 UTC 2026
Total time taken to generate the page: 0.0059030055999756 seconds
