Toymods » Tech & Conversions » whats the better ECU to run an 18RGEU
Blaze
whats the better ECU to run an 18RGEU Tue, 06 May 2003 20:51 Go to next message
What is the better ECU to use to run an 18rgeu. would I be better of getting a 2tgeu or use a 22re ecu. I can get my hands on either so I need to know what would be the better choice.
Re: whats the better ECU to run an 18RGEU Tue, 06 May 2003 23:35 Go to previous messageGo to next message
Definitely 2T-GEU; it's practically identical to the 18R-GEU ECU so it will be easy to do.
Blaze
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 02:32 Go to previous messageGo to next message
thanks Norbie, I think I'll give the 2tgeu a go.
Jason
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 02:36 Go to previous messageGo to next message
check your pm's Des
Blaze
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 05:58 Go to previous messageGo to next message
guess what, I have an 18rgeu ecu coming. thanks for the help guys.
roger
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 06:08 Go to previous messageGo to next message
Even though you have the ecu now. just some further info.
I belive the 2tg air flow meter is smaller I could be wrong does anyone have the measurements?
So although electrically the 2tg system is almost identical, using an air flow meter from the 2tg on the 18rg could cause some tunning problems that go beyond spring and air bypass adjustments.
If you don't have an airflow meter use the one off a 22re or 2se leaded version. These are the same size and have the same out put according to my measurements.
Blaze
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 07:55 Go to previous messageGo to next message
I have an 18rgeu AFM and one form the Camry 2s-e, they are exactly the same size. Not sure about the spring tension though. i will play with both. thanks for the info though
blackRA28
adelaide
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 08:58 Go to previous messageGo to next message
Just out of interest, what ignitor and coil assembly are u planning to use Blaze?
it has come down to the ignitor in my setup is the only thing stopping the engine from running, as it is not sending the spark signal to the ECU!! im using a bosch aftermarket-type ignitor that came with the complete loom, but i dont know what coil was being used with this in the previous car. We've tried a couple different Coils, no success. the ignitor is not working with the factory 18rge coil so gona try a ignitor/coil pack from a cressida. would've gone the 22re pack but a mate has this spare (5Me? maybe). He seems to think they are almost the same on all the early toyo electric ignition systems, i guess it just doesnt work with a bosch ignitor unless u hae a bosch-type elec. coil.. or the ignitors stuffed.
Anyone had this problem or experiences with the old electric ignition systems on these motors? is the cressida ignitor going to have any drawbacks if it does run the engine?
Cheers!!
Guy
______________________
BlackRA28
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 13:42 Go to previous messageGo to next message
I'm using a 5M-E ignitor on my 18R-GEU and it works fine.
blackRA28
adelaide
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 14:07 Go to previous messageGo to next message
Cheers Norbie thats good to hear, should have it up and running then soon.. Just out of curiousity this time Did you use the 5M-E factory coil aswell? or an item from different model toyo motor?
[Updated on: Wed, 07 May 2003 14:09]
Blaze
Re: whats the better ECU to run an 18RGEU Wed, 07 May 2003 22:22 Go to previous messageGo to next message
Well , I think it is the coil and ignitor from a 21re, it could be from a 22re I will have to have a look today. I think that is the problem with mind too. I just connected up the IG wire to a bunch of negatives to the coil, instead of connectiing it to the negative on the front of the coil. I'm getting spark from the coil and from the distributor though so i think it is all connected up right. I'll go and check. a bit hard not having a car that goes Crying or Very Sad
[Updated on: Wed, 07 May 2003 22:24]
TA22-3SGTE
MACKAY
Re: whats the better ECU to run an 18RGEU Fri, 09 May 2003 11:30 Go to previous message
Ok on the toyota igniters there is a yellow wire this is for the taco signal if you connect the IG wire to this you should get a signal to trigger your ECU .
Trevor
Previous Topic:Suspension/Handling Setup For a TA22
Next Topic:3sg(t)e?
Current Time: Mon Nov 2 06:06:08 UTC 2026
Total time taken to generate the page: 0.11198806762695 seconds
