Toymods » Tech & Conversions » 22RE engine manuals
jish_hemp
icon5.gif  22RE engine manuals Wed, 07 May 2003 12:29 Go to next message
i need help with the 22RE in my 1986 corona csi. i cant get the car manual for this model but i found out there is a 84-85 celica with the 22RE in it. is there a car manual for this model or any sort of manual about this engine.
BansheeBuzz
Gold Coast
Re: 22RE engine manuals Wed, 07 May 2003 12:51 Go to previous messageGo to next message
the 22re efi system from an 86 corona is different to the 22re system in celica.
What probs are you having? i may be able to help
jish_hemp
Re: 22RE engine manuals Wed, 07 May 2003 13:19 Go to previous messageGo to next message
1) if the car has been sitting around for a while (overnight, during work) when i go to start it up it takes a bit for the motor to get started, it just turns over for about 5-10 seconds then starts, but if i the car has been sitting around for about 5mins it starts up first crank of the motor.
2) when the motor is cold the engine tries to run as if it is warm (not choked) idling at 750rpm(which is its warm idling rpm) and strugling then it usually sorts itself out in a couple of minutes, then likes to idle at 900rpm even when its warm(sometimes it idles at 750rpm), im worried that the air/fuel mixture is not right when its cold and warm (like they are swapped around for some reason). Im not quite sure so any help would be greatly appreciated.
Thanks Josh Kemp
BansheeBuzz
Gold Coast
Re: 22RE engine manuals Wed, 07 May 2003 20:38 Go to previous messageGo to next message
where abouts are you from? Possible causes for this are
1 cold start injector and/or its curcuit
2 air bypass valve and/or its curcuit
3 any sensors that control these.
1jdave
Re: 22RE engine manuals Wed, 07 May 2003 20:49 Go to previous messageGo to next message
sounds like the coolant sensor resistance should be 4000 to 7000 ohms at 0 degrees 2000 to 3000 at 20 deg c. yes your efi 22re is the same spec as a celica 22re 1985 vintage.could also be cold start system a gregorys manual and a multimeter will sort these out
BansheeBuzz
Gold Coast
Re: 22RE engine manuals Thu, 08 May 2003 08:36 Go to previous messageGo to next message
1jdave wrote on Thu, 08 May 2003 06:49
This is wrong. They run different efi systems. Let me point out the differences.
the 86 corona has a TCCS system which consists of the following
an o2 sensor
different ecu (3 plugs)
different ignition system(electronic spark timing)
different wiring harness
different tps
84-5 celica has an analog system with following
no o2 sensor
2 plug ecu
vacuum advance distributor(none est)
BansheeBuzz
Gold Coast
Re: 22RE engine manuals Thu, 08 May 2003 09:19 Go to previous messageGo to next message
i forgot 86 corona has knock sensor where the 84-5 celica didn't
Stefan
Hobart, Tas
Re: 22RE engine manuals Fri, 09 May 2003 15:32 Go to previous messageGo to next message
Interesting. I thought it was '87 Coronas that got the TCCS, now I know.
I wonder whether we ever got the early tall-deck 22RE?
BansheeBuzz
Gold Coast
Re: 22RE engine manuals Fri, 09 May 2003 20:55 Go to previous message
stefan - when they changed to unleaded is when they got TCCS and it was 86 that got unleaded. I wrecked an 86 to get the TCCS off it a couple of months ago.
As for the tall and short decks, i think we only got the 1 varient. I have both a 22r-e from a celica and 22r-e from 86 corona(siting on the ground at the yard) and they appear to be the same block and head thou i haven't measured them yet.
Previous Topic:Supra 14x7 rims on AE86
Next Topic:help!!!...oil in turbo piping
Current Time: Fri Nov 20 13:51:56 UTC 2026
Total time taken to generate the page: 0.0050060749053955 seconds
