Toymods » Tech & Conversions » 5SFE Camry clutch pedal throw
halfaf
Brocklehurst
5SFE Camry clutch pedal throw Wed, 07 May 2003 20:31 Go to next message
I have a '96 4 cyl Camry and while the gearbox is easy to use, the clutch pedal is too long to make good gearchanges I find. The old'76 Corona seemed to have at least 3/4 or less throw of the action of this car.
Anyone modified their clutch hydraulics or return spring (if fitted) to shorten the clutch action?
thanx,..Jason
BansheeBuzz
Gold Coast
Re: 5SFE Camry clutch pedal throw Wed, 07 May 2003 20:44 Go to previous messageGo to next message
you do not have to depress the pedal all the way to the floor to shift. When you take off from a stop, the point where the clutch starts to grab is all you need to press the clutch to, to shift.
wagonist
Toymods Club Treasurer
Re: 5SFE Camry clutch pedal throw Wed, 07 May 2003 23:17 Go to previous messageGo to next message
I'm having the same problem on my 96 Caldina. If I don't fully depress the clutch pedal when changing from 2nd to 3rd, there's a nasty noise as my gearbox teeth try to leave their natural environment.
I have changed the clutch to a Celica uprated one, so maybe the clutch spring isn't exactly the same.
Is it possible to put a new longer slave piston or similar to get rid of this problem?
halfaf
Brocklehurst
Re: 5SFE Camry clutch pedal throw Thu, 08 May 2003 07:02 Go to previous message
Yeah, adapting different diameter master hydraulic cylinder (larger diameter= less travel for same amount of work) will do the job, but so would shortening the throw-out fork by remounting the slave a bit closer to the pivot theeby shortening the lever effect and movement,...but all very theoretical and I was hoping someone else may have done the homework for me Smile
Its not a sports car, but even still for a sedan, its just that bit too long.
Jason
Previous Topic:How does a distributor work?
Next Topic:corolla sportivo 'box problem - better 'box to match?
Current Time: Sat Oct 31 19:07:56 UTC 2026
Total time taken to generate the page: 0.068378925323486 seconds
