Toymods » Tech & Conversions » 1G-GTE starts MUAHAHAHAH !!!!!
Les
1G-GTE starts MUAHAHAHAH !!!!! Thu, 08 May 2003 04:18 Go to next message
let me tell what we have touched:
took out injectors to clean
took out fuel tank and put new internal pump .... we noted that fuel is pumping to the fuel railBUT now there is no injector pulse so the car will crank, but not crank over....
with the computer - not touched, and was checked by a shop in parra, and is working fine.
They mentioned that the crank angle sensor may be stuffed. does the 1g have this ? and if so where is it located ?
If you have any idea pleassssssssse help me !!!
Thanks !
[Updated on: Sun, 29 June 2003 09:04]
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 04:25 Go to previous messageGo to next message
The 1G uses a distributor...don't know what they were smoking if they said the CAS is on the blink. Are all the injectors plugged in right?
CrAiGzEE
south of the big smoke
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 04:49 Go to previous messageGo to next message
take ya air filter off and when ya press the afm in can ya hear the fuel run thru the rail???
if not it could be ya earth to ya afm wire 2 i think
this problem had me stumped for ages
sounds like it aint getting fuel somewhere
Les
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 04:52 Go to previous messageGo to next message
the fuel rail is getting fuel... just not getting into the injectors... so u think it could be the grounding of some of the wires ??
arghhhhhhhh
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 04:55 Go to previous messageGo to next message
I think what Craig means is that the fuel pump is working so the fuel rail is full, but the injectors aren't being opened cos its not getting a signal from the AFM.
Les
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 05:13 Go to previous messageGo to next message
nice - i will advise my mate...
its prolly just a loose wire somewhere yeah ?
hope it is nothing major
Les
Re: 1GGTE wont start PLEASE HELP !! Thu, 08 May 2003 11:55 Go to previous messageGo to next message
any more suggestions - still not turning over ..... Sad
Grant
Newcastle, NSW, Australia
Re: 1GGTE wont start PLEASE HELP !! Fri, 09 May 2003 02:51 Go to previous messageGo to next message
1. Does it have spark? No spark = no injector pulse.
2. Make sure the ecu is receiving a cranking signal. (12 volts on STA AND NSW during cranking)
3. If that is all ok get someone with a scope to check both IGf signals back to the ecu. I've had the experience where there was spark BUT one of the confirmation signals droped out due to a faulty ignitor.
gold28
Madrid - Spain
Re: 1GGTE wont start PLEASE HELP !! Fri, 09 May 2003 03:35 Go to previous messageGo to next message
Yup I had the same problem as Grant was mentioning. Only it was a damaged connector to the ignitor.
I have a spare Gen 2 ignitor you can try out if you want. I think the Gen 3's are different.
knackers
berala sydney
Re: 1GGTE wont start PLEASE HELP !! Fri, 09 May 2003 05:46 Go to previous messageGo to next message
hi les
check the wiring loom near the coil its your main feed.
it has about 6 wirers in it and they are in a push pull plug
make sure all the wirers are in there sockets nice and tight.
cya knackers
Les
Re: 1GGTE wont start PLEASE HELP !! Sat, 24 May 2003 05:35 Go to previous messageGo to next message
GRANT - whats your number ? Can I call you to ask for advise ? We've got spark, power to injectors, but no earth signal to open the injectors.
What color are the wires I should be tracing and where to and where from?
We've taken the computer to Petroject and it's ok. So its not a computer problem...
Thanks man !!!
GOLDRA28 - Can I get that ignitor off you to test if it works ?? When are you free so I can get it off you ? If you dont mind.
sideshow
Re: 1GGTE wont start PLEASE HELP !! Sat, 24 May 2003 07:57 Go to previous messageGo to next message
if u still cant get it goin and are willing to pay someone
send me an email on sideshow10@optusnet.com.au
i do mobile work so i can come to u
knackers
berala sydney
Re: 1GGTE wont start PLEASE HELP !! Sat, 24 May 2003 10:28 Go to previous messageGo to next message
hi les
sideshow is your best man he will get it going
and beleave me it won't cost you all that much.
sideshow10@optusnet.com.au So drop him a line.
good luck cya knackers
sideshow
Re: 1GGTE wont start PLEASE HELP !! Sat, 24 May 2003 12:10 Go to previous messageGo to next message
thanks guys for the good rap
slowly i hope to get popular
my business is all registered now
im just waiting for some advertising to happen
ill be doing mobile work so i have little overheads which means i can charge cheaper by the hr
plus remember i only charge a small call out fee compared to say 60 to 100 bucks for a towing fee
so if anyone needs help just email me or pm me
Les
Re: 1GGTE wont start PLEASE HELP !! Sun, 25 May 2003 05:17 Go to previous messageGo to next message
knackers wrote on Sat, 24 May 2003 20:28
hi les
NO worries - i have emailed sideshow and have said that if it does not start within the next 2 weeks or so, hes the man for the job !!
thanks for the help all of ya Cool
Grant
Re: 1GGTE wont start PLEASE HELP !! Sun, 25 May 2003 22:07 Go to previous messageGo to next message
For what it's worth my number is 0409 572904. If you definitely have no injector pulse I suspect a wiring problem or a faulty igniter. It would take less than 10 mins for Jim to test the ignitor signal and probably only an hour or two to trace a wiring fault (depnding on how well it was done in the first place). My advice is spend the relatively small amount of $$$ and get Jim to check it out. You'll only be chasing your tail otherwise.
Les
Re: 1GGTE wont start PLEASE HELP !! Sun, 25 May 2003 23:01 Go to previous messageGo to next message
Thanks Grant for your wise words, will speak to Jim soon to fix up a date.. (hopefully within 2 weeks Jim if you are reading this!)
Thanks guys !!
Les
Re: 1GGTE STARTS NOW Sun, 29 June 2003 08:56 Go to previous messageGo to next message
No idea how happy I am !!!! Laughing Laughing
The new internal VL turbo fuel pump we installed was faulty therefore not enough pressure was going through !!!
Let this be a lesson to all !!!!
JUST BECAUSE IT IS NEW, DOES NOT MEAN IT WON'T BE THE PROBLEM !!!!
Always check what EVERYTHING you touched/changed to solve your problem !
CrAiGzEE
Re: 1G-GTE starts MUAHAHAHAH !!!!! Wed, 02 July 2003 23:02 Go to previous message
nice!! glad to see ya sorted it out
Previous Topic:Subs + '75 TA22 + Fuel Tank
Next Topic:where can i get my cluster re-calibrated
Current Time: Mon Oct 26 13:49:21 UTC 2026
Total time taken to generate the page: 0.0096800327301025 seconds
