Toymods » Tech & Conversions » help!!!...oil in turbo piping
nik3t
perth
icon10.gif  help!!!...oil in turbo piping Thu, 08 May 2003 10:55 Go to next message
can any1 help me out here b4 i take my car to someone.
i have a 3tgteu turbo in my ta22
i noticed oil in the turbo piping when my blow off valve came off. the blow off valve itself was full of oil.... the oil has been leaking from the inlet manifold, then ran through my pipe. i first thought it was the turbo but im 100% that it has come from the manifold..
there is no oil in the air filter..no smoke blowing either..what could it be??? ur help & advice will be much appreciated.
nick
Sprinta
Re: help!!!...oil in turbo piping Thu, 08 May 2003 12:19 Go to previous messageGo to next message
Try an oil/air separator or a catch can (basically same thing)
Im pretty sure it would be the oil coming from your cam cover going into your inlet manifold via the PCV valve breather thing up the top
http://members.iinet.net.au/~alemc/cars/alem/engine2.jpg
Not the best photo but look at the catch can on the left and follow the black hose around and it goes to the cam cover.. This would prevent any oil getting into your inlet. To make it legal all you have to do is run the return pipe to the inlet and wallah Smile
Grega
melbourne.victoria.austra...
Re: help!!!...oil in turbo piping Thu, 08 May 2003 20:25 Go to previous messageGo to next message
thats if its oil surge thats the problem - clean out your plenum and take it for a *steady* drive - don't cane the shit out of it but at least get it on boost for a bit. then see if there is oil in the inlet/plenum -
otherwise your seals in your turbo might be the issue....what sorta condition is the turbo in?
nik3t
perth
icon5.gif  Re: help!!!...oil in turbo piping Fri, 09 May 2003 16:37 Go to previous messageGo to next message
yeah.. i found the prob. took off the piping.....started the bitch and then the turbo spat out oil in my face....
if the turbo is stuffed wouldnt it be blowin smoke?? it still is boosting ok to 10 pounds Rolling Eyes
lvn-ra65c
Wichita, Ks, USA
Re: help!!!...oil in turbo piping Fri, 09 May 2003 19:57 Go to previous message
sounds like what mine was doing. oil in piping but no smoking...
kinda hard to tune with afr when the oil is in the system =/
Previous Topic:22RE engine manuals
Next Topic:22RE on Premium
Current Time: Fri Nov 20 13:13:41 UTC 2026
Total time taken to generate the page: 0.0044059753417969 seconds
