Toymods » Tech & Conversions » Suspension/Handling Setup For a TA22
BOGking
icon5.gif  Suspension/Handling Setup For a TA22 Thu, 08 May 2003 14:27 Go to next message
Hi every1.
i have a stock ta22, and now i am goin to get some Monroe Gt Gas. I am running some 14" rims, and will be runing some 15"s later on. and the widest rims/tires i want to go is 6-6.5".
wat will be a good spring setup for city and suburb roads?
i was thikin to lower the car by 2inchs, so how stiff should i have the springs? ( is there a measurement for stiffness in springs? )
Or will it be wiser just to lower it by 1 inch?
Wat spring brands could i look at? dont really want to get kings and pedders.
Well i am upgrading the suspension, wat urethane bushes kit can i get?
Does any1 know about the arrr... 'Centre Roll Adjustment kit' by centreline???
thanks for any sugestions.
Grega
melbourne.victoria.austra...
Re: Suspension/Handling Setup For a TA22 Thu, 08 May 2003 20:23 Go to previous messageGo to next message
dude, i got a set of monroe gas and kinga's for the ta22. not that they're in yet, but should do fine...
Classique71
Colac, Victoria
Re: Suspension/Handling Setup For a TA22 Fri, 09 May 2003 09:54 Go to previous messageGo to next message
As the other thread said - good swaybars - like the 24mm i had in the front of mine - and the 18 in the rear would be a great addition too
The Strut top adjustors from K-mac are cheaper than the stock rubber ones from toyota - so look at them too
monroe GT's and king springs are a good budget start for your package ..
also make sure to repolace any worn bushes along the way you encounter - but thats obvious - and youll have your ta22 handling those bendies in sweet fashion
PS Greg or Bog - if you want a set of RT132 Corona struts to convert into your ta22's ( bigger brakes )- let me know - i know where theres a very good pair you could pick up - here in town ..
BOGking
Re: Suspension/Handling Setup For a TA22 Fri, 09 May 2003 12:21 Go to previous message
Thanks grega, Thanks again Classique Very Happy
knew i could count on u hahah.
yep still got all the info from that really helpfuly thread.!
yep will look at the sways after the suspensions.
amm but how much should i lower the car by? 2 or 1 inch? and u know how stiff i should hav it?
Previous Topic:electrician to wire 7mgte????
Next Topic:whats the better ECU to run an 18RGEU
Current Time: Mon Nov 2 10:53:15 UTC 2026
Total time taken to generate the page: 0.0062530040740967 seconds
