Toymods » Tech & Conversions » 5ME and 5MGE flywheel diameters? Need new clutch.
SUPRAGTE
North Sydney
5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:24 Go to next message
Guys,
anyone know when size these two engines have as their flywheels?
I know the 5MGE is larger, same as the 7MGE flywheel I'm pretty sure.
Can anyone confirm the sizes? 236mm possibly for the larger? maybe?
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:29 Go to previous messageGo to next message
5ME clutch plate diameter - 225mm
5/7MGE clutch plate diameter - 236 or 240mm
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:37 Go to previous messageGo to next message
5m-e also has a 236mm variant - which is bloody rare, however, in the daikin book atleast, its is the 236mm version that is noted as more common (totally incorrect: 225mm is the most common).
7mge is 240mm (same clutch kit pn# as 2jz-ge)
no idea where the 5mge sits in all of this
ill double check the 'actual' dimension on a 7MGE (w58) flywheel when i get home if you like.
ed
SUPRAGTE
North Sydney
Kewl, thanks for the speedy reply Smile
Can someone confirm if its 236mm or 240mm?
I'm getting a Daikin Xtreme clutch and def don't want to get the wrong one.
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:39 Go to previous messageGo to next message
which flywheel do you have paul?
ed
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:46 Go to previous messageGo to next message
Need to know which flywheel Paul.
Ed, WTF is up with your sig?
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:51 Go to previous messageGo to next message
nothing's up with the sig Rolling Eyes
well, im not 'allowed' to say whats up with the sig
lets just say dorothy's house has landed squarly and heavily on a certain wicked witch, and ive got nothing better to do that sing about it
[Updated on: Fri, 09 May 2003 03:55]
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 03:54 Go to previous messageGo to next message
I've got both flywheels, the 5ME and 5MGE.
I want to go with the 5MGE cause its larger and will effectively give me about 100kg of extra clamping force with the extra 15mm.
See this is the drama I'm having, getting the exact match up to what Daikin have in their catalogue otherwise i'll end up with a useless $400 clutch.
If you could check your 7mge one that would be great Ed.
Wish I had the Daikin book in front of me then I could make a decent guess whilst also looking at the specs of the 7MGE flywheel.
The 5MGE flywheel is currently in the car so it's impossible to measure.
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 04:03 Go to previous messageGo to next message
no worries paul, will let you know tonight.
forget using the 225mm 5me flywheel (der!), theres not much decent (off the shelf) around that will bolt up to it. I got the BEST daikin exeedy HHD kit, and i doubt it'd hold your engine.
i cant recall whether the 5mge and the 7mge share the same dimensions, i used to know, but that info has left my brain. fwiw, once you get to 240mm most places can start making custom clutch plates, ie half organic, half ceramic or brass etc. and you can just buy the HHD pressure plates alone from daikin - you dont have to buy the whole kit.
my recommendation - talk to 'specialized brake and clutch' in st mary's (youll have to find the number - theyre on glossop st) daikin's tech team in victoria recommends them as the BEST place for info, custom assemblies and modifications. even if you dont buy there, they'll sort out all the pn# you need, and what fits, what combo etc etc
ed
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 04:17 Go to previous messageGo to next message
Definitely don't waste your time with the 5ME gear. I made a custom flywheel and used a 4 puck ceramic clutch plate and heavy duty pressure plate (all stuff I had for the M engines I ran) behind the 2JZGE and it's slip city. I don't even want to think what it would do behind your engine (probably twice as powerful as mine).
I strongly urge you to use the larger stuff. There is just better, heavier duty stuff around.
[Updated on: Fri, 09 May 2003 04:20]
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 04:45 Go to previous messageGo to next message
Yep, i decided to go the larger when I dropped the engine into the new car cause I new i'd be putting out more torque with the new setup.
I've been going to Western Clutches for years now and have their Extra Heavy Duty pressure plate but it is now slipping. They are very helpful with using their machines and refacing gear out there, gotta hand it to them Smile
But now I am out of options and am going to a Daikin Xtreme setup which is their new track/drag cltuches and should sort my issues out before next dyno day.
Just been on the phone to Ray and we both reckon that the 5MGE flywheel has to be the same as the 7MGE one as there is absolutley no way they could fit any more clutch face material on the outside of the flywheel or else the starter wouldn't be grabbing the ringgear properly. Same goes for the inside, there wouldn't be enought room for the flywheel bolts on the inside so 5MGE must be the same as 7MGE.
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 04:58 Go to previous messageGo to next message
For what it's worth, the width of material on the 5ME clutch plate is 40mm, whilst for the 7MGE it is 44mm.
BlackSupra
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 11:40 Go to previous messageGo to next message
Out of interest at what boost pressure does the clutch start to slip?
With a standard 7mge clutch and standard 7mgte, will this work with a w58 or be slip city?
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 09 May 2003 12:15 Go to previous messageGo to next message
At around 10psi it begins to slip big time.
A 7mge pressure plate will work with fine with a stock but boosted(12psi) 7mgte, that's what the guys in the US run.
Ray's has got a that pressure plate we're pretty sure and his isn't slipping at 12psi.
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Mon, 12 May 2003 13:01 Go to previous messageGo to next message
Guys, for your information the 7MGE and 5MGE clutch diameter are the same and that is 236mm.
Am going to a Daikin clutch dealer tommorow arvo to see what's available.
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Wed, 14 May 2003 06:12 Go to previous messageGo to next message
Paul,
my 7mge flywheel has a clutch plate surface of 240mm dia. the wear mark extends right out to the 240mm limit. perhaps it had a non standard clutch plate on it?
anway, obviously something bigger than 236mm was fitted to it, so you may be able to find something similar.
ed
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Wed, 14 May 2003 09:06 Go to previous messageGo to next message
Cheers Ed,
the plot thickens. Disregard my comment earlier that 7mge clutches must be 236mm, I'm wrong there and as you measured yours Ed that confirms it.
I had a look at a daikin catalogue myself for the first time today at a parts shop to try and sort it out. The book has 225mm,236mm and 240mm flywheel listings.
The 240mm is listed as being on the 7mge, it would be 2mm either side bigger than the 236mm one and most likely the same flywheel just the surface is used right to the edge as Ed says.
Think i'll unbolt the gearbox, remove the clutch and take it all out to Western Clutches to sort it out.
askkenny
Parkland, Washington,USA
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 16 May 2003 05:16 Go to previous messageGo to next message
I hope I'm in time to prevent you from removing the flywheel. Having just scored mucho literature on ebay for the 5mge I am now prepared to answer most of my own questions. As to yours, one of my new treasures reveals that the 5mge and 7mge parts numbers are both 1340549175. Interestingly, the 86 Cressida/Supra 7mge and the 83 Supra 5mge share the same disc and pressure plate numbers. As to the dimensions, Sachs site says that the measurement is 225 for the 5mge and 7mge non-turbo and 240 for the turbo. Good luck.
ed_ma61
Lost in the K hole
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 16 May 2003 12:16 Go to previous messageGo to next message
askkenny wrote on Fri, 16 May 2003 15:16
yes, you can simply use the same parts numbers and buy a clutch off the shelf, and it will fit. this is the 'easy way' so to speak, but when youre out looking for the best clutch for an application, it can get waayyyy more complicated than that... read below...
this is a perfect example of where, if you bought the catalogue part, sure it'd fit, but it ISNT the best solution. the 5me should be the ONLY late model m engine which should run a 225mm clutch. sure, itll fit other engines, but i can most definiely assure you the 7m runs ATLEAST a 236mm clutch, and can run up to 240mm. this is where you need to pull the thing out, go to a clutch place, and say - here, find one to fit.
NEVER belive everything you read... it can be so so wrong
ed
askkenny
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Fri, 16 May 2003 19:15 Go to previous messageGo to next message
I have to admit as I read your advice that it applies so well. So far the Mitchell service CDs, Toyota CDs and the Toyota factory microfiches,the 1985 Supra manual, the Supra Body repair manual and with factory sales and production numbers I've been getting in the mail make it seem like a Supra information feast to me. Ebay is a great source Supra information that you pay for. I really got a bargain having spent less than fifty dollars US for the above mentioned items. As for free infomation, you get what you pay for.
SUPRAGTE
North Sydney
Re: 5ME and 5MGE flywheel diameters? Need new clutch. Sat, 17 May 2003 01:47 Go to previous message
I wish toyot came out with a manual for dropping a 7MGTE into an MA61 with T04E turbs, HKS manifold and wastegate pumping out 420hp with a special section on upgradeing your clutch. Smile
As soon as you get decent power alot of things standard can't keep up. You gotts look outside the normal otherwise just drive a normal, but who wants that.
Previous Topic:ke35 corolla paddock basher power up????
Next Topic:engineering an engine conversion.
Current Time: Sat Nov 21 21:47:50 UTC 2026
Total time taken to generate the page: 0.0075311660766602 seconds
