Toymods » Tech & Conversions » Will this work?
Hirogen
Melbourne, Australia
      WTF is a jabber?
icon5.gif  Will this work? Fri, 09 May 2003 13:23 Go to next message
Ok, i have 2 4AGE's. 1, is a 7 rib deal from an AW11 that runs an AFM. The other, RWD map version. Now, i want to use the inlet, wiring and ecu from the RWD, on the 7 rib one. Will said thingy work? am I just playing with myself? Any other ideas if this wont work.
Ps, i have the complete wiring and ecu from both engines if that helps.
sideshow
Re: Will this work? Fri, 09 May 2003 13:40 Go to previous messageGo to next message
i presume u r goin to run it in a rwd
cause the manifold would face wrong way in a fwd
i recently wired up a 4ag fwd with modified manifold to fit in a sprinter
was abit of muckij round gettin corr3ect alternator brackets and make water pipes to fit the rwd
u also need the correct water pump and outlet otherwise the outlet hits alternator
i cant remember whats diff on the water pump but i had to change it too
Hirogen
      WTF is a jabber?
Re: Will this work? Fri, 09 May 2003 13:47 Go to previous messageGo to next message
Aside from the physical deals, will the engine run on the other wiring and ecu? all other problems can be fixed with a bit of mucking around I figure.
sideshow
Re: Will this work? Fri, 09 May 2003 14:05 Go to previous message
just be careful which harness and ecu u get
i ran into the prob where the harness was a fwd 86kw and the ecu and engine was a 100kw so i had to change the ecu plugs over and the injector plugs over
plus the injectors in an 86kw run a droppin resistor i think
but if the ecu matches the harness and also matches the injectors u should be right
Previous Topic:22RE on Premium
Next Topic:need to find fuel pump
Current Time: Fri Nov 20 13:14:07 UTC 2026
Total time taken to generate the page: 0.015552997589111 seconds
