Toymods » Tech & Conversions » 4AGZE and thermostat location
EVOSTi
cambo
      no
4AGZE and thermostat location Sun, 11 May 2003 11:18 Go to next message
my 4AGZE wasnt running a thermostat when i got it, so i bought one to put in then i started wondering where it went? does it go into the water pipe that comes from the block behind the supercharger? would be a pain but i figure i better put it in cause i dont want to be runnign round with the engine cold all the time even tho the previous owner had been but i would suspect this would shorten engine life especially with higher revs and also wouldnt be good for fuel consumption either.
maybe somehow i can get some flanges and mount it in the top raiator hose not that there much room.
thanks.
Jonoze
Re: 4AGZE and thermostat location Mon, 12 May 2003 04:56 Go to previous messageGo to next message
GZE's run a remote thermostat. In the fwd layout its located on a housing which is bolted to the top of the gearbox. (same as the fwd ge setup.)
I'm pretty sure you could just use a ge setup if you wanted.
EVOSTi
cambo
      no
Re: 4AGZE and thermostat location Mon, 12 May 2003 06:11 Go to previous messageGo to next message
thanks mate, i thought that may be the case cause i couldnt see where it could possibly go.
so a normal ge from an sx runs a remote thermostat aswell? if so my problem is solved.only thing is theres about 10cm of hose between the radiator and the head (in a sprinter). and i woud think mounting it in the bottom hose would take longer to warm up also.
Jonoze
Re: 4AGZE and thermostat location Mon, 12 May 2003 06:17 Go to previous messageGo to next message
I think you'll find that the ge thermostat is on the bottom hose.
Thats how mine is setup...and yes it does take a while to warm up.
EVOSTi
cambo
      no
Re: 4AGZE and thermostat location Mon, 12 May 2003 11:16 Go to previous messageGo to next message
that sux cause my car cant idle when cold only when warm ATM. i could always try to to make it go into the top one if i can make the space. time to visit the wreckers i think.
Re: 4AGZE and thermostat location Mon, 12 May 2003 13:08 Go to previous messageGo to next message
Mines in the bottom hose, and it warms up just fine... I just used the GZE thermostat housing in line in the hose.
EVOSTi
cambo
      no
Re: 4AGZE and thermostat location Tue, 13 May 2003 07:41 Go to previous messageGo to next message
thats all well and good if you got it Smile
i went to the wreckers today and checked out the thermostat housing on 100kw GE and i dont think i can use it. its rather large with pipes coming of it in all directions rather than being just a straight bit of pipe with flanges.
so if anyone has some gze thermostat flanges let me know Sad
Jonoze
Re: 4AGZE and thermostat location Wed, 14 May 2003 03:01 Go to previous message
Thats what the gze ones look like. The main inlet and outlet are at an angle of about 45 degrees to each other. I think the only difference is the location of the heater hose which comes out the top of the housing on the ge, but on the gze it is sorta parallel with the main inlet.
Previous Topic:what to do with a v8 lexus
Next Topic:compressor for ae86
Current Time: Sat Oct 24 01:39:50 UTC 2026
Total time taken to generate the page: 0.0053279399871826 seconds
