Toymods » Tech & Conversions » 4ageRWD manifold on 4agz??
JDM hachi
was adelaide now newcastle
4ageRWD manifold on 4agz?? Mon, 12 May 2003 02:49 Go to next message
ok i know the difference between the small port and the big port head, but what i need to know is will the RWD manifold work on the small port head,ie bolt up, it doesn't need to work that well just allow the car to run, i have a good reason for wanting to do this- ie sidestepping the requirement for engineering of a gze into my import 86, they want to see the engine number so turning the gze into a ge will then allow me to give them what they want.
also, does any one know if any other headaches will arise from this i assume that the throttle body bolt pattern may be different ,etc....
thanks.
matty.
pepsicola
Re: 4ageRWD manifold on 4agz?? Mon, 12 May 2003 07:14 Go to previous messageGo to next message
u can't use big port intake on a small port head.intake port diameter is different, and i think bolt pattern is different. better off just bolt a big port head on. or if u can find it, i think the 1st gen 4agze in a MR2 is big port. Very Happy
there's also problem when u bolting a big port head to a small port block. i am assume u using small port ECU, so u have to disable the TVIS, trigger it to open all the time.
oh, and...check your pm. it's about the 4 spot brake again. Razz
[Updated on: Mon, 12 May 2003 07:56]
Re: 4ageRWD manifold on 4agz?? Mon, 12 May 2003 07:55 Go to previous messageGo to next message
The bolt patterns are the same, the bigport manifold will bolt up to the head and all will look lovely, but you'll be buggered if you can get it to start Very Happy
pepsicola
Re: 4ageRWD manifold on 4agz?? Mon, 12 May 2003 07:58 Go to previous messageGo to next message
Roll it down a hill with the engine off, see if there's something going *crunch* - although a little feeling should tell you if it
pepsicola
Re: 4ageRWD manifold on 4agz?? Tue, 13 May 2003 06:33 Go to previous messageGo to next message
? Shocked ? Shocked ? Shocked ? Shocked ? Shocked ?
what happen?I didn't write the above post.
what I wrote was "i wonder what will happen if u start it"...
Dodgy_Haro
Re: 4ageRWD manifold on 4agz?? Tue, 13 May 2003 07:31 Go to previous messageGo to next message
Heh heh ... it appears your Toymods password has filtered off into the public domain Pepsi ... Laughing Evil or Very Mad Laughing
pepsicola
Re: 4ageRWD manifold on 4agz?? Tue, 13 May 2003 09:40 Go to previous message
I thought so, but it can't be.
coz that post hasn't been modified, like the previous one I did.
It hasn't got a marked update date on it.
Previous Topic:Fuel Injector Cleaning
Next Topic:removing glass off AE82/86 headlight?
Current Time: Mon Oct 19 18:05:30 UTC 2026
Total time taken to generate the page: 0.0053420066833496 seconds
