Toymods » Tech & Conversions » Mazda 4 piston brakes on AE86?
hinricp
Mazda 4 piston brakes on AE86? Mon, 12 May 2003 02:55 Go to next message
have seen this conversion but does anyone know what is involved, i.e. what disc, caliper mounting etc?
Thank you
EVOSTi
cambo
      no
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 06:13 Go to previous messageGo to next message
dont bother with the S4 setup, do the hilux 4 piston upgrade. i got my photos developed and the article will be available in the next few days.
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 07:49 Go to previous messageGo to next message
I'm using Mazda 4 potters on mine, I can find/send you some photos later tonight if you like. Personally I'd use the Mazda ones over Hilux ones to save weight - if you want more braking capacity, use Nissan 4 potters.
gabe
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 09:43 Go to previous messageGo to next message
mrshin,
what rotors are you using??
and what modifications (ie machining) did you have to do to make them fit??
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 10:16 Go to previous messageGo to next message
I think I did a post on this a while ago... I'll add the pictures and write something about it later tonight.
EVOSTi
cambo
      no
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 11:13 Go to previous messageGo to next message
i have no doubt the mazda one would be better, but only if you got the money i am a mad tight ass so the hilux ones were the go.
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 12:28 Go to previous messageGo to next message
I only used the Mazda ones because I got them at a near giveaway price Very Happy And I also scored several sets of Nissan ones at an even less credible price, and yes they're well claimed!
Ahh crap, HOW does one attach pictures to their messages?
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 12:29 Go to previous messageGo to next message
You need to have the hosted somewhere first of all! If you cant do this just email them to me!
Re: Mazda 4 piston brakes on AE86? Mon, 12 May 2003 23:51 Go to previous messageGo to next message
Yeah, I'll send it to you tonight, my FTP doesn't want to be nice and do what I want it to!
DJ345
eastern suburbs, Melb
Re: Mazda 4 piston brakes on AE86? Tue, 13 May 2003 06:36 Go to previous messageGo to next message
mrshin can you please send me some photos of the mazda 4 spot conversion too.
Thanks Damian.
[Updated on: Tue, 13 May 2003 06:37]
gabe
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 01:34 Go to previous messageGo to next message
sorry to be a pain but could i get those pictures also mrshin?? Smile
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 05:03 Go to previous messageGo to next message
Sorry guys... Finally got the FTP going, then couldn't get onto the site last night.
http://members.austarmetro.com.au/~mrshin/brakes1. jpg
http://members.austarmetro.com.au/~mrshin/brakes2. jpg
http://members.austarmetro.com.au/~mrshin/brakes3. jpg
I'll write something about it later tonight. Evil or Very Mad
1G-GE KE35
Welly, NZ
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 05:09 Go to previous messageGo to next message
Looks good Very Happy
What discs are you using?
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 14:17 Go to previous messageGo to next message
Rotors are V8 Crown (UZS13x)
Struts are xA6x celica, because they were already on the car and have a fatter stub axle - could PROBABLY work with AE86 ones, haven't had a chance to check. The celica ones bugger up the camber, (MA61 ones would be even worse), using strut tops the best I've got so far is zero camber, need to play with lower arms more to get proper neg camber
Hubs are machined several MM off on the back to accomodate the offset of the rotors
Rotors have had the holes filled and new ones drilled to suit the 4 studs instead of 5
Calipers are RX7 4 potters, attached with a piece of 5/8" plate drilled and tapped (look at the picture)
Tryna think what else needs to be mentioned!
E30-323ti
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 20:18 Go to previous messageGo to next message
Looks good.
What Dia are those discs? I guess they are 22mm thick to go with the calipers.
What are the spacers under the strut for?
Re: Mazda 4 piston brakes on AE86? Wed, 14 May 2003 22:42 Go to previous messageGo to next message
Discs are 280mm - not huge, but big enough for most purposes. I'm using them 24mm thick, the most the calipers will put up with.
Spacers under the strut are roll centre adjusters - to be honest, I'm not entirely convinced of their greatness, must experiment a bit more to see I spose!
Re: Mazda 4 piston brakes on AE86? Wed, 27 August 2003 02:48 Go to previous messageGo to next message
Anyone know how hard it would be to fit these calipers onto a XT130 strut, or RA28 strut?
I'm looking at scrapping the hilux calipers for a more light weight setup such as the mazda calipers.
Joel
coronamark2
Re: Mazda 4 piston brakes on AE86? Wed, 27 August 2003 03:41 Go to previous messageGo to next message
what upgrade could i do on a corona mark2 would them V8 crown ones fit?
I want some cross drilled rotors and good looking/working calipers.
any suggestions?
roger
Re: Mazda 4 piston brakes on AE86? Wed, 27 August 2003 03:47 Go to previous messageGo to next message
mr shin cna you measure the bolt spacing i think the hilux ones are 90mm
Re: Mazda 4 piston brakes on AE86? Wed, 27 August 2003 04:05 Go to previous messageGo to next message
Yeah hilux are 90mm.
I remember awhile ago someone on here put up the diagrams and everything for the plates but I cannot find anywhere!
Henn
Rosanna, Melb
Re: Mazda 4 piston brakes on AE86? Fri, 29 August 2003 08:12 Go to previous message
You can get the RX7 calipers onto an AE86 using an adaptor plate and 180SX rotors. I have written about this before.
Apparently RA40 strut legs are identical to AE86s, apart from the stub axle which is fatter and has a better caliper mounting arrangement, and the spring platform, which can be turned off and replaced with the sprinter one. Inserts will allegedly swap straight over and height/camber is not a problem.
So using RA40 strut leg, AE86 spring and upper, custom adaptor plate, RX7 calipers and finding a suitable disc from the DBA catalog seems to me like a good plan. Not cheap, but good.
Hen
RX7 caliper mount spacing is 158 mm centre to centre
Previous Topic:1JZ inlet manifold.. crack or casting mark?
Next Topic:Who here has Koni Adjustables ( dial type)
Current Time: Sat Oct 24 09:58:25 UTC 2026
Total time taken to generate the page: 0.0061020851135254 seconds
