Toymods » Tech & Conversions » Starting 1G after long time
icon5.gif  Starting 1G after long time Mon, 12 May 2003 05:05 Go to next message
Okie doke. I'm just doing some research now. Should hopefully be in the uni break in a month or two when I finally get the 1GGTEU into the car. I know for a fact, I've had the engine sitting there for a good few months, and it was sitting at Japanese Motorsport for probably about 6 months before that. Add the time spent in Japan and you can see it has been sitting for a long time!
I'm going to replace the cam seals, the front and rear main seals as well as the timing belt.
I've been told by someone to pull the plugs out and check them for oil. They also told me to squirt a bit of oil into the sides of the cylinders and slowly turn the crank to circulate it around. Then while I'm slowly cranking it get someone to place their hand over the hole to see if they can feel the sucking on their hand.
Also, what should I be doing to check the turbos are fine?
Is there anything else I should be doing before I fire the engine up?
Any info would be great!
Thanks,
Nathan
toycelica77
bris
Re: Starting 1G after long time Mon, 12 May 2003 05:27 Go to previous message
i know on carbied engines you take out the spark plugs and crank the engine from the starter for a few turns until oil pressure is registered and the little oil lights goes out then you start and let it idle for a while...
not sure for EFI engine, but i'd say its close to that
basically follow the engine wear in procedure to get it running (obviously not all of it if you havent rebuilt it)
Previous Topic:cd player repairs
Next Topic:ta22/23 specs
Current Time: Fri Nov 20 22:04:40 UTC 2026
Total time taken to generate the page: 0.0052590370178223 seconds
