Toymods » Tech & Conversions » IAC on a 1UZ
SupraPete
IAC on a 1UZ Mon, 12 May 2003 09:55 Go to next message
I'm trying to put my Idle Air Controller back on but I need to know where the air hose goes into. I know its the fat hose on the IAC but I don't know where it is plugged in.
I'm not using the standard intake hose.
Manny
Re: IAC on a 1UZ Mon, 12 May 2003 10:01 Go to previous messageGo to next message
Pete
Try http://geocities.com/deonsv8hilux/
Re: IAC on a 1UZ Mon, 12 May 2003 10:15 Go to previous messageGo to next message
Just make sure it's connected anywhere between the throttle and the air flow meter - have a think about it and all will become clear. Any air that goes in there has to go through the AFM, and do so before the throttle... Very Happy
SupraPete
Re: IAC on a 1UZ Mon, 12 May 2003 23:27 Go to previous messageGo to next message
Havn't got an AFM Wink
SupraPete
Re: IAC on a 1UZ Mon, 12 May 2003 23:38 Go to previous messageGo to next message
There are some great pics of the IAC on this thread
http://www.toymods.org.au/msgboard/index.php?t=msg &th=13603&rid=777&S=98e08c2dd9d822f135 390c93b282ec87
definately goes in the intake pipe - after the AFM, before the throttle.
Next question:
Running a MAP sensor can I put a small aircleaner on the end of the pipe instead of plugging it into my intake pipe?
It does sound dodgy. I'll find out how hard it'll be to make a new hole in my intake pipe etc.
Re: IAC on a 1UZ Mon, 12 May 2003 23:44 Go to previous message
If there's no AFM, there's no real reason why you can't just stuff a small filter on the end of the valve - presuming you're not using a turbo or anything of course! The little filters they sell at gasresearch for the end of blow of valves would probably do the trick, should be reasonably cheap from any larger LPG conversion place.
Previous Topic:Swapping from carby to injected
Next Topic:RA40 struts in a 22?
Current Time: Sat Oct 31 13:02:52 UTC 2026
Total time taken to generate the page: 0.060947895050049 seconds
