Classifieds » Parts Wanted » WTB: 1jz air con pump and pulley
Chris Davey
sunny coast, qld
WTB: 1jz air con pump and pulley Wed, 14 May 2003 05:02 Go to next message
anyone have one of these? the previous owner took mine off because it will have no air con but i need it otherwise there will be no tention on the belt Sad
anyone in brisbane area preferrably.
thanks in advance
chris
jezzamoreton@hotmail.com
0404029203
Re: WTB: 1jz air con pump and pulley Wed, 14 May 2003 08:22 Go to previous messageGo to next message
Get a shorter belt!
ChuckLandwehr
Re: WTB: 1jz air con pump and pulley Wed, 14 May 2003 09:59 Go to previous messageGo to next message
Hey there matey, yes I have an aircon compressor for a 1J yours for $60.00
Regards Chuck
BansheeBuzz
Gold Coast
Re: WTB: 1jz air con pump and pulley Wed, 14 May 2003 10:39 Go to previous messageGo to next message
i have 1 off a 1jz $50 im on the gold coast too!!
Pete
gold coast
Re: WTB: 1jz air con pump and pulley Wed, 14 May 2003 11:17 Go to previous messageGo to next message
As GT say's, get a shorter belt. I run A/C but no P/S. My alternator sits where my P/s pump was originally and my A/c is rotated downwards and the mounts cut and welded.
Works a treat. You are going to put 5 or 6 kilos over the front wheels for nothing??
If you do make sure you gut the pump, the bearing for the front pulley runs on a machined boss on the front of the pump. Therefore there is no use fo all the rods/pistons and cams in the pump.
If it is not sealed it will seaze up after a while anyway.
BansheeBuzz
Gold Coast
Re: WTB: 1jz air con pump and pulley Wed, 14 May 2003 11:25 Go to previous messageGo to next message
it doesn't mater if the compressor itself is seized just as long as the idle bearing isn't siezed. The idle bearing on a compressor can be easily replaced too.
You can strip the internals to save weight if you really wanted too. The extra weight will really do nothing to your car handeling or performance wise.
Re: WTB: 1jz air con pump and pulley Thu, 15 May 2003 12:06 Go to previous messageGo to next message
BansheeBuzz wrote on Wed, 14 May 2003 21:25
Sure. Just that you don't actually need it to act as a pulley wheel at all, unless of course you one day intend to run A/C.
I am running PS and NO A/C pump on my 2JZGE (I'd imagine the pulley locations are similar on a 1J). I needed to make a spacer that was essentially a 25mm long piece of steel pipe to fit where the A/C pump would have sat. I ended up using a 6PK1860 (original 6PK1940 I think) belt but I'd recommend the 1840.
It's just one less thing to clutter up your engine bay. Up to you, of course.
Chris Davey
sunny coast, qld
Re: WTB: 1jz air con pump and pulley Fri, 16 May 2003 12:06 Go to previous messageGo to next message
ok, my mechanic said he could either make a bracket up and change some shit (can't remember exactly) or he said it would be easier to fit a PS pump because there would be no tention on the main 'thingy' in the middle that pivots. i can try and get a pic to show what i mean if it would help?
thanks for the input
BansheeBuzz
Gold Coast
Re: WTB: 1jz air con pump and pulley Fri, 16 May 2003 19:28 Go to previous messageGo to next message
where abouts in bris are you?
Chris Davey
sunny coast, qld
Re: WTB: 1jz air con pump and pulley Sun, 18 May 2003 02:49 Go to previous messageGo to next message
i am actually on the sunshine coast.
hmm i am going to my mechanics today, so i will ask him what he thinks and then if i want your a/c pump if will tell you. ok?
later
chris
Chris Davey
sunny coast, qld
Re: WTB: 1jz air con pump and pulley Wed, 21 May 2003 01:41 Go to previous message
just letting you guys know that i don't need the pump as i am moving my alternator.
thanks anyway
Previous Topic:WTB - TPS + other 4AGE stuff
Next Topic:WTB: T50 Gearbox...or any other gear box to fix AE86
Current Time: Sat Nov 21 11:34:27 UTC 2026
Total time taken to generate the page: 0.0087580680847168 seconds
