Toymods » Tech & Conversions » 18RG tuning problems
Mr DOHC
18RG tuning problems Wed, 14 May 2003 11:04 Go to next message
on my 18RGU with newly rebuilt and tuned carbs, i have a miss under accel, doesn't matter what revs, i can be cruising down the h'way at 3500 rpm, if i accel a small amount it'll bog down and lose 5 k and slowly pick up speed, if i blip the throttle its cool,
dunno, maybe the fuel levels have to come up in the bowl Confused Confused Confused Confused Confused
if i'm cruising at 60k it'll do it, so i cant slowly accel i have to blip it and then accel
Razz Razz
HELP
btw: the rebuild was professional
BansheeBuzz
Gold Coast
Re: 18RG tuning problems Wed, 14 May 2003 11:14 Go to previous messageGo to next message
If the rebuild and tune was profesional take it back to em and get them to retune it. Sounds like its got the wrong size jets.
[Updated on: Wed, 14 May 2003 11:14]
celicaboy
Re: 18RG tuning problems Wed, 14 May 2003 11:41 Go to previous messageGo to next message
where did you get your webebrs tuned at in brisbane? i need mine tuned as well... mine gives out godo torque and good on excellleration but it will run rough when it idles at the speed you are going... it also idles on stand still really lumpy.. i am suspecting the 2nd carb is way out fo tune or is on its way.... so i wanna tune it and see what happends... the front one i got right but i just cant seem to get the second one right. so yeah i was wondering where you got your carbs tuned at and at what price? they are the solex type you have eh?
TurboRG
Nor Calif USA
Re: 18RG tuning problems Wed, 14 May 2003 14:51 Go to previous messageGo to next message
Or you can have a jet loose.
Mr DOHC
Re: 18RG tuning problems Thu, 15 May 2003 08:00 Go to previous messageGo to next message
i got Autocarbs in wooloongabba to do it, he charged $500
Re: 18RG tuning problems Thu, 15 May 2003 13:13 Go to previous messageGo to next message
$500 for a carby tune and it still runs like crap?? Take it back and demand he do it properly!
earlyrolla
Re: 18RG tuning problems Fri, 16 May 2003 12:40 Go to previous messageGo to next message
The basic kit for the solex (weber look-alike) is around $100 per carb. $500 for both might be a little steep, depending on the work done. If you have the money then take it to someone with a dyno and knows what that are doing.
I have heard of a guy here in Perth (I am sure there is someone in Brisbane who does the same), that actually solders up the jets then re-drills them to suit. All the work is performed with the car on a dyno and with a gas analyser. The work was done on a mates rally car and he could not speak highly enough about the results.
Mr DOHC
Re: 18RG tuning problems Sat, 17 May 2003 13:00 Go to previous messageGo to next message
i'm taking the car back to him this wednesday, $500 was for r&r the carbs rebuild them, supply air cleaner skeleton and do the linkages, the job he did was brilliant, but he thought the missing was my leads {OLD}, i got new ones and i got platinum plugs, but it's still there, not nearly as bad tho, but none-the-less it's going back
people100
Rocklea qld
Re: 18RG tuning problems Sun, 18 May 2003 12:04 Go to previous messageGo to next message
I had an 18rgu engine in my 78 corona. I tuned it myself and it rab fibe except for a slight miss. Turns out the prob was my brake booster because the booster house connects onto the intake manifold anear number 3 piston. i got new booster and retuned my carbs and it was fine. PS how much and where did u get the engine rebuilt. Laughing
earlyrolla
Re: 18RG tuning problems Mon, 19 May 2003 03:18 Go to previous messageGo to next message
I have the same 'flat spot' in my 18RG, never had the spare money to actually have it fixed. I put a vacuum gauge on the engine to monitor what goes on (what causes the problem). When you first open the throttle from cruise, there is a sudden drop in manifold vacuum. This is a result of a low volume intake manifold and four rather large throttle plates. This drop in vacuum results in slower air flow through the carbs. (I know the accelerator pump plunger pushes in fuel as the accelerator is depressed.) The result is a 'flat spot' until the engine picks up revs. Depressing the clutch and giving it a 'blip' will over come the problem as the engine is able to rev up quicker when the clutch is in.
I have kinda got used to it and just drive around it. I am sure that it could be fixed with a bit of time and effort and someone who knows what they are doing with the carbs.
Interesting to see how many other 18RG drivers experience anything like this too.
Cheers all.
celicaboy
Re: 18RG tuning problems Mon, 19 May 2003 08:03 Go to previous message
you might have a tiny bit to smaller jets in it... my 18rg dont do it at all when i eccelerate liek that i dont really have a problem with my solex's at all they run a lil rich but i tuned it a lil bit more and it got a more even air/ fuel mixture you just gotta spend the time on it and make sure the jets are right i guess
Previous Topic:Celica gearbox pleeeeze help
Next Topic:BOV'S which one 4 me??
Current Time: Sat Oct 24 16:07:30 UTC 2026
Total time taken to generate the page: 0.0060780048370361 seconds
