Toymods » Tech & Conversions » 1JZ Variants
fingers
Darwin
1JZ Variants Fri, 16 May 2003 03:00 Go to next message
Different types and their native homes etc. I see JZX81 and JZX90 being thrown around alot but don't really know the differences.
Have searched the tech and conversions but there is a lot to sift through. Any links and general info would be appreciated.
Thanks in advance.
Fingers
Re: 1JZ Variants Fri, 16 May 2003 03:49 Go to previous messageGo to next message
JZX81 and JZX90 are chassis codes, ie they apply to a car, not an engine. AFAIK there were no major differences between 1JZ's until the late 90's when the VVTi version was introduced, which has a completely different cylinder head and a single turbo in place of the twin turbos on earlier versions.
sprintless sprinter
Re: 1JZ Variants Fri, 16 May 2003 07:13 Go to previous messageGo to next message
I was off the impression that the turbo set up was different in the JZA's? also the sumps are different.
fingers
Darwin
Re: 1JZ Variants Fri, 16 May 2003 07:17 Go to previous messageGo to next message
How are the sumps different?
And these are found in Chasers and Supras? Any others?
Soarer
Wollongong
Re: 1JZ Variants Fri, 16 May 2003 07:25 Go to previous messageGo to next message
As Norbie said, JZX are designations for a chassis type (Toyota Chaser to be exact).
There are a couple of different 1JZ configs:
1JZ-GTE (pre 1996) 2.5 litre twin CT12a turbos
1JZ-GTE (post 1996 2.5 litre single turbo with VVTi
1JZ-GE 2.5 litre, non turbo, VVTi
1JZ-FSE 2.5 litre, non turbo, direct injection (VVTi maybe)
There are also assorted sump configurations depending on the car it came out of.
Pete
gold coast
Re: 1JZ Variants Fri, 16 May 2003 12:47 Go to previous messageGo to next message
Here's a snippet of info.
I have 3 1J's in my possesion, 2 supra motors and 1 chaser motor.
Early supra engines have smooth and glossy plastic cam covers and coil vents. They also have dipsticks that use a piece of cable rather than a strip of steel.
Early 1J's have serpentine belt tensioners that have "LITENS" written on them and are made in CANADA?? This model also have steel pulleys on them. Late ones have plastic idlers.
Remedy
Southern Sydney
Re: 1JZ Variants Fri, 16 May 2003 17:30 Go to previous messageGo to next message
Some have a hydrolic engine fan and water pump setup and others are belt driven. I know the soarer is belt driven, not sure about others though.
sideshow
Re: 1JZ Variants Fri, 16 May 2003 23:08 Go to previous messageGo to next message
there is also early and late ecus
the early has 4 plugs
each plug has 2 rows
similar to 4ag 20v style plugs
the late has 4 plugs
each plug has 4 rows
this is due to the auto ecu and
egine ecu being one unit
fingers
Darwin
Re: 1JZ Variants Sun, 18 May 2003 22:34 Go to previous message
All good info. Thanks Guys.
Previous Topic:Auto with supercharger.
Next Topic:AE82 4AC to 20V 4AGE
Current Time: Thu Oct 22 22:05:02 UTC 2026
Total time taken to generate the page: 0.007282018661499 seconds
