Toymods » Tech & Conversions » Biggest Turbo
SupraPete
Biggest Turbo Fri, 16 May 2003 03:53 Go to next message
YES I've done a search first.
What is the biggest turbo??
I know of the HKS T51R SPL which is the biggest HKS turbo (that I know of) and is rated at 1200hp. http://www.rotaryextreme.com/hks.html
Links with pics, and power output would be great.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Biggest Turbo Fri, 16 May 2003 04:18 Go to previous messageGo to next message
I've heard the words "Garret" and "T88" thrown around a lot.
SUPRAGTE
North Sydney
Re: Biggest Turbo Fri, 16 May 2003 04:23 Go to previous messageGo to next message
I thought it was the T88 too, I think the Turbonetics Y2K is pretty huge too.
The
Re: Biggest Turbo Fri, 16 May 2003 05:06 Go to previous messageGo to next message
All of the above are tiny compared to large diesel/aircraft applications! Smile
SupraPete
Re: Biggest Turbo Fri, 16 May 2003 05:08 Go to previous messageGo to next message
Which ones specifically Norbie? sites would be good. How much hp are they rated at?
Jason
Re: Biggest Turbo Fri, 16 May 2003 05:42 Go to previous messageGo to next message
I dont know exact sizes etc but i use to work in both these industries.
The largest aircraft engine with a turbo i ever worked on was 720 cubic inches flat eight which i think equates to about 12 litres their were larger radial engines that i worked on wich were about 1820 cubic inch but these had superchargers.
I think youd have more luck and joy with a turbo designed for a diesel application this is because aircraft generally have a price tag to suit. If you want to investigate price try serches on these engine manufactures and parts distributers
Lycoming
Continental
Aviall
OEM
Garret
Soarer
Wollongong
Re: Biggest Turbo Fri, 16 May 2003 07:20 Go to previous messageGo to next message
T88-34D is the largest I've seen in a car.
Of course truck turbo's are larger, but would be near useless on a car, since semi-trailers have massive engines (8 litres+) which are required to spool the buggers.
The largest turbine I've ever seen is actually a hydro-electric one at a dam. They measure about 10 metres in diameter, but I don't think any mechanical device in the world could spool one up easily Razz
Soarer
Wollongong
Re: Biggest Turbo Fri, 16 May 2003 07:32 Go to previous messageGo to next message
Have a drool over these:
http://www.trust-power.com/02greddy/turbine.html
68rolla
Re: Biggest Turbo Fri, 16 May 2003 07:53 Go to previous messageGo to next message
Nasa uses turbo's on there shuttles to make some stupid amount of horsepower, cant remember an exact figure.
Here is an interesting MR2 turbo
http://www.ozsupra.qld.org/web/stuff/stuff_mr2.htm
Re: Biggest Turbo Fri, 16 May 2003 08:05 Go to previous messageGo to next message
I'd rather some of the bigger Apex'i or HKS turbos because none of the Trust ones have ball-bearing races, and from the things I've read tend to have a bit more lag for the power they produce.
rusty
Re: Biggest Turbo Sat, 17 May 2003 09:47 Go to previous messageGo to next message
common misconception that ball bearings make a difference to spool. they dont. the fact that the whole turbo is a new design, the housings and blades, is much more influential than the most obvious marketable difference, the ball bearings.
both turbonetics and garrett make turbos up to and past the 2000hp point, so the 'biggest' turbo for a car is whatever you specify.
sound performance in the states will sell you a turbo for a supra with up to 88mm inducer which will flow over 1500hp, and make over 1000hp at the wheels through an auto box on a dynojet dyno.
diesel turbos are not ideal for performance cars because they are configured for high pressure, into a big diesel engine which turns 2000-2500rpm and makes only maybe 4-550hp. contrast that with a turbo like the greddy T88 (IHI/misubishi turbo), or T51R SPL (garrett turbo with housings cast for hks in japan) which is designed to flow similarly high pressure, but over 1000hp.
the requirements are very different and finding performance is not simply a matter of putting a large turbo from a big engine onto a smaller engine.
Re: Biggest Turbo Sat, 17 May 2003 14:08 Go to previous messageGo to next message
The biggest turbo made that I know of is a little on the large side for a car, considering it's bigger than a bloody whole car! I read about this somewhere back when I was doing engineering at uni, used on a diesel engine for power generation, one thing I can remember about the engine itself was it had a stroke of around 95cm (thats CM, not MM!), 12 cylinders, a bore who-knows-how-big, and a massive (or was it a pair?) turbo to assist it to produce 10,000+hp at some unbelieveably low RPM. Of course, look to ocean liners for big engines Very Happy
toycelica77
bris
Re: Biggest Turbo Sun, 18 May 2003 01:28 Go to previous messageGo to next message
most stationary engines, like in powerplants and mine, have turbo's with an impellar size of around 1-1.5m across, so big they actually have they're own oil sump and pump...
the 40tonne trucks ahve a smaller one (bout the size of a small human crouching) and these are rated at about 3000hp i think, all mapped to dilever boost at around 1000rpm to about 2400, which is redline for the big capacity deisals
celicaboy
Re: Biggest Turbo Sun, 18 May 2003 04:34 Go to previous messageGo to next message
i believe that the trboes off the freight liner semi's are the biggest road going turbos out Very Happy sub zero's skyline has one in that biiiiig turbo but there are bigger then that even Very Happy
gold28
Madrid - Spain
Re: Biggest Turbo Mon, 19 May 2003 06:23 Go to previous messageGo to next message
Going on what Norbie said, wandering through work, I came across this
http://members.optusnet.com.au/~nez_tony/mypic5.JP G
http://members.optusnet.com.au/~nez_tony/mypic6.JP G
http://members.optusnet.com.au/~nez_tony/mypic7.JP G
It is basically the aircon fan on a P3 orion aircraft.
I reckon it would look great bolted up to a certain gold RA28 Razz
CrAiGzEE
south of the big smoke
Re: Biggest Turbo Mon, 19 May 2003 08:19 Go to previous messageGo to next message
hmm ya would think havin a big would make ya car go fast! but why cant trucks beat me?? Twisted Evil Twisted Evil
Re: Biggest Turbo Mon, 19 May 2003 10:07 Go to previous messageGo to next message
Probably the 40+ tonnes of weetbix sitting on the back! Then again, ever watched truck racing?
rvrolla
Central Coast
Re: Biggest Turbo Tue, 20 May 2003 03:04 Go to previous message
Well... I read somewhere that the CT26 is the biggest turbo to be put in a production car !? Shocked
And as for the truck racing, they pull something like 1000+hp
Previous Topic:Koni Shock Absorbers for AE86
Next Topic:W5x Gearbox to 2T/3T with 1G bell?
Current Time: Fri Nov 20 09:23:19 UTC 2026
Total time taken to generate the page: 0.0085539817810059 seconds
