Toymods » Tech & Conversions » engine water temp. How low is too low
willwal98
Toowoomba
engine water temp. How low is too low Fri, 16 May 2003 04:38 Go to next message
Hi guys, I've been having trouble with overheating for a while, had a pressure test and no problems there so next step was the thermostat. Pulled it out and sure enough rated at 88c so clipped the middle out and now sits on about 70c (no more than 80c climbing the toowoomba range, very big hill for people not in the area). I start work at 4:30am so it's quite cold then and temps reach only about 65c. How cold is too cold? If this is ok I will leave it as it is, otherwise i'll get a proper thermostat. The only problem I can see is that the heater is useless a 4:30am at around 10 degrees Very Happy (cold feet on the way to work).
rob_RA40
c'town, NSW
Re: engine water temp. How low is too low Fri, 16 May 2003 05:43 Go to previous messageGo to next message
most toyota engines operate around 82deg
EDIT: whoops i see u have an 18R-G there
[Updated on: Fri, 16 May 2003 05:44]
TA22-3SGTE
MACKAY
Re: engine water temp. How low is too low Fri, 16 May 2003 12:21 Go to previous messageGo to next message
Try and get a 72deg thermostat for it , without a thermostat in cold weather it takes to long to warm up and 90% of engine wear occurs while the motor is cold .
Trevor
willwal98
Toowoomba
Re: engine water temp. How low is too low Sat, 17 May 2003 04:15 Go to previous message
yeah ok, thanks guys for the feedback.
Previous Topic:T series Diff into #E3# Corolla
Next Topic:ke35 corolla paddock basher power up????
Current Time: Sat Nov 21 22:02:16 UTC 2026
Total time taken to generate the page: 0.0049059391021729 seconds
