Toymods » Tech & Conversions » signs of .. blown turbo seals ??
Ae86-Te
Tas, Australia
signs of .. blown turbo seals ?? Fri, 16 May 2003 09:16 Go to next message
hey! Confused
my car when it idles blows blue/white(ish) smoke.. when its warm! you can smell burning oil when you drive it for a while as well! has got really bad l8ly! a few ppl said oil seal at the back of the turbo? wot do you guys think? some1 else said valve stem seals? does any1 know around about the cost to recondition a Garrett t25?
thanx
feral4mr2
Bundaberg, Qld.
Re: signs of .. blown turbo seals ?? Fri, 16 May 2003 12:34 Go to previous messageGo to next message
Freak yeah. you'll find it will smoke more at idle.
have a look in your i/c pipe work as well, if the inlet seal is leaking there'll be oil in them.
TE72_Turbo
Re: signs of .. blown turbo seals ?? Sat, 17 May 2003 13:42 Go to previous messageGo to next message
what motor is this on? I have previously had similar problems on my 4AGTE...
Re: signs of .. blown turbo seals ?? Sat, 17 May 2003 13:52 Go to previous messageGo to next message
Yes most likely turbo seals - take it out, give it a bit of a hiding, then pull over and let it idle for a minute or two. If you start to choke to death, then it's a pretty sure bet the turbo seals are knackered. When you say 'garret T25', do you mean something from a Nissan engine? If so, you might well be up for an apalling repair bill.
Ae86-Te
Tas, Australia
Re: signs of .. blown turbo seals ?? Sun, 18 May 2003 06:36 Go to previous messageGo to next message
..the motor is bluetop 4agze, now (te) with a Garrett t25 turbo from a Nissan Silvia! (ca18det)
Yes! u take it for a bit a hiding when you have stopped it smokes bad! Hasn't lost any power though!
thanx heaps 4 tha info!
TA22-3SGTE
MACKAY
Re: signs of .. blown turbo seals ?? Sun, 18 May 2003 12:12 Go to previous message
To test if it is the rear turbo seal , Go for a drive and get the motor to operating temp then with the motor idling block off the crank ventilation breather/s for about 10 sec , if it starts pouring out smoke it will be the seal .
Trevor
Previous Topic:engine transplant bne
Next Topic:Is overfilling a gearbox a problem?
Current Time: Fri Oct 23 10:32:26 UTC 2026
Total time taken to generate the page: 0.0077369213104248 seconds
