Toymods » Tech & Conversions » Is overfilling a gearbox a problem?
CuRtana
Is overfilling a gearbox a problem? Fri, 16 May 2003 23:33 Go to next message
Hi, I think I may have overfilled my W50. I cant get out the plug at the bottom or the filler plug to check, is this going to cause any major problems? I imaging not having enough oil would not be good for the box, but is having too much bad for the gearbox?
Damian
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 00:53 Go to previous messageGo to next message
How did you fill it if you cant get the plug out?
Anyway there is a little vent hole at the top of the box anyway, so if any oil really needs to get out it will!
CuRtana
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 01:24 Go to previous messageGo to next message
I filled it through the shifter hole as none of the plugs will come out. THats ok isnt it? i know its not the best way, but it'll do (i hope)
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 01:48 Go to previous messageGo to next message
How do you know that you actually filled it enough?
manipulate
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 02:18 Go to previous messageGo to next message
IF u dont know ...dont assume
always do things the proper way if u dont know
Mind u its good of u to ask as oppose to not caring but still.....do the job properly...
y cant u get the plug out....cant get to it ? or your too weak ?
CuRtana
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 03:51 Go to previous messageGo to next message
Too weak Razz and so are dad and his mates Sad
Jason
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 04:17 Go to previous messageGo to next message
You have a PM
manipulate
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 04:31 Go to previous messageGo to next message
Curtana if the bolt is too tight its just a simple matter of getting enough length on the spanner....simple....
just hook up 2 even 3 spanners together to get enough leverage and pull away....be carefull not to damage your spanners though
Rolla Boy
Club Member
Sydney, NSW
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 05:50 Go to previous messageGo to next message
The only problem with overfilling anything is the extra stress that it puts on the oil seals...
BansheeBuzz
Gold Coast
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 06:44 Go to previous messageGo to next message
get yourself a good 1/2 inch breakerbar!!!
Re: Is overfilling a gearbox a problem? Sat, 17 May 2003 07:16 Go to previous messageGo to next message
Rolla Boy wrote on Sat, 17 May 2003 15:50
Why? The gearbox is not a sealed unit, it has a vent or 2!
nilezy
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 05:53 Go to previous messageGo to next message
hey
I would have thought that if you overfill a gearbox and submerge the gears, or part of the gear to much, it will place to much load on that gear from being to wet. Or it will just cause to much friction, and you will loose a percentage of power in the gearbox.
Not 100% sure though, just a thought...........
Nilezy
Flem
cambo
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 07:37 Go to previous messageGo to next message
IF IN DOUBT WHIPP THE OXY OUT!!!. Try appplying a slight amount of heat to the filler and drain plugs then/or try tapping it with a hammer, but what you really need as stated before is more LEVERAGE.IF the spanner keeps on slipping of it may be worth while investing in single hex sockets.
RA60_Celica
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 08:10 Go to previous messageGo to next message
if you fill it to much it will basically fuck it. its just as bad as not having enough oil in it. for one the seals will have extra stress, the synchros, and dog teeth will be harder to engage, and can even cause overheating problems. as for filling it in the gearstick hole that is bad. the gearstick is in a seperate area , the extension housing and if the oil manages to find its way to the bottom it all wont go in the area you want it. i would not fill a gearbox unless u can get both plugs out, try a rattle gun, dangerous but it works every time just dont strip it Confused
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 08:22 Go to previous messageGo to next message
Too much oil is worse than not enough (note that I said 'not enough', not 'none'), for all the reasons already given.
This goes for anything that requires a certain amount of oil.
What I wanna know is, how did you know it needed oil in the first place, if you couldn't undo the top plug?
Rolla Boy
Club Member
Sydney, NSW
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 09:28 Go to previous messageGo to next message
Nice question Joel... Maybe it was hard to shift or noisy???
manipulate
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 09:43 Go to previous messageGo to next message
I assume he was changing the oil ?
undid the drain plug and couldnt undo the filler plug
BigWorm
Turramurra, Sydney.
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 10:21 Go to previous messageGo to next message
Nope, he said he can't get out either.....
manipulate
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 10:23 Go to previous messageGo to next message
What a freak
Rolla Boy
Club Member
Sydney, NSW
Re: Is overfilling a gearbox a problem? Sun, 18 May 2003 10:55 Go to previous message
manipulate wrote on Sun, 18 May 2003 20:23
What a freak
HAHAHAHAHAHAHAHA!!!!!!!!!
You evil man Mani...
Previous Topic:signs of .. blown turbo seals ??
Next Topic:Removing 7mge injectors
Current Time: Wed Oct 21 08:58:47 UTC 2026
Total time taken to generate the page: 0.10888290405273 seconds
