Toymods » Tech & Conversions » 1G-GTE fuel pump
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon5.gif  1G-GTE fuel pump Sun, 23 June 2002 15:06 Go to next message
Hi guys,
Just wondering what fuel pump others are using for their 1G-GTEs. I'm currently running the stock pump in the RA65 fuel tank that I've got. The 22R-E was a 2.4L but there's a pretty major power difference so it's a bit suspect whether it can deliver enough fuel...
Anyone know any other decent pumps that'll fit into an RA65 fuel tank?
Re: 1G-GTE fuel pump Sun, 23 June 2002 15:14 Go to previous messageGo to next message
Maybe you should go to the Mk2 forums/groups and see how the guys with their 7M-GTE's are getting along. Might have more of an idea considering they have the same fuel tank.
Nark
Cabramatta, NSW
Re: 1G-GTE fuel pump Sun, 23 June 2002 23:36 Go to previous messageGo to next message
That's a damn good idea! Thanks dude!
TOY77
Re: 1G-GTE fuel pump Mon, 24 June 2002 06:39 Go to previous messageGo to next message
Nark,
I'm running a bosch - volvo pump... but mine runs from a surge tank... so its a different set up.
Have you had the flow rate tested?
Stew
Guest
Re: 1G-GTE fuel pump Mon, 24 June 2002 09:11 Go to previous messageGo to next message
Nark, go get a Bosch "040" or "019"
they are the largest intank pump bosch make.
they will support any amount of power that a 1g can make (maybe even "morboost") and can easily be modified to fit into your tank.
they will provide all the flow and pressure headroom you'll need.
also Nod Nod NOTHING BEATS BRAND NEW Nod Nod when it comes to fuel pumps.
drop me a line , we found the cheapest place for 'em too.
Matt
Nark
Cabramatta, NSW
icon9.gif  Re: 1G-GTE fuel pump Mon, 24 June 2002 09:18 Go to previous messageGo to next message
TOY77 wrote on Mon, 24 June 2002 4:39 PM
Yeah, I've had some mechanics test it. They told me that it flowed enough, but I'm not sure I trust what they say...
Guest
Re: 1G-GTE fuel pump Mon, 24 June 2002 09:33 Go to previous messageGo to next message
You can flow it yourself you know.
just get the pump to pump into the bucket for a set time and work out the litres per minute.
if it doesn't flow 2.5 litres a min then throw it away !!
Matt
Darren
Re: 1G-GTE fuel pump Mon, 24 June 2002 09:39 Go to previous messageGo to next message
Flow isn't the only consideration, I've seen lots of pumps flow fine but won't hold enough pressure.
Darren.
Guest
Re: 1G-GTE fuel pump Mon, 24 June 2002 10:02 Go to previous messageGo to next message
True, but it's one way it can fail, that is easy to test.
it only gets more complicated after that.
Les
Re: 1G-GTE fuel pump Mon, 24 June 2002 23:23 Go to previous messageGo to next message
Alrignt TOYO give it up... how much - I need one too Smiley =
Guest
Re: 1G-GTE fuel pump Tue, 25 June 2002 00:17 Go to previous messageGo to next message
The prices range up to $600 depending on where you get it.
the cheapest place we found was in QLD i think. they overnight freighted (free) it for $435.
I will get the phone number off my brother.
sounds like a lot but fuel pumps are not cheap.
The legendary "bosch mtorsport" unit will set you back $600 + from most places.
Celicamad has told me in the past though he has a place he can get get good external pumps for 250, and he can also get a surge tank to suit for 150.
email him.
Matt
Les
Re: 1G-GTE fuel pump Tue, 25 June 2002 00:44 Go to previous messageGo to next message
aiite - thanks...
i been getting round those prices for a VL turbo fuel pump $2-300...
is that reasonable, I heard they do the job.. my car is stocker for the mement too... and has the 2.4L fuel pump
Nark
Cabramatta, NSW
icon5.gif  Re: 1G-GTE fuel pump Tue, 25 June 2002 01:26 Go to previous messageGo to next message
How hard is it to open up a fuel tank?! Are there any special considerations? Apart from trying to keep crap from getting into it.
Les, I forgot to get to you ask BD4s to flow test the pump for you.
Les
Re: 1G-GTE fuel pump Tue, 25 June 2002 01:34 Go to previous messageGo to next message
Max.....what for ??dont think i will bother, just follow the trailed and tested route...VL turbo pump sounds like it will e a good upgrade..
my mechanic mate told me that it needs a new pump anyway ! Nod
Guest
Re: 1G-GTE fuel pump Tue, 25 June 2002 03:33 Go to previous messageGo to next message
vl turbo is good for around 160 rwkw. if thats ebough then they are a good pump.
I thought they could be had brand new for less than $200.
make sure you shop around
MAtt
Les
Re: 1G-GTE fuel pump Tue, 25 June 2002 04:04 Go to previous messageGo to next message
160 rwkw ey Smiley =)))))))
any pointers for me... all the places i have called (syd) are over $200 mark.. Nope
disco stu
Re: 1G-GTE fuel pump Tue, 25 June 2002 13:35 Go to previous messageGo to next message
I just got a boshc vl turbo external pump for $280.
Are the $200 ones bosch pumps or doesn't it matter.
Tim
Les
Re: 1G-GTE fuel pump Tue, 25 June 2002 22:50 Go to previous messageGo to next message
hmmm im not too sure.. i made the calls a while ago - but sorry, I meant round 200.. prolly more lie 250-280 for Vl turbo fuel pump.. where did u get yours from Stew ?
Les
Re: 1G-GTE fuel pump Tue, 25 June 2002 23:04 Go to previous messageGo to next message
MAX
if you are reading this.... tell me what fuelpump u get and the $$$... I will prolly follow your lead and buy the same...pretty much that is what I have been doing anyways regarding the conversion !! ask u what u did then follow !!
Nark
Cabramatta, NSW
icon14.gif  Re: 1G-GTE fuel pump Wed, 26 June 2002 01:41 Go to previous messageGo to next message
Les, it prolly won't be for a while. I'm very broke right now.
I'll tell ya about it when I get it done though.
japspec
Re: 1G-GTE fuel pump Wed, 26 June 2002 02:54 Go to previous messageGo to next message
Hey guys
Q: Does the VL turbo pump flow more than the NA pump??
Q: Would this pump fit well to a HR33 GTST skyline, an original one is like $900!
Guest
Re: 1G-GTE fuel pump Wed, 26 June 2002 03:29 Go to previous message
Japspec, for your r33 I would strongly recomend the large bosch intank units "040" or "019".
all you need for the conversion is a phillips head screwdriver, hacksaw, and a large stainless hoseclamp.
the first time I did this changeover took 50 mins (r32gtst), drive in -->drive away, subsequent times even less.
it is very straightforward, and they are awesome pumps.
Matt
Previous Topic:Hybrid 3T 2TG
Next Topic:1JZ Injectors
Current Time: Thu Nov 19 23:19:36 UTC 2026
Total time taken to generate the page: 0.0074119567871094 seconds
