Toymods » Tech & Conversions » Donk a 7M-G(T)E in a MA61
ZZT231
melbourne.vic.au
icon5.gif  Donk a 7M-G(T)E in a MA61 Sun, 18 May 2003 10:15 Go to next message
Hey All,
I don't know if this thread has been done to death but is it easy and what is required when bolting a 7M-G(T)E into it and do i require an Engineering Certif if I just go the 7M-GE.
Is it hard to do the change over and what parts of the loom do i need to retain.
I haven't done a conversion and wondering how hard is it to do?
ZZT231
melbourne.vic.au
Re: Donk a 7M-G(T)E in a MA61 Sun, 18 May 2003 10:16 Go to previous messageGo to next message
Also I forgot to add. How does the insurance company react to the changing to a more modern and powerful motor?
Cheers.
Cressida Supra
Re: Donk a 7M-G(T)E in a MA61 Sun, 18 May 2003 14:48 Go to previous messageGo to next message
engine wiring loom must be changed, ecu must be changed
insurance company wont blink for 7mge, but will go berserk for the turbo motor (will do it, but will cost you)
its a fair amount of work, and not much more to go 1jz, i'd suggest that
Peewee
ed_ma61
Lost in the K hole
Re: Donk a 7M-G(T)E in a MA61 Mon, 19 May 2003 05:05 Go to previous messageGo to next message
needed:
front sump
front oilpump pickup
original 'front' mount engine mounts off the 5m in the car
ecu and loom
7m fuel pump resitor and relay (5m uses the afm to do this)
it all bolts in with zero required modification
and theres only 2 (maybe 3?) small loom plugs which need to be mated to the body loom.
7mge has a cpacity increase under 15% over the 2.8L 5m, but power is over the 15% increase required by the rta for engineering purposes. its also JUST over a 15% increase over the 5mge (what a pain) - but if you convince the lowly rta types that our cars came fitted with a 6m, say, in japan (200hp) you MIGHT get awat with not engineering it...
i, rather biased-ly, think the 7mge is a great motor, and think that the swap is well worth it if you like the thoughts of playing with a hi-per na powerplant...
ed
BlackSupra
Re: Donk a 7M-G(T)E in a MA61 Mon, 19 May 2003 07:41 Go to previous messageGo to next message
http://andy.supras.org.nz/
http://www.supras.com/~riemer/gte/reg.html
http://www.celicasupra.com/7mgte/
ZZT231
melbourne.vic.au
Re: Donk a 7M-G(T)E in a MA61 Mon, 19 May 2003 07:42 Go to previous message
I am thinking of getting a cheap project car to mess around it and use it as a run around car and trade up the old SA63.
Don't know yet... Just accessing what is good to do at the moment yet do it with in a tight budget.
Previous Topic:BOV'S which one 4 me??
Next Topic:How to mask cam cover detail... ???
Current Time: Sat Oct 24 14:52:27 UTC 2026
Total time taken to generate the page: 0.0055420398712158 seconds
