Toymods » Tech & Conversions » Info on an 18rgu
people100
Rocklea qld
Info on an 18rgu Sun, 18 May 2003 12:12 Go to next message
I have an 18rgu engine. twin solex carbies. I am chasing cheap injection manifold, possible with hardness, Extractors and info on where to get a haed gasket from. i am rebuilding it for my sa63 celica, looks like a supra. Any info would be great thanks. Also have 78 corona parts for cheap sale including 18r with extractors. Will seperate.
Blaze
Re: Info on an 18rgu Sun, 18 May 2003 22:48 Go to previous messageGo to next message
If you want a hand with the wiring I can help. Just did one myself. To make things easier get yourself a loom from an older 22RE.
Mr DOHC
Re: Info on an 18rgu Mon, 19 May 2003 13:39 Go to previous messageGo to next message
genuine head gasket is like $70 or so dollars and are available at the brissy warehouse
RJB - Aus
Re: Info on an 18rgu Tue, 20 May 2003 01:51 Go to previous messageGo to next message
Blaze wrote on Mon, 19 May 2003 08:48
Hey everyone, my first post of the forum Smile
Blaze, whats that part about the 22RE loom? I have a Triumph Dolomite Sprint running a 18R-GU with head work and mild cams (its just getting ready for rego), and my first mod after getting a new paint job is to put on EFI (assuming it'll actually fit). The hardest part IMO is going to be getting all the parts, so if I could get the loom out of an old Corona it would make life alot easier. Whats the deal?
[Updated on: Tue, 20 May 2003 01:52]
Re: Info on an 18rgu Tue, 20 May 2003 12:26 Go to previous messageGo to next message
He means you can use the ECU, wiring harness and sensors/injectors from a 22R-E. These are much easier to find than original 18R-GEU items, and with a bit of fiddling will work just as well. You still need the 18R-GEU manifold/plenum etc though.
RJB - Aus
icon7.gif  Re: Info on an 18rgu Tue, 20 May 2003 12:39 Go to previous messageGo to next message
^^^ Yupp, no worries, thanks for that.
Norbie, could you do a real quick favour for me please? In my Dolomite there's very little clearance between the airfilters from the Solex's and the brake master cylinder. If you could take a minute to quicky measure the length of the EFI manifold ect from the head to its outer-most pont, I would really, really appreciate it. I'm just worries that there's not going to be enough clearance to fit in the EFI gear. Thanks man Smile
Blaze
Re: Info on an 18rgu Tue, 20 May 2003 22:55 Go to previous messageGo to next message
My 18rgu with efi gear on came with all the sensors and injectors. I tried wiring up the loom myself, without success. So BansheeBuzz suplied me with a full uncut loom from a corona with and eary 22RE in it. It turns out my loom was fine. I was using a coil and ignitor from a 21RE that didn't have a ballist resistor like to old one that was on the 18rc.
I just put all the positives together and negatives together and thought that would work. not so. I ended up getting an ignitor from an old 5me as i know Norbie uses that one. It has a ballist resistor and when I wired that all up correctly the injectors started to pulse.
So all I meant was for the ease of thing using a uncut loom is easy as piss, just connect the ECU plugs up to the right wires and then the rest is self explainitory. just plug the same colour plug into the same colour sensor or injector. leave the rest that of the plugs that you don't need a lone. Simply
On another side note as Norbie said you can use the 22re gear and with a little tinkering can get it to work. At the moment i am using the AFM from a 2se camry. It still needs a slight tune throught the spring tension but on the negative it doesn't allow for the idle mixture to be adjusted. Its been blocked off. So I am swapping it this arvo for an 18rgeu one that I have.
[Updated on: Tue, 20 May 2003 22:59]
RJB - Aus
Re: Info on an 18rgu Wed, 21 May 2003 01:28 Go to previous messageGo to next message
Thanks Blaze Smile
Tiger
Kuranda
    5-speed gear stick
Re: Info on an 18rgu Tue, 14 September 2004 05:49 Go to previous messageGo to next message
Hiya fellow Qldner,
Greetings from Kuranda. Am doing up my '79 celica LT2000 with 18rgu engine. Any possibility of getting scanned wiring diagrams for the engine. Some dopy bugger didn't do a proper jobe & half the wires are missing. It's her 25th B'day this month & want to bring her up to Showroom condition. Can you help plz.
Tiger.
Re: Info on an 18rgu Tue, 14 September 2004 05:55 Go to previous message
You've dug up a thread which is about 18 months old... I don't think Blaze posts here any more.
Previous Topic:another 18r related question OIL PUMP
Next Topic:Mx62 Cressida, Cold Start Probs, Fueling Up.
Current Time: Fri Nov 20 16:01:00 UTC 2026
Total time taken to generate the page: 0.0067989826202393 seconds
